Question about Lanzar VIBE266 Car Audio Amplifier
Now speakers well i had an amp problem but i fixed it. But now my speakers dont work. they turn on when the amp turns on but they make like a static sound, i dont think it is the speakers cuz i have another set and they do the same thing...so if anyone has an idea i would appreciate it. i have a multimeter, so if i can check the speaker wire to the subs then if someone could let me know how that would be great to ... thanks for any input
    Problem Solver:
  • 13 Answers
Check your connections on your speakers themselves, also check your connections of the speaker wire to your amp and also check for any cuts or damage throughout your wiring as this my be caused by the + and - wires that touch
Posted on Aug 15, 2007
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
I get static and crackling sound out of right speaker, then it blows the speaker fuse, Sanaui au-999 what is wrong
Any of the transistors in the right channel power amp section circuit will have the fault. Check it. A very skilled work indeed.
Apr 15, 2012 | Audio Players & Recorders
Basically, I've noticed a fairly faint static noise while listening to music at about 30%-40& with the Logitech z-2300's. I dont know if the problem persists when the speakers are any higher because I...
Most speakers I have owned or listened too have a faint buzz or static to them. If you are using a computer turn up the volume on the computer all the way and then you should not have to turn the volume knob on your speakers past 20% that's what i did with mine and they sound fine. If you are using something else like an i pod or something like that make sure you turn the volume on the device all the way up to ensure you don't have to turn the speakers up that high. If that's not your problem then i don't know.
Dec 12, 2010 | Logitech Z-2300 Computer Speakers
I have a Yamaha RX-V640 AV receiver. When I turn on the system, one of the rear speakers makes a hissing noise and system goes in standby mode automatically. I have tried changing the speaker and speaker...
Hi
the noise that you hear is a static, on the main circuit some components needed to be replaced. dont connect the speakers while you have this problem it can burn the speakers
if you want to fix the Amp let me know
ecrdn@yahoo.com
Jack
Oct 12, 2010 | Yamaha Audio Players & Recorders
PEAVEY XXL AMP HEAD PROBLEM!!! NEED HELP NOW!!!
Hi...
Do you have the Impedance switch set for the right cab?
Are you using a guitar cord to connect to speaker cab ?...If so, dont. Use a speaker cable.
Is the damping switch loose?
Jun 23, 2010 | Audio Players & Recorders
It is an old speaker (DM601 S2) but well cared for. Have clear sound in one speaker and static in the other.
It sounds like a ground problem with the speaker crossover circuit or the amplifier. Turn the amp off and disconnect one speaker and interchange it with the other using the same speaker wires. If the static speaker is now working interchange the speaker wires and try it again. Or if the same speaker still has static it is the speaker. If the static is on the same channel then you have a bad wire or if both channels work it was a bad connection. If the problem remains on the same channel change the speaker wires. If the problem switched to the other channel then it is a bad speaker wire or connection. If the same speaker has the same problem it is most likely the crossover circuit in the speaker which is used to filter frequencies of the audio signal by using capacitors and coils. If the static speaker is now working and the other speaker is now not working it is the amplifier. If the static problem is on all input devices I would trouble shoot the preamp section of the amplifier.
Jun 23, 2010 | B&W DM602 S2 Speaker
Front speakers only produce static
The amps are on each of the speakers. There is a place in Florida that will fix them for around $85.00 each plus shipping. I put a sony unit in mine and replaced all of the speakers with the kicker ds series for less than fixing the bose system.
May 29, 2009 | 1991 Cadillac Seville
Subwoofer wont play
change your rca's you may have a bad one that is grounding out or one of your spkr
Apr 14, 2009 | Alpine MRP-M1000 Car Audio Amplifier
Static from right from speaker
The noise is in the pre-amp stages of the Denon AVR. It might be caused by bad capacitors.
Mar 08, 2017 | Denon AVR-1803 Receiver
Surround Sound gets static
I'm trying to understand if the speakers are connected directly to the TV, or via an amp. If you have an option try connecting them through an amp so that the TV doesnt have to amp them, you'll get better results. even if there was no static in the first place its a better idea. Good luck!
Jan 02, 2006 | RCA MM52110 52" Rear Projection HDTV-Ready...
Lanzar VIBE266 Car Audio Amplifier Logo
Top Lanzar Car Audio & Video Experts
Mike Duncan
Mike Duncan
Morne Olivier
Joe Alexander
Joe Alexander
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
