Question about Brother MFC-8870dw Wireless Multifunction Laser Printer
Replace Fuser error will not go away
How do I get rid of the 'Replace Fuser' error on a Brother MFC-8870DW printer? Also, how do I get to the maintenance menu for this machine? the Menu, *, 2...codes did not work for me.
  • 3 more comments
  • pbpro Dec 16, 2008
    The Issue:
    I print by default in duplex mode. This has caused the printer to prematurely increase the count of the pages printed (basically has doubled it). Since I have printed over 100k pages (actually 50K pages), the printer is reporting "Replace Fuser" message.
    What I am looking for:
    After reading multiple posts on many websites regarding Brother printers, i read about different sequences for entering a maintenance menu where one can reset the "Replace Fuser" message.
    The problem is the sequence of keys varies by printer models. I have tried the sequences described for printer models within this family (line) of printers. My printer is MFC-8870DW. Other printers in this family are MFC-8860DN, MFC-8460N, etc..
    The codes described did not work for me. Given that can somebody provide the sequence to:
    1. get in to the maintenance menu for the MFC-8870DW and,
    2. re-set the "Replace Fuser" count as well as other functions?
    Also, is there any documentation available that describes the above and functions available under the maintenance menu?
    Thanks,
    PBPRO
  • pbpro Dec 18, 2008
    I figured out how to get into the Maintenance menu:
    1. Turn off the printer
    2. Hold down the Menu button
    3. Turn on the printer - DO NOT release the Menu button until the "Please Wait" message on bottom of the LCD disappears.
    The lights on the printer (FAX, COPY, SCAN - blue lights, and the yellow STATUS ligth) will flash.
    I know pressing 91 changes the top LCD line to show INIT on it and pressing 99 exits the Maintenance menu.
    Pressing 91 did NOT get rid of the "Replace Fuser" message though - will keep trying. If anyone knows the sequence codes for resetting this counter back to 100% lief, please let me know.
    Thanks in advance,
    PBPRO
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    I would suggest, unless you tried this, to use 92-98 and see what results you get. I'd also give the 8 numbers a try down to the zeros and ones as well. It the only strategy I know of the uncovers these closely guarded secrets and I really want to publish yours when you find it for the benefit of all.
  • Glenn Rogers
    I did not find anything regarding your exact printer either. When we techs have a machine in our hands, we ferret out the access method using the hunt and peck process. This may be your only hope.
    Keep me informed when you do succeed.
    Thanks, I know you will. You sound like the type of person who does not give up.
    Regards,
    Worldvet
  • Glenn Rogers
    Did you start into the maintenance menu by opening the cover door and then pressing the Clear/Back key?
    Thanks,
    Worldvet
    Sniper:
  • 56 Answers
With in 2 seconds you have to hit Menu,*,2,8,6,4
Continue even though you hear the 3 beeps.
When it does into maint mode press 88
That is parts counter reset
Scroll to the part and hit ok.
Press 99 to exit Maint mode
Posted on Jan 15, 2009
    Problem Solver:
  • 9 Answers
I wrote an article on this subject. Brother 8870 fuser replacement and reset procedure
Posted on Aug 07, 2012
Machine error code 55
Sir/madam
Please Follow the Video http://www.youtube.com/watch?v=xig75RXA5qc For Your Printer Brother Troubleshoot
Or Follow Us For On Brother Printer Support
Jan 23, 2014 | Brother MFC-8870dw Wireless Multifunction...
Mfc 8480dn error code 78
error code 78 is a fuser error. You will need to replace the fuser with a new one.
May 04, 2011 | Brother MFC-8480DN All-In-One Laser...
MFC-8870dw 30ppm Wireless Network Multifunction Laser Printer with Duplex Printing, Copying,...: How do I connect my Brother MFC-885CW printer to m...
Connect the printer with a USB cord to the computer. Switch off the printer and install the driver in to your computer , during installation the software will tell you to switch-on the . Do so and finish the installation .
This is the procedure to connect the printer with your computer.
May 17, 2010 | Brother MFC-8870dw Wireless Multifunction...
Wrinkled copies
Fuser unit is about the only thing in this model of printer that WILL cause wrinkling/creasing of the paper. So most likely, yes you are going to need to replace the fusing assembly.
Part# LU0214001K
About a $179.00
The vendor I use is precisionroller.com
Good Luck
Mar 04, 2010 | Brother Multi-Function Center MFC-8870DW...
I have a mfc 8870dw and just replaced the toner now it displays "toner error" what can i do
Remove and reinstall the cardtridge.
Check manual for new cardtridge code (if needed).
Nov 17, 2009 | Brother Multi-Function Center MFC-8870DW...
8870DW scan function does not work with macBook using USB
You must reinstall the software on the computer to which the printer is physically connected. i think u are using usb to connect to computer so to share it out u most buy printserver or use let the computer where its physically connected just to be on and u share there the computer to your workgroup computers
Dec 27, 2008 | Brother Multi-Function Center MFC-8870DW...
Resetting "Replace PF Kit 1" message
Same with me on my MFC 8870DW. The procedure worked perfectly:
1) Turn off printer
2) Press and hold menu button and turn on. Keep holding button until you see maintenance on display.
3) Press 88. This brings up parts replacement menu.
4) Press Up arrow until you see the part you replaced (laser, fuser, pf kit1, pf kit mp).
5) Press the OK button.
6) Power off and restart printer.
But how do I know whether or not I really NEED to replace a PF Kit1? I guess I'll find out if it recurs soon.
Joe
Jun 18, 2008 | Brother MFC-8460N Laser Printer
1,496 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
