Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
TV WONT POWER ON
I HAVE A MITSUBISHI WD-62725 PROJECTION TV AND IT WONT POWER ON. THERE IS A GREEN LIGHT ON THE FRONT OF THE TV WHICH FLASHES CONSTANTLY. I TRIED THE SYSTEM RESET BUT THE GREEN LIGHT STILL FLASHES AND THE TV WONT POE[WER ON. I HAVE NOT CHANGED THE LAMP NOR HAD ANY SERVICE PERFORMED. ANY SUGGESTIONS ON GETTING IT TO TURN ON?
  • docgasp Dec 16, 2008
    I TRIED YOUR SUGGESTIONS BUT TV STILL DOESNT POWER ON. THERE IS NO "NUMBER AND SEQUENCE OF BLINKING GREEN LIGHTS" AS THE LIGHT BLINKS CONSTANTLY AT ABOUT 4 TIMES PER SECOND. I HELD THE DEVICE/MENU BUTTON FOR FIVE SECONDS BUT NOTHING HAPPENED (THE SCREEN IS BLACK). ALSO, I SAW NOTHING IN THE SLINTERIORS SECTION ON THE WEBSITE YOU RECOMMENDED THAT SOLVED OR EVEN APPLIED TO MY PARTICULAR PROBLEM. WHAT SHOULD I DO NEXT?
  • docgasp Dec 21, 2008
    TRIED THAT SEVERAL TIMES ALREADY. UNPLUGGED TV FOR MORE THAN HALF AN HOUR AT A TIME. GREEN LIGHT STILL FLASHES CONSTANTLY! ANY OTHER SUGGESTIONS?
    President:
  • 2,110 Answers
This message board and *************** just saved me either $1000.00 or $4500.00. To all the contributors who posted photos and instructions on the dreaded "flashing green light" T-H-A-N-K Y-O-U ! TV WONT POWER ON - rofl2.gif
As of Firday night. I had the TV re-assembled (with new capacitors installed)
and I had almost conceded and given up. When I plugged the TV back in I had no power and no flashing green light. NOTHING.
I've spent the rest of weekend using CNET.com to read reviews on the editor's choice awards for plasma sets and wondering how I'd pay for a 52" - 1080p Plasma.
Sunday I took the TV apart (not wanting to give up) all the way down to removing the brand new capacitors. Desoldered them, took them out and started all over again. This time when I plugged the power cord in I instantly heard juice go through the set. Walked around to the front and......OMG I had a flashing green light.
In about 30 seonds the green light went out. THE MOMENT OF TRUTH !
I pushed the power knob on the front of the set AND......
BAM -I got a picture.
The WS-55859 has 7 capacitors instead of the "four" that have been mentioned here, on other Mitsubishi sets. They are mounted on a 4" square daughter board inside the DM Module shielded case.
Total cost of the repairs were around $105.00. Seventy five dollars of that came from a universal arm style light that has a big round magnifying glass.
8 - 1000uf 16v 105C Capacitors
1 - Magnifying Lamp
1 - Weller Soldering Iron
1 - .075" Width (Pro Wick Desoldering Braid) Size #3
1 - ROSIN CORE SOLDER
INSTRUCTIONS: (EXPLAINED LIKE YOU HAVE NO SOLDERING EXPERIENCE)
I had never desoldered a circuit board in my life. On my own I finally figured out if you place the desolder braid flat on the board next to the pin (you want to desolder) place the tip of your iron directly on the desolder braid and not directly on the solder. You can briefly touch the solder just to get the wick action started.
Have the desolder braid touching the base of the ***** of solder your wanting to remove. Press your iron directly onto the braid with the braid barely touching the ***** of solder. When iron is hot enough you will see the braid begin to **** the melting solder like a wick.
When placing the solder on the new pins you need a third hand to hold the capacitors snuggly against the circuit board. To do this, I placed the capacitor in place with the two pins sticking through the board. I grabbed one pin with a set of surgical hemistats. Because hemistats are slightly arched, it allows the hemistats to grab one pin and the other clearly visible to solder while the hemistats hold the capacitor in place. Allow it to cool, remove the hemistats and repeat the process till all capacitors are in place.
A TIP ON SOLDERING:
On your first drip of solder onto each pin, make sure it's as tiny as possible.
