Question about Intel Motherboard
Computer Monitor Switched OFF By BIOS SETTINGS
I accidently switched off my Monitor Display by the BIOS Setting. Now My computer is working but my monitor is not showing anything.
How do i Revert it back????
PLZ HELP
  • abhisar2006 Dec 14, 2008
    Thanx But you see i cant see a thing on my monitor.
    if there are any shortcuts then i might be able to do it.
    the computer works fine but the only thing is in the display
    Scholar:
  • 111 Answers
You will need to reset your BIOS setting to its default.
Every motherboard is equip with a jumper called clrtc (Clear RTC), look in your motherboard manual to find out how to use it to reset your BIOS. Or if you know the type of your motherboard, please share it.
Posted on Dec 14, 2008
How do i find a manual or the secret menu?
I don't think a monitor setting is causing Windows to not appear.
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 24, 2014 | Likom Computers & Internet
My acer monitor H243H says No Signal after I unplugged the DVI cable and plugged it back in. I can't switch the input because nothing happens when I push the input button on the bottom of the monitor. It...
Maybe your BIOS switched to VGA output, try plugging in another monitor which has VGA input and change settings in BIOS for default output to DVI.
Nov 05, 2013 | Acer H243H Monitor
I had problems with my monitor. I am purchasing a new monitor. When the new monitor is connected to the computer does the BIOS default setting adjust to the new monitor? I am just a computer user not,...
Sometimes the BIOS doesn't display properly on the widescreen monitors if your video card was built before widescreen monitors were acceptable. I have an old ATI Radeon video card from 2006 and it cuts off the BIOS setup screen when setup. If a 640 X 480 monitor was plugged it, the problem would go away. The graphic drivers aren't going to initialize in your computer until the computer is booted which compensate for the current resolution settings.
Another solution is to see if you have a BIOS upgrade available for your computer that will create a resolution and refresh rate that will work for your monitor.
Oct 11, 2013 | Computers & Internet
My newer flat screen monitor went black but works fine when hooked up to another computer and I have an older monitor that I hooked up and the older one works fine...??
That sounds like a display/resolution setting problem on your PC. I doubt there is anything actually wrong with the PC or the monitor, since both work with different combinations, so its most likely just a setting.
Some monitors don't display anything when they get a signal/resolution that is not compatible with their displays. I would try changing the display settings on your computer with your old monitor, then switch monitors and see if your newer monitor works.
Here's how to adjust the display resolution:
If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust/lower the resolution. If in Vista/Win7 right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Feb 15, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
I change my video card settings in Bios to AGP, after that, i already installed my video card, but no display appeared, ican't restore my video card setting to previous settings because my monitor has no...
if you still have old video card remove the new one and replace with old one
change setting back in bios
then reinstall new card and instead of changing through bios just start computer it should automatically change settings for you
please let me know
May 03, 2009 | Computers & Internet
I accidently Switched My Display to PCI Settings in the BIOS Settings in my computer. Now the display of my monitor is off but my Computer is running
With computer disconnected for elecctric,Go into machine. Disconnect the battery. Reconnect the battery. Start computer back up gettign back into the startup routine and change it back.
Dec 14, 2008 | Computers & Internet
Monitor goes into sleep mode after a few seconds
This is normaly cause by incorrect power management settings.
check power management setting in both windows and your computers bios
you will not need to worry about the power management settings of the bios when an operating system such as windows is loaded.
Loch Hiam
Az.
Sep 18, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Monitor Problem
I fixed the problem by acquiring a recovery disk that booted me into the bios screen and the screen came on. I then changed the settings, I still don't know why it happened in the first place though!
Thanks anyway though
Aug 23, 2008 | Acer AC 711 17" CRT Monitor
Green Flash power only on one computer
It sounds like the monitor functions properly and your computer functions properly, but the combination causes a problem. Try making sure the screen resolution on your main computer is set to an acceptable resolution for your monitor - AL1916. Try setting it low to 800x600 and move up from there until it doesn't work anymore. You can change the screen resolution from the Display Settings (right click on the desktop and select Display Settings) window.
Jun 11, 2008 | Acer AL1916B 19" LCD Monitor
Intel Motherboard Logo
54 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
