Question about Sewing Machines
Timing is off on my Pfaff 2140/2170 machine.
If I could get detailed directions with diagrams, I could fix my machine. I was sewing the other day and the needle came down on one of the pins in my fabric, thus causing the message, "main motor blocked". I cleared out the broken needle and tangled thread, and tried to resume sewing. It would not sew stitches correctly. That is when I removed everyting I could to see inside where the bobbin hook passes the needle. They were WAY off. The nearest service center is over an hour away, and I don't have the time or money. I planned to make lace covers for ornaments to give as gifts this year. Please help.
  • 1 more comment
  • spsmith52 Dec 15, 2008
    i have the ame problem with a brother PE170d. need help fast
  • kathleen282 Dec 21, 2008
    Now, if I had a diagram of my machine showing me exactly where the set screws are and the gears I would be set. Thank you for your directions. I did find them helpful, but I need the extra step of diagrams.
  • Anonymous Apr 01, 2009
    what kind of pre-wound bobbins will work in my pfaff 2170?
  • 202 Answers
Basically on any sewing machine to time it you will need to separate the two gears that drive the hook. Usually loosen the set screws that attach the gear to the shaft and separate them.
Time the hook first. On center needle position, set the hook so that the point is behind the needle when the needle bar has risen about 2.5mm.
2) Set the needle bar height. Choose the needle position which is the last for the hook to pass.
(Left on most machines, right on older Vikings) At this point, place the point of the hook behind
the needle and set the needle bar height so that top of the eye is just barely below the tip of the
hook.
3) Check feed timing. Set the stitch length to the longest stitch. The needle should enter the
fabric just as the teeth drop below the surface of the plate.
Posted on Dec 20, 2008
Hobby 307 schematic for parts
You probably need to request an assembly diagram directly from Pfaff.
May 29, 2017 | PfaFF Sewing Machines
I have a pfaff 907 machine that will not pick up the bobbin thread &It gets stuck. I have oiled &cleaned it & have followed the directions.
If you haven't already, try a brand new needle. If it is still a problem, most likely the machine is out of time. Search for sewing machine timing or take it for service.
Jan 25, 2017 | PfaFF Sewing Machines
Timing PFAFF 1222SE timing
Have you tried a brand new needle and checked to make sure it is the correct needle and installed facing the proper direction? If you've done all that, then it is most likely a needle/hook timing issue. Probably need to take it for service.
Apr 06, 2016 | PfaFF Sewing Machines
How do you reset timing on Pfaff Creative 7570 Machine? Was sewing and heard loud pop, now will not work. Any ideas?
Hi Lisa,
"A loud pop" whilst sewing sounds as though a capacitor has blown probably in the power supply unit. I'd recommend that you take your machine to a Pfaff service shop to have it serviced.
To reset the timing on a sewing machine is a specialist job. To give you an idea of what it entails on a mechanical machine (your machine is electromechanical) have a look at this video
Good luck :)
Jun 21, 2015 | PfaFF Creative 7570
Can't open Pfaff Select 3.0 Sewing Machine to fix timing
I found an electric drill with a hex bit and that did the trick!
Dec 30, 2008 | Sewing Machines
Pfaff sewing machine hobby 850? from 1986...
Try installing a brand new needle. A bent/dull needle will frequently not pick up the bobbin thread.
If a new needle doesn't help, then most likely the machine has been knocked out of time (the needle and hook are out of sync). You can search for sewing machine timing to see if you want to try to fix it yourself or take it for service. Timing is usually affected when a needle hits something hard (like a pin, the needleplate or a hard seam of fabric) and is deflected
Jan 04, 2018 | Sewing Machines
Sewing Machines Logo
756 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
