Question about ViewSonic E790 Monitor
How to use buttons on front of Monitor for vertical Horizontal settings
I am a older newbe on the computer and I have a problem with a black space around the outer edges of the monitor screen. I would like to know how to use the setting buttons on the front of the monitor to help fix this problem. The resolution is set at 1024 X 760 on my computer.
  • Pat Bee Mar 14, 2007
    Thank you tomj23 for the great help
    and link to the user manual.
    Greatful Oldie.
  • 624 Answers
Oldie, The first thing to do is set the monitor resolution, color depth and monitor refresh rate to what you want then adjust the monitor accordingly. Adjust resolution, color depth and refresh rate for Windows 2000/XP: -Right click any clear spot on your desktop and select properties from the menu that appears. -From the Display Properties box that appears click on the Settings tab. -In the screen resolution section (lower left corner) experiment with the resolutions and see what you like. -The color quality box should be set to the highest (most colors) color setting listed. -Click on the advanced button in the lower right corner. -In the next window click on the monitor tab. -Typically you would want to set it at 70 Hertz or better. The higher the setting the less flicker you will notice, however, there is always a trade off. I would start with 70 Hertz and gradually move up; at some point your monitor will reach a setting it can?t support. If the screen blanks out Windows will reset back to the previous settings as long as you don?t hit any keys. -click the OK button twice. More to follow?.
Posted on Mar 14, 2007
  • tomj23 Mar 14, 2007
    Part II:
    Here is a link that leads to the ViewSonic user manual for your monitor. It has diagrams of the buttons and explains what each does.http://www.viewsonic.com/support/usergui...
    Basically the process is as follows:
    -Press button 1, the main menu should appear.
    -Use the up or down arrow button to the right of button one to move the cursor up or down. Select the H/V position (horizontal / vertical) and press button 2.
    -Use button 2 again to toggle between the horizontal and vertical adjustments, I find it easier to do the horizontal settings first.
    -After you have selected one use the up and down arrow button to center the window in the center of the screen.
    -After it is centered press button 1, this will lock your setting. Depending on the monitor you will either go directly into the expand mode (where you can enlarge the existing display window to the edge of the physical screen) or you will be taken back to the main menu. If you go back to the main menu use the up/down button to highlight the H/V size item. Again press button 2 to enter that section. As before use the 2 button to toggle between the horizontal and vertical adjustments.
    -Repeat process for the vertical settings.
    As you can see there are lots of settings and you can really mess things up without really trying. If you do go back into the menu and select ?Memory recall? which will reset everything back to factory defaults.
    Good luck, let us know if you have any other questions and please don?t forget to rate this posting.
SOURCE:
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
One inch of the window is off the screen
you could adjust the vertical and horizontal adjustment through the main menu of the monitor. buttons on front of monitor. auto adjust may fix it but if it does not look for the vertical or horizontal adjustment fot the area effected. if this helps please rate with comment
Feb 03, 2013 | LG Computers & Internet
My new LG Flatron E2350 does not fill the 23 inch screen only 22 inches with a black border, have updated graphics and monitor card to the latest. What do I need to do for the graphics to fill the 23 inch...
Similar to TV - you need to adjust the "H" - Horizontal and "V" - Vertical. Horizontal will move picture up or down and Vertical will adjust left to right.
Use the menu button on your monitor.
Apr 03, 2011 | LG Flatron L1515S 15" LCD Monitor
There are two vertical lines on my lg flatron w1942s monitor one is red and other is green line
Go to the buttons on the bottom of your monitor it will give you an option to change the vertical and horizontal setting.
Mar 12, 2011 | LG W1942S 19" LCD Monitor
I have a Samsung NC10 notebook hooked up to an Acer x193w monitor and up until today it has been working perfectly. Now the display will not fill the monitor's space. Horizontal is fine but vertically the...
Do you have a spare computer to hook up to the monitor to see if the monitor's settings are off vertically?
Can you adjust the vertical size of the image of the monitor?
Are the letters squashed down vertically?
If the letters are squashed down vertically, did the setting for pixel size of the screen get adjusted to another size accidentally in the control panel under display settings?
Can you reset the Acer monitor from the menu?
Jul 29, 2010 | Acer X193W LCD Monitor
Monitor's display is shifted up and right so that there is just black space to the left and all along the bottom whereby cutting off the display. cannot see bottom menu bar.
One of the buttons on the front of you monitor (bottom right hand corner of the bezel) is a menu button. Press that then using the the arrows up and down buttons go the the horizontal and vertical positioning option. Once chosen move the display as desired.
You could also press the Auto (config) button, that may do the same for you.
May 17, 2010 | Acer AL1912 19" LCD Monitor
The Acer monitor's horizontal and vertical is set
use the function button on your moniter and scroll until you see the setting you want to change and increase it or decrese it from there.
Jul 16, 2009 | Acer AL1916W 19" LCD Monitor
Black at left and right of monitor
Since this is a CRT monitor, it doesn't have a native resolution like LCD monitors. You need to adjust the veritcal and horizontal sizes to fit the monitor. On the front of the monitor there are some menu buttons. You need to open the on-screen menu, then navigate to the Horizontal Size and Position menu, use the plus and minus buttons to grow and shrink the image. If it's not centered, use the Horizontal Position menu to move it around. Use this same system for the Vertical menu and you can get your image to fit your screen. By the way, you should have your operating system running with a white (or light colored screen) up when you do this so you can see all the edges of your desktop. The buttons are tricky, but they kinda make sense. Good Luck!
May 14, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Monitor is vertical display instead of horizontal display
Hi...there! Kazz,
Go to your toolbars bottom R/H corner and look for the VGA settings icon ( nVidia or ATI). Right click on that...and look for rotation settings, from there just followed the settings... Have nice day!
Oct 10, 2008 | ViewSonic VA902 19" LCD Monitor
Hansol 730E CRT monitor
REPLACE THE BOOSTER C 5,6nF-1600V
Oct 18, 2006 | Hansol 730E 17" CRT Monitor
ViewSonic E790 Monitor Logo
172 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
