Question about ViewSonic E790 Monitor
Monitor I am a senior learning the computer. there is a black square around the outer edge of thr monitor screen,How do I use the buttons on front of monitor to fix this problem?
  • 624 Answers
This is a duplicate posting. Click the following link to view the active post. http://www.fixya.com/support/t137689-use_buttons_front_monitor_vertical
Posted on Mar 14, 2007
Cannot fit to screen size
You probably need to install a display driver for this monitor on your netbook. http://us.aoc.com/monitor_displays/e950swn
Dec 05, 2012 | AOC 19" LED Monitor e950Swn Black
Acer laptop switched on light up on switch but no screen display
A blacked-out screen doesn't necessarily indicate a broken monitor. If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on.
To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard.
Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue.
Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue.
Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases. Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop. Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment.
Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard.
Wedge the edge of the keyboard bezel off of the top cover. Work your way along the edge of the keyboard bezel to loosen it. Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector.
Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place.
Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken.
If the monitor doesn't work, the motherboard or video card might need to be replaced.
hope this helps
Hope this helps
Nov 24, 2012 | MSI P45 Neo3-FR (MS-7514-010) Motherboard
Monitor screen display stretched center but squashed/narrow edges
On the monitor itself, I am guessing this is a desktop? There are buttons for adjustment. Look for the menu button around the bezel of the monitor and press it. Scroll through the settings for the default setting and press that. Once the default settings are made for the monitor, then you can go to the graphics settings available through windows to get the resolution straightened out.
Mar 26, 2010 | Computers & Internet
How can i open an hp w2207 monitor
I just got my son's hp w2207 apart. You need to gently pull off the front black frame around the LCD first. Work the black frame away from the silver edging around the entire screen. Then unscrew the four, black screws on the back.
Nov 30, 2009 | HP w2207 Monitor
Power button damange ,
I used two thin putty knives this morning to open the monitor case. First, unscrew the four screws at the back. Then insert a putty knife into the small crack between the front bezel and the monitor shell. Carefully work you way around and wiggle the putty knives. Note that the front buttons are attached to the thin black edge at the front, and there's a thin cable at the bottom. Don't damage that. You can take off the back shell though.
Sep 09, 2009 | Dell UltraSharp 1707FP Monitor
Black at left and right of monitor
Since this is a CRT monitor, it doesn't have a native resolution like LCD monitors. You need to adjust the veritcal and horizontal sizes to fit the monitor. On the front of the monitor there are some menu buttons. You need to open the on-screen menu, then navigate to the Horizontal Size and Position menu, use the plus and minus buttons to grow and shrink the image. If it's not centered, use the Horizontal Position menu to move it around. Use this same system for the Vertical menu and you can get your image to fit your screen. By the way, you should have your operating system running with a white (or light colored screen) up when you do this so you can see all the edges of your desktop. The buttons are tricky, but they kinda make sense. Good Luck!
May 14, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Hannspree HF229H monitor and Windows XP. Images stretch to fit.
I had this same issue.
Go into the monitors menu, go down to "Image Settings", go to "HDMI Mode", select "PC Mode"
Hope this fixes it for you. It worked for me.
Feb 16, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
How to use buttons on front of Monitor for vertical Horizontal settings
Oldie, The first thing to do is set the monitor resolution, color depth and monitor refresh rate to what you want then adjust the monitor accordingly. Adjust resolution, color depth and refresh rate for Windows 2000/XP: -Right click any clear spot on your desktop and select properties from the menu that appears. -From the Display Properties box that appears click on the Settings tab. -In the screen resolution section (lower left corner) experiment with the resolutions and see what you like. -The color quality box should be set to the highest (most colors) color setting listed. -Click on the advanced button in the lower right corner. -In the next window click on the monitor tab. -Typically you would want to set it at 70 Hertz or better. The higher the setting the less flicker you will notice, however, there is always a trade off. I would start with 70 Hertz and gradually move up; at some point your monitor will reach a setting it can?t support. If the screen blanks out Windows will reset back to the previous settings as long as you don?t hit any keys. -click the OK button twice. More to follow?.
Mar 14, 2007 | ViewSonic E790 Monitor
Is there an easy way to open this monitor?
-Flip the LCD face down and remove the screws that hold the base in place. -looking at the top edge of the LCD monitor you should see a small notch on each end between the front bezel and the back cover. -Using a plastic tool or a flat blade screw driver insert the tip and gently pop the case open. -Work your way around the edge of the case. -Once the LCD monitor is open unplug the control panel connector from the right side and remove the front bezel. Let us know if you have any other questions and please don?t forget to rate this post.
Dec 28, 2006 | Dell E173FP 17" LCD Monitor
ViewSonic E790 Monitor Logo
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