VERY TINY ! Get it on the pin and set the solder supply to the side. Work that tiny drip with the tip of your iron. You want to work that first drip and get it to **** into the hole of the circuit board around the capacitor's pin. I didn't pay special attention to this on my first pass and my drips were to large. This can lead to loose pins and loose capacitors. The only way to get solder deep into the hole the pins are sticking through is use a very tiny amount of solder.
While your DM Module is completely out and laying on a slightly elevated surface. (I used a plano fishing tackle box) Observe the bottom plastic guide that the DM Module rest in. Toward the outer edge of the TV's back,
you will see a narrow slot in the plastic guide. In my photos I refer to it as a plastic receptacle.
Now pick up the faceplate you have removed from the DM Module. At the bottom of the faceplate is a shark fin shaped piece of the faceplate. Make
sure that lines up and slides back into the the plastic guide properly.
If you don't......your DM Module will seem to not want to slide back in properly. It also acts as a guide to make a copper contact strip to engage properly with proper surface contact.
Removing the DM Module is only slightly tricky. Because your not going to disconnect any wire connectors from any of the circuit boards. The wire bundles leaving the DM Module have just so much length and will not allow you to slide the DM Module out.
So there is a work around to get the DM Module out.
IN my photos, I show you how to rotate the DM Module "in place" and rotating it out of it's resting place.
Above the DM Module is the upper plastic guide that prevents you from doing this rotate "in place" maneuver. The upper plastic guide must be removed by removing two screws.
To get to these screws, just above the plastic guide is a inner wooden shelf that is laying in the TV horizontally. I removed four screws holding it inside the TV's case, and then removed the wooden shelf. (see photos).
Now you can easily remove the upper plastic guide.
STEP BY STEP GUIDE WITH PHOTOS:
STEP 1) The DM Module loose. But it can't be rotate out because of the upper plastic guide.
http://webpages.charter.net/dcrawfo...yUrl/STEP_1.JPG
STEP 2) How the DM Module is rotated out of the TV case. Allow the wires
entering the DM Module to be an axis point of the rotation. That way they barely move and don't get snagged or stretched.
http://webpages.charter.net/dcrawfo...yUrl/STEP_2.JPG
STEP 3) The DM Module out and the side cover of the metal housing removed.
http://webpages.charter.net/dcrawfo...yUrl/STEP_3.JPG
STEP 4) My setup to do the soldering work.
http://webpages.charter.net/dcrawfo...yUrl/STEP_4.JPG
STEP 5) Up Close of the daughter board and the seven capacitors on
Mits WS-55859.
http://webpages.charter.net/dcrawfo...yUrl/STEP_5.JPG
STEP 6) The daughter board unscrewed and flipped over where you will be soldering.
http://webpages.charter.net/dcrawfo...yUrl/STEP_6.JPG
STEP 7) The Upper Plastic Guide that must be removed to rotate the DM Module out of the TV set.
http://webpages.charter.net/dcrawfo...yUrl/STEP_7.JPG
STEP 8) Get this wooden horizontal shelf out (4 screws) and getting the upper plastic guide out becomes easy.
http://webpages.charter.net/dcrawfo...yUrl/STEP_8.JPG
STEP 9) Helpful Hint about the wooden shelf and the platic guide that both need to be removed.
http://webpages.charter.net/dcrawfo...yUrl/STEP_9.JPG
Posted on Dec 21, 2008
    Genius:
  • 1,011 Answers
Sir,
Check this link
Posted on Dec 16, 2008
  • 2,336 Answers
You should find more info from this website. It might be a good idea to test the lamp with a DVM before getting into the capacitors issue.
This type of repair is not a DIY if you are not familiar or have basic electronics knowledge.
  • 10,594 Answers
Green light blinks constantly?
Unplug TV from AC for 15-20 minutes and replug it, power ON.
Above said action will cool down temp sensor in your TV.
Good luck.
  • Shahid Electronics
    Shahid Electronics Dec 21, 2008
    Replace Lamp, if its not being replaced yet.
    Sergeant:
  • 306 Answers
Real common problem, failure of the power supply or the DM (microprocessor) canot reset - can be repaired by a good servicer but not a self-repair issue..else I recommend unplugging it and then holding the power button for at least 3 seconds to discharge the capacitors. I don't know if it works for TVs, but it does work for my computer. Leave it unplugged for at least a half an hour and then plug it back in and try again.
