Question about Teac DC-D2831 CD Shelf System
Audio cartridge My cartridge is so worn that I get a lot of skips and distorted sound. I would like to replace the cartridge but don't know how or where to buy a new cartridge. Sollie
    President:
  • 3,130 Answers
What cartridge are you asking about? The phono, or what?
Posted on Mar 28, 2007
How do i stop the arm skipping on an ion pure turntable. This happens on old and new vinyl. the machine is just out the box.
To stop it jumping you need to increase the weight located on the end of the arm slightly then test play a record, if it jumps you increase the weight again slightly and test again. Repeat till it stops. If it rumbles decrease the weight.
As for the sound. You need to find out if the deck uses a magnetic cartridge or some other type. If it uses a magnetic cartridge it will have to be connected to an amp with a Magnetic Cartridge Pre-amp built in. Or you will need to purchase one (pre-amp that is) if it has not got one. This can be then be plugged into a standard jack socket.
If it does not use a magnetic cartridge, don't put it one marked for "phono". Instead put it in a tape, aux or cd socket.
Feb 17, 2015 | ION Audio Pure LP USB Conversion Turntable
I've got an Audio Technica LP-1240 turntable with a Shure M97xE cartridge. I've had it for several days now, and it's been playing fine. I just got a record cleaning kit (Tonar cleaning brush with a bottle...
A damaged or worn stylus will effect all records not just one. I don't know what D4 fluid is, but if there was some still present on the record it could have got inside the cartridge and done some damage to it.
Sep 21, 2013 | Audio Players & Recorders
I need someone who actually knows about audio and particularly MOTU microbook and headphones. I do voice transcription through headphones and am looking for clarity in audio but also a little bit of...
The realtek chip should come with the HD audio manager in the control panel if the drivers were installed correctly.
You'll want to check and make sure the equalization (under the sound effects tab) is set to none, or possibly to treble (I had to use the treble setting on mine if using a sound system with a subwoofer).
Another trick to raise the frequency of the audio is to raise the "Karaoke setting which will pitch shift all frequencies upward.
Jul 21, 2011 | Computers & Internet
My Samsung HLP6163W started making a loud buzzing sound and the picture is distorted. I've read around and have come up with two possible solutions: replacing the lamp or replacing the color wheel. ...
100% this tv problems it is the tv colors wheel it is defective require replacing.The loud tv buzzing noises sounds are the sounds came from the tv wharp colors wheel it is spinning out control wildly and off of it motor axis and by hitting it to the wall of it steel box holding it.The tv distorted colors pictures are came from out of the reflections of a badly worn out of the tv colors wheel.
Jul 08, 2011 | Samsung HLP6163W 61" Rear Projection...
I have the Acer AspireOne. I suddenly started getting sound distortion on songs played in itunes--it skips then plays really slowly and with a mechanical type sound to it. I thougt there was a problem with...
I have the exact same problem with my acer aspire one. Just recently is started distorting with a mechanical sound...skipping on the videos and making it impossible to actually listen to anything or watch any videos. I thought it might just be an isolated problem until i noticed it happening during startup, etc. I have not found a solution yet but am updating the audio driver. Let me know if you resolved this issue! Thanks!
Sep 10, 2010 | Acer (54.AA806.001) Sound Card
Hi i recently bought a cobra 29 ltd chrome cb radio for my car,i also installed a new antenna ,i have a strong signal,but i am unable to hear conversations because the sound is distorted.It sounds like...
You can't tune the radio. You are supposed to tune the antenna.
I have a page for tuning your antenna. This can cause some distortion, but it shouldn't be that bad. Go here for how to tune your antenna.
also the internal speakers aren't that great. Try an external. I can't just use an internal because an external is so much better.
Something else to consider. There is a lot of skip right now. Skip is when the ionosphere becomes charge by solar flairs, and causes radio signals to skip across it, making them travel hundreds and even thousands of miles. There are some cb operators out there who run a lot of power. 10k watts and up, who just talk skip all day. A lot of those guys sound extremely distorted and over modulated. You may be hearing these guys out there. Its their radio's not your receive.
Also. People who are close to you, may over load the front of the radio in the receive section, which will make it sound distorted.
Aug 16, 2010 | Cobra 29 LTD CB Radio
My print is fuzzy and has a lot of skips in the text. The problem started when I put in "copy" paper and new cartridges from cartridge world at the same time and I cannot tell which might be the problem,...
Some copy papers are extremely thin, and the printing on them will look fuzzy, but if you have skips in the text, this problem is with the cartridges. Look at the heads of the cartridges and see if they are clean. If that doesn't work, i would return the cartridges and try another set. The same thing happened on my HP, I replaced the cartridges and it worked fine!
Feb 12, 2010 | Lexmark P6250 All-In-One InkJet Photo...
JBL PSW D112 Distorted Sound
your memory is low on resources need to increase memory.everything on ur pc uses mem.audio and video devices use an aweful lot.if you have open another program not only will ur audio be distorted but ur other program will be running slow.
correct? need to add more ram.
Mar 07, 2008 | HP Pavilion dv4000 Notebook
Sony handicam trv skips playback like in slow motion?
you need a computer with at least 1.5 ghz and 1 gig of ram anything less will cause recording to pc problems
Oct 26, 2007 | Sony Handycam DCR-TRV280 Digital Camcorder
CDA-9855
Try lens cleaner first, always the best idea. If it makes a clicking sound when trying to read the discs, you're looking at a bad optical pickup.
Oct 24, 2006 | Alpine CD Player CDA-9855 LIMITED QUANTITY...
Teac DC-D2831 CD Shelf System Logo
70 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
