We have an AWM 295-1000 frontloader and it keeps stopping during the washing cycle. We need to wind the dial to the next click to re-start the machine several times during each cycle. Also the fabric softner doesn't dispense as it should and the washing comes out not smelling nice.
  • Anonymous Apr 27, 2009
    Did you get an answer to this, we have the same machine, same problem.
  • nigesmith May 25, 2009
    Same problem, have to manually move the dial round a bit then it gets going again.
  • 5911 Answers
SOURCE: fabric softner
Remove the dispenser tray. Inspect the area just above the fabric softener portion of the dispenser. There should be a series of holes where water feeds into the tray during the rinse cycle. Sometimes these holes become clogged with fabric softener residue. If the holes are clogged, water will never dispense the fabric softener out and it will stay in the tray. If you take some cotton swabs and meticulously clean all the holes out, I bet your problem will go away. Let me know if this was helpful to you.
Posted on Oct 06, 2007
  • 75 Answers
SOURCE: Fabric Sofner won't dispense
hi there remove the soap drawer then remove the cover over the softener compartment you will more than likely find a blockage in the cover siphon or the down tube on the drawer
Posted on Feb 29, 2008
  • 1314 Answers
SOURCE: Front Load Does not dispense fabric softner and bleach
under the bottom panel of the washer on the left hand side is a tech sheet that will tell you how to fix this
Posted on May 16, 2008
SOURCE: Fabric softner is building up in dispenser
Same deal - I have to soak up all the residual water in the softener dispenser between washes. (The detergent and bleach compartments are fine).
Posted on Jun 19, 2008
SOURCE: Kenmore front load washer will not dispense fabric softner
I've had this same problem and solved it by removing the detergent/bleach/softener dispenser drawer from the machine and seriously cleaning out all of the "gunk" from the drawer and from inside the drawer area on washer. Sometimes I have had to repeat the cleaning and then the fabric softener begins dispensing again. I have model # 417.43042200 but it may work on all the Kenmore front loading washers.
Posted on Apr 16, 2009
My hotpoint wm63p washing machine when in wash cycle works up until the last spin and then u hear clicking and the machine will skip the cycle and stop or sometimes just continue to the next dial cycle..i...
If you have changed the brushes are satisfied that they are fitted correctly, then it can be a couple of possibilities.
1- The motor itself is faulty.Even though it does the wash o/k it is possible the spin winding is faulty.
2- The prograqmmer is faulty.
Make sure the pump is working o/k, and that all the water has drained out, as this would stop it spinning
Dec 15, 2010 | Hotpoint Washing Machines
Whirlpool AWM 5080 stops during cycles
Sound like could be faulty pump however you need to make sure no
Could be pump at fault 1st you need to make sure no coin stuck in there ...
Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Can''t get my clothes out... water still inside
does it have a dial that you can manually turn to start the next cycle? You can usually drain the water by pulling the drain hose out from the wall drain behind hte washer....( usually just shoved in the drain not attached) but be aware that when you hold the hose below the water level in your washer it will start to drain. Then perhaps the door will unlatch.
Sep 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
The machine does not automatically go from one cycle to the next
You have a pitted timer most likely. First i would check out the lid switch which you may be tripping while messing with the timer. And what brand and age.
Mar 29, 2009 | Washing Machines
Whirlpool Duet 9100 starts cycle then stops & wont drain
F2 code is a drain issue. If you are not using he detergent you can cause slow draining and then you will get the code. Try using less detergent. Also, try disconnecting the power to the washer to reset controls.
Mar 24, 2009 | Whirlpool GHW9100L Front Load Washer
Ariston frontloader - dial spinning around and won't start a cycle
Your bearings are almost certainly gone which would explain the noise not an easy job or cheap . Normally it would consist of a tub change or at best a bearing hub . As for the clicking round of the selector Iwould suggest poss the heater or brush fault. As ofr price you'd have to ask your local repair man. Worst case sinario approx £200 .00
May 30, 2007 | Ariston Technologies AWD120 13 lb. Washer...
Open Questions:
Washing Machines Logo
274 people viewed this question
Top Washing Machines Experts