  • AbdulRahiman S Dec 16, 2008
    or you need to replace the capacitors on the DM board. Its a very easy repair. You can get the V23 DM repair kit at the following link which is the one for your model. Its listed under the repair kit category and comes with the replacement capacitors and step by step instructions on CD. Heres the link. http://servicemanuals.vstore.ca/
    Usually when your Mitsubishi TV has a fast blinking light it is amicroprocessor error, the whole board typically has to be replaced. It can cost you between $300-$650.
    The microprocessor boots up at plug in by either flashing 3 times (older TV's) or flashing for 90 seconds. No finish flashing, no boot, bad micro, most of the time.
    The only thing you can really try is pressing the reset button and leaving it unplugged for 5 minutes or so.
    If you STILL have a problem then you may need a service manual, or a service technician.
  • 734 Answers
need to replace the 1000uf capacitors on the DM
board.
Thanks
Posted on Dec 14, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls determine the number/sequence of the green blinks. It represent an error code that will point to the general area of probable fault. Thereafter diagnosis and eventual repairs could be done.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 14, 2008
    A few other ideas you may want to explore:
    • Alternately, press the "Device" and "Menu" buttons for 5 sec and to get the error code.
    • Or better yet, pls contact http://servicemanuals.vstore.ca/ and look for Slinteriors.
    • They have in stock a "repair kit" with instructions for the most common Green Light problems of Mitsubishi units. The kit includes the replacement capacitors with a higher temperature rating and pico fuses.
    • or reference this how-to pages.
  • Louie  Role
    Louie Role Dec 16, 2008
    In some instances, a common cause of the blinking green LEDs is fault at the DM board. This fault is the failure of several capacitors. They have to be replaced.
    This of course would require opening the unit, perform voltage measurements,determine faulty component and subsequent part(s) replacement. Further, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron would be required. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings.Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Tv wont power up after replacing 6 caps 4 bad 2 looked good but were in series so replaced with larger voltage. mitsubishi wd 62725
That model will usually have 8 caps that require replacement on the Power board and also 4 capacitors on the DM board which will usually cause the Non stop blinking light symptom.
Sep 23, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Describe your WD-62725 62 in. Rear Projection HDTV-Ready Television Problem Green light is blinking the TV won't turn on. We've unplugged it and tried to push the reset button and the green light...
If the led light flashes green continuously, the fault came from the DM power supply. The faulty parts there are the electrolytic capacitors. Let me know if your handy with electronics and I will assist you to fix it yourself.
Jdvillanueva
Sep 16, 2011 | Mitsubishi WD-62725 62" Rear Projection...
WD 62725 timer light continusly flashes green TV won't turn on! Push reset button as soon as you release it ,it starts flashing again. Unplug TV 3-4 Hours No help.
The V26 DM repair kit from www.tvrepairworld.com will usually repair that issue. The kit contains the replacement capacitors and the step by step instructions on CD
Dec 07, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi wd-62825 dlp
If the green front panel LED blinks continuously and the TV never comes on, its an issue with the "DM" board. When these TVs are first plugged in, the green LED should blink for 30 sec. to a minute or so. This is the TV booting up, reading its software. Mitsubishi has been having problems with this circuit for several years. In may cases the only permanent solution is to have the chassis rebuilt by Mitsubishi at considerable cost and inconvience. The chassis may have to be sent back to Mits for this rebuild. Call Mits and ask for help.
michtech
Feb 13, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Blinking green timer light
I purchased my WD 62725 in January of 2005 and have had way too many problems with something costing this much.  My green reset button is now blinking and I have read and tried all of the suggested solutions. All of them have failed.  I sure think Mitsubishi should be held more responsible than they seem to be.  Some one suggested a class action lawsuit.  I would sure join one.  Jack P
Oct 14, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-62725 constant blinking of green light
Check the lamp to see if it is damaged(this is in your owners manual for removal)If not please contact me for more info
Mar 24, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Blinking green light, will not power up
Try holding the menu button on the tv while turning on the tv.The other problem might be the connection to the lamp in the tv.They have a nasty habbit of coming loose ore falling out if the lamp is inserted to hard.
Mar 13, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
99 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
