Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Brother Mcf-260c scales printing on fast draft
Printer is running on mac osx 10.5 (networked too) but even on thecomputer that the printer is connected to it prints the document at approx 1/4 scale on fast draft and 1/2 on normal fast draft, have checked all settings and still cannot find a solution,
any ideas?
SOURCE: Coupon printer problem - can't unselect Keep Printed Documents
Informes de fax enviados
Posted on Feb 09, 2008
SOURCE: HL-5250dn ona Bonjour network will not work with Leopard
Brother is totally fucked up under Leopard, found so far no chance to fix it.  Brother's own printer drivers are 10.4 only -- lame
Posted on May 10, 2008
SOURCE: I want to find the MAC address on a Brother
Go to Printers and Faxes.
Right click on the printer and select Properties.
Toward the bottom, click on Printing Preferences...
Click on the Support tab.
Click on Print Settings.
This should give you three pages. The third page has the network settings including Ethernet/MAC address.
Posted on Apr 06, 2009
SOURCE: Will not Print online Coupos
A huge Thankyou! I fixed it!
Posted on Dec 05, 2009
  • 114 Answers
SOURCE: MFC-8870dw 30ppm Wireless Network Multifunction Laser Printer with Duplex Printing, Copying,...: How do I connect my Brother MFC-885CW printer to m...
Connect the printer with a USB cord to the computer. Switch off the printer and install the driver in to your computer , during installation the software will tell you to switch-on the . Do so and finish the installation .
This is the procedure to connect the printer with your computer.
Posted on Jul 21, 2010
My Brother MFC-260C will not print black even thought the cartridge is full.
This may have a problem with you printer cartridge try to clean it in your computer by using the printer maintenance which is including in the printer software where you've stalled in your computer.
To check and see if your printer has this option, click on "Start" then "Printers and Faxes." Right click on the icon for your printer. Scroll down to "Printing Preferences." Look for a tab called "Maintenance" or similar wording. Next, click on "Head Cleaning" or similar wording. Your printer will make some noises as the print cartridges are being cleaned. Run a "test page" after the procedure is complete. Repeat steps if necessary.
Hope this steps helps you.
Aug 12, 2011 | Brother MFC-260C All-In-One InkJet Printer
I have installed the brother MFC-260C on my Imac and it won't print, it is reading that it is there but coming up with the error invalid format for short nickname.
I assume you are running snow leopard on a MAC.
Please click on the link below and download and install file, this should resolve the issue.
Mac printer drivers.Brother printer drivers for Mac 10.6:
http://www.apple.com/downloads/macosx/apple/firmware_hardware/brotherprinterdriversformacosxv106.html
Jun 17, 2010 | Brother MFC-260C All-In-One InkJet Printer
Just replaced Netgear WebSafe router with Linksys WRT400N. Now, can't "see" printer in network nor can access it to change settings (or print). Have tried with ethernet cable straight to router and through...
Reset printer to factory settings according to manual. Plugged in ethernet cable directly to router. Ran BRAdmin which recognized printer and saw that IP address had been automatically set within new router range. Changed setting to STATIC. Deleted old printer definition from printer list and added updated definition using Printer Setup Utility. Printed test page from BRAdmin. Also printed file from Documents folder wirelessly. Changed printer settings in another laptop & was able to print wirelessly from there as well.
Jan 07, 2010 | Brother HL-2070N Laser Printer
Brother MFC-260C no black ink
Check this link. Will save you all a lot of money.
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
Jan 05, 2010 | Brother MFC-260C All-In-One InkJet Printer
The printer prints the letterhead but not the text on the page.
either your print cartridge is running out of ink or your settings is set to fast draft
Jun 20, 2009 | Brother MFC-665CW All-In-One InkJet...
Won't accept photo paper
Only load photo paper do not mix it with plain paper, this will happen on all printers.
May 03, 2017 | Brother MFC-260C All-In-One InkJet Printer
Wireless Printing problems Vista to 10.3.9 Mac to Brother Printer
I have a wireless Mac ,version osX.4.11. I have a Colorsmart HP Priner 4100. I have created documents in IWorks Pages. I can not print directly. I have to save the doc as a PDF email, email to myself, go to Safari, then the printer will print. What am I doing wrong?????
Feb 26, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Setting HP OfficeJet 4315 print preferences on a MAC OS X
Whenever you send a file to print from a program a small window shows up. If it shows only
Printer: Drop down menu ARROW Presets: Drop down menu Some buttons at the bottom
then click on the ARROW pointing down for more options. That will show more info, including a drop down menu that will allow you to change page settings, printing settings, etc. For example, if you want to change the printing quality, select "Paper Type/Quality" from that drop down menu and new options will show up allowing you to change the settings of the printer.
Jan 10, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
67 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
