Question about Dishwashers
Broken door spring?
Opened the door, followed by a loud bang now the door is very heavy.
  • microhand Dec 21, 2008
    Same problem of my Kitchenaid dishwasher. The model number is
    KUDI01FLSS6. I can see the cable(rope) is broken. Where can I get the part if I want to try to fix it myself.
    By the way, my wife said that nobody will fix it anymore. Either you buy a new dishwasher or leave it alone. Is that true? Thanks.
  • Anonymous Feb 16, 2009
    door cable is broken on my KUDP01FL KitchenAid dishwasher
    Do you have instructions so I can fix it myself?
  • 145 Answers
Either a spring or a door cable. On newer Kitchenaids and Whirlpools, it is usually a "cable" made of rope and plastic that breaks, not the spring itself. Get me the complete model number and I will look it up for you...
Posted on Dec 14, 2008
Fix broken garage door torsion spring
I would call a residential door company. Those springs are not something I would recommend the average homeowner to mess with. Sorry!
Jun 01, 2015 | Building Materials
Dor hinge repair
I fixed my Fagor disgwasher spring last night. The symptom was a bang and the door got heavy. Investigation revealed a broken cord. The parts are available at around 20 UK pounds per pair. They consist of a cord with plastic mouldings at each end. A heavy duty spring sits inside the washer parallel to the door bottom and is streched as the door is opened. I would not recommend buying the spares as getting them off the spring is almost impossible. I had a vice with tools and gave up. Instead I bought some similar cord (try a ships chandler/dinghy shop), one metre should do (99p). Remove the spring and cut the cord off at the moulding. Put the spring in a vice and drill out the cord. Start small (2mm) and work up. Put the new cord through the hole. Bend the spring and use a small screwdriver to fish out the cord. Tie a knot in it. Take a large flatblade screwdriver and open up the coils so the knot will pass through. Drill the other plastic moulding and repeat. The cord length between the mouldings was 280mm but measure the unbroken one. The dishwasher I had a cover clipped in place at the bottom of the door. Lever this forward and the spring is easy to remove.
Apr 18, 2014 | Fagor Dishwashers
Loud popping noise occurs when refrigerator door is opened
of course not! you paid good money for that fridge! can you train everyone to open the door only to 85 degrees?
Mar 08, 2013 | Refrigerators
I have an Indesit DV62WHUK dishwasher and the last night the door made a banging sound when it was opened and now it won't close and will fall back under it's own weight. I suspect either a spring, spring...
There is a plastic unit behind the door handle which houses a spring under tension. This latches the door closed and makes the electrical connection to allow the machine to work properly. You need to buy a new unit (£15) which is a bit fiddly to reach but easy to fit (2 screws)
Dec 02, 2010 | Indesit 23 in. DV62 IX Built-in Dishwasher
Dishwasher door drops hard when opened.
Sounds like one of the doors springs is broken or has come detached from the dishwasher housing frame. If you have a plain dishwasher door, ie one that does not have a wood panel matching your cabinets, and the spring(s) are broken, new springs cost about $20. If you have wood panel on the dishwasher door, then you may need heavy duty replacement spring at about $22.
Jan 15, 2010 | GE Dishwashers
The drum shakes violently and is very loud during spin cycle
There are 2 shock absorbers/springs attached to the drum. If one of them breaks it will cause a loud banging noise when you wash heavy loads. This is an easy fix. The part is about $22.00 and it is accessed throught the front bottom panel.
Dec 01, 2009 | Frigidaire GLTF1670A Front Load Washer
Loud Banging Noise
if its a loud banging noise when the unit kicks off then broken spring in compressor will have to replace compressor check your 2-5th year warrenty in your owners manuel
May 14, 2008 | Hotpoint HTS18GBR
Loud bang during spin
Remove the top of the machine and check if the centralising spring/s is/are still attatched. Next remove back cover or tilt machine back and inspected the shock absorbers. One of the shockies could be broken or just pulled out of the guide. If springs and shockies are ok open the door and try to move the inner drum up, down and sideways. If it is very loose, then the centre bearing is worn.
Oct 27, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Dishwashers Logo
323 people viewed this question
Top Dishwashers Experts
