You can remove the panel and check for fault in the connectors and the line to the display, use a hair dryer to warm and dispel any moisture on the board and panel. If there is no result then the panel has to be replaced. To remove click : control panel
Have you lost complete control of your washing machine? ... If your PCB assembly (printed circuit board) is faulty then replace today for an efficient and effective ...
8 Jun 2010 - Replacing any of the front panel controls on a washing machine is ... how to replace any of the knobs, buttons, printed circuit boards that sit ...
14 Nov 2013 - Watch Josh explain how to diagnose washing machine control and program problems. ... If you then suspect that the problem still lies in the circuit board ... to test the board and you'll actually just need to replace it altogether.
31 Oct 2009 - 15 posts - 11 authors
hotpoint aquarius wf530 washing machine flash like Christmas tree when ... After reading this forum I took the PCB board out and the C17 ...
19 Mar 2011 - 14 posts - 9 authors
Just took the board out of the washing machine to check the c17 cap ... was gonna cost £150 just for a replacement board without fitting.
This is the Mark 6 board fitted to late Hotpoint washing machines. The module will be programmed to your model number - ready to fit. Typical models are WF550P WF560G .... Hotpoint Arcadia PCB Modules. SKU: 256. Hotpoint Arcadia PCB ...
Adwww.hotpoint.co.uk/SparePartsrating for hotpoint.co.uk
Save £5 When You Spend £35 or More! Low Cost and Next Day Delivery.
Price Match Guarantee · Spend £35 & Save £5
F14 means that control board does not sense that machine is heating:
F14 - A fault with the water heating has occurred
When you get F14 the fault is usually either the thermistor or the heating element (electric dryer). Both parts are tested removing the part from the dryer and reading impedance at the part contact. If the part returns infinity, then the part is defective. If you need to contact a qualified technician use the phone number listed on your owners manual or check Hotpoint website.
A few reasons for this, faulty heater, broken wire, faulty pressure switch or faulty main control board (the heater relay is on the main control board).
There is no reset for this. Unplug the appliance and take the rear cover off.
Check the wiring to the heater and thermostat. Give the wires a good tug as they can break internally and look ok. If you have a multimeter, test the heater, it should read around 25 ohms. Take the top off the appliance, locate the pressure switch (has a thin tube on it), give it a few good taps with your screwdriver handle. Finally, take the main control board out (bottom left when viewed from the rear) and one plug at a time, take them off, clean and tighten them, plug them back on. If everything checks out ok, then it's likely the main control board is at fault.
Sounds to me like you are having a problem with the control board........Bad news is its one of the more expensive parts on units....Good News is its one of the easier parts to replace if you are not an Appliance Service company.......Look into getting the control board in the control panel! [email protected]
