I accidently Switched My Display to PCI Settings in the BIOS Settings in my computer. Now the display of my monitor is off but my Computer is running
    President:
  • 2,692 Answers
With computer disconnected for elecctric,Go into machine. Disconnect the battery. Reconnect the battery. Start computer back up gettign back into the startup routine and change it back.
Posted on Dec 14, 2008
Why will HP a6700f onboard VGA connector will not provide a signal ?
have you tried when in the vga card to go to control panel/display and look at change display settings and connect to a projector?
Mar 07, 2017 | HP Computers & Internet
I am not getting any display on my Dell 22" monitor once connected with XFX ATI Radeon 5750 card. Monitor goes on stand by mode. I have installed the drivers on XP 32bit but still no display. For...
Is one/both running in a PCI slot? Is one in an AGP slot? If you are running AGP and PCI you can select priority in the BIOS.
Your description points out that both are PCIE... so my first thoughts are probably moot, but I will leave them up just in case......
If both are PCI, it would depend on your BIOS - some allow priority asignment. Your motherboard manual is the best tool for this.
It sounds like you know what you are doing, but I will throw this out there just in case....
Did you try swapping slots and seeing if there was a change?
My guess is that you are a serious gamer and tweaking performance.... if nothing I offered so far has helped, check your MB manufacturer for any BIOS upgrades since running dual video cards, especially the newest and hottest ones requires a BIOS update.
Off topic.... I am VERY curious what else you have under the hood of your setup!!!!
GOOD LUCK!
Jan 28, 2011 | Pine Technology XFX ATI RADEON HD5750 5750...
Computer turns on ! No display ! Did system restore and No Display
first thing how did you do a system restore without display? second thing unplug your display from the power and your computer then plug it back in making sure that the plugs are all the way in. then check that the monitor is switched on it should says something like no signal found, now turn on your computer, if you still dont get any display try to test the monitor on another computer or laptop with an external display socket. if the monitor works on another computer then you need to look at video card. if it is an onboard video card then you are probably out of luck and will have to buy a pci or pci express(pcie) card for it. i know that SR2013WM comes with integrated graphics so if thats what your using then just buy a graphics card and you will be up and running again. if you play games then get one with at least 512mb and also one that has a fan i have found that the ones without fans can heat up and slow everything down. ok i hope that helps let me know how you go.
Jan 20, 2011 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
Have connected it correctly but keep getting NO SIGNAL message?
If you have graphics card, You need to connect the monitor pin to the graphics card.
If you are connecting through graphics you must change the option in the bios to PCI to get the display.
If you do not have graphics card. Then try changing the connecting cable of the monitor.
Please ensure that you have switched on the power supply for the monitor..
If still problem persists then I suggest you to connect your CPU to another monitor and try to check whether you are getting display or not.
If you are not getting display there might be something wrong in the motherboard with the monitor pin.
This must fix your problem.
Let me know if you still persist the same problem.
Regards
May 24, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
No display assus motherboard PSN73-AM ASUS MOTHERBOARD
When the PC starts up, do you get a BIOS display at all? Try fitting a graphics card into the board instead of using the built in port, if that works check the BIOS settings to see if the built in adapter has been disabled,
Mar 26, 2010 | ASUS P5N73-AM Motherboard
Onboard VGA port disabled, in Vista
You should try to disable it in the hardware list.
E-machines have an odd bios where not all the functions of the motherboard are available to the user.
If you can find the make and model of your board there is a good chance you can find the PROPER bios for it.
Emachines use motherboards from a variety of regular motherboard suppliers
My older e-machine has a hacked bios so that I can alter ALL the settings.
Aug 24, 2009 | eMachines EL1210-11 PC Desktop
Display problem
Hi there
try going into the bios settings and disable the on board graphics and change it to PCI or PCI Express.
You may have to plug the monitor into the on-board VGA port to do this, once done shut the computer down and change graphics port, then restart the pc, your problem should now be solved
Good luck and kind regards
Jan 06, 2009 | ASUS P4SGX-MX Motherboard
Computer Monitor Switched OFF By BIOS SETTINGS
You will need to reset your BIOS setting to its default.
Every motherboard is equip with a jumper called clrtc (Clear RTC), look in your motherboard manual to find out how to use it to reset your BIOS. Or if you know the type of your motherboard, please share it.
Dec 14, 2008 | Intel Motherboard
Chips M863G V1.5 Motherboard
This type of problem is so common nowadays. What I did is open up the casing, pulled out the RAM and by using pencil eraser, rubbed the contact pattern. Put it back and turn on your computer. Always work for me and hope it might work for you too.
Feb 08, 2008 | Chips M863G V1.5 Motherboard
Computer turns on, but there is no display on monitor.
The builtin video card is probably bad. Yes, you can get a PCI video card.
Dec 28, 2007 | Dell Dimension 2300 PC Desktop
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
