Question about 2-Way Remote Starter
Rs 810 crimestopper coolstart remote engine starter
I have a 98 buick lesabre with a crimestopper coolstart rs 810.when i push to start the vehicle the headlamps,parking lights come on after 3 seconds the starter with these lights still on cranks the engine after 1.5 seconds the motor is started but the starter continues to crank for the 10 second feature this system came with for a hard starting engine have had all wiring looked at for bad connection to find none.I have now noticed that my gauge for charging is at 17 volts and 1 more volt would put it in the red.the battery is new.and i am thinking that maybe something is going wrong with the alternator.could this be the problem with the remote starter problem.
  • 3 Answers
Could be one of several things, and depends on the way it was installed. IIRC, those systems can either detect an increase in voltage when the car starts, or a preprogrammed RPM signal. If you have access to the owners manual, see if you can reprogram the RPM ro voltage threshold yourself. That should see an end to the overcranking......
Posted on Dec 14, 2008
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Sparkplug wiring harness diagram
The spark plug firing order is ( 1 - 3 - 7 - 2 - 6 - 5 - 4 - 8 )
Apr 19, 2014 | Crimestopper RS1505DP CoolStart(TM) FM/FM...
My truck starts right up but will only run for a half a second
It's a problem with a factory immobilizer system of some kind. You should have said the year, make, and model of your truck. I had this same thing yrs. ago on an 98 GMC pickup.
Dec 19, 2010 | Crimestopper RS1505DP CoolStart(TM) FM/FM...
I have a 95 yukon and my auto start will make the truck crank over but it wont start. I can push the auto start button on the remote but it will just keep cranking the engine over but wont start up but if...
It sounds like your security bypass isn't programmed or needs to be replaced. Try to reprogram it and then start the vehicle. Shut it down and try to start it a second time, if it doesn't start the second time the bypass needs to be replaced.
Dec 15, 2010 | Crimestopper RS1505DP CoolStart(TM) FM/FM...
I have lost my 4 button coolstart car remote ser rs-830/rs-810 need to order a new one
You can purchase the remotes directly from Crimestopper or call them to direct you to a dealer near you. Their contact and order information can be found at this link:
Crimestopper contact page
The following 2 links will help you identify which remote you need.
Remote chart by system number
Remote identification by image
Nov 08, 2010 | 4-Button Remote Start/Keyless Entry with...
It works sporadically
look under your dash on the driver side get the model number of the actual unit then go to www.crimestopper.com go to support tab click manuals and manuals again and find the model number you found under your dash the problem with this remote is that the cs34-ii is used on many different units this was told to me buy the tech support from crimestopper. you can try to reset your remote if that does not work maybe your remote just needs replaced
Feb 02, 2010 | 2-Way Remote Starter
Crimestopper Car starter buttons on remote are too sensitive.
wrap a wide rubber band around the remote button that way if it gets bumped it won't send the signal
Jan 09, 2010 | 2-Way Remote Starter
I have a Crimestopper rs-3. I have had 2 instances where my car won't start with the remote or the key. This was just installed 2 weeks ago. Had a tow truck come to tow it to a local garage. The driver...
What type of vehicle is it installed in? Does it crank with the key and not start or does it not do anything? There could be several problems, ie. if a bypass was used to bypass a factory anti theft it could be malfunctioning, if your crimestopper has security features enabled that could prevent it from starting even with the key. (This is most likely if the driver was able to start it by pressing the valet switch). Or there could be a loose connection in the ignition harness. Either way, I would highly recommend taking back to where it was installed and heve them go over it.
Hope this helps.
Oct 29, 2009 | Crimestopper RS1505DP CoolStart(TM) FM/FM...
Trying to install a remote start & keyless entry. I need to know where all the wires from the ignition harness go too???
First you will need to research your vehicles under-dash wiring schematic to identify your object wires, color code and function. The schematic may be found in a Y.M.M.(year,make & model) specific, electrical wiring manual. A related search on the internet, or at your local auto dealerships parts department. Then cross-reference and record your vehicles color coded leads to the remote starts color coded leads with respect to their function.
Hope this helps,,,Good luck
Aduz
Mar 27, 2009 | Crimestopper CoolStart(TM) 2-Way Remote...
Remote wont make truck start?
ok this happend to me once take the key and stick it into the ignition and turn it 8 times only turn it untill the lights go on DO NOT START THE ENGINE EACH TIME after this try it again
Jan 06, 2009 | Crimestopper RS1505DP CoolStart(TM) FM/FM...
2-Way Remote Starter Logo
565 people viewed this question
Top Crime Stopper Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
John
John
Frank Mangiapane
Level 1 Expert
Are you a Crime Stopper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
