Question about Fantom Titanium Hard Drive
Yellow light? My hard drive is about a year old now and this morning when I went to turn it on, the drive would not boot itself up. The light came on but it was yellow, or more like red and green on at the same time. I tried it a few minutes ago and it ended up working but I've been worrying all day. I have 140 Gb worth of important video files on this drive and I'm afraid this might happen again and not fix itself. Has anyone else had this problem? is there a way to fix it? or should I start saving up for a new hard drive and keep my old one running until then?
  • Trevor Rocco Mar 16, 2007
    Thank you for the advice Tim. I always try to do those things but programs and computers are not always cooperating. I will continue to try and save my files in more than one place.
    Thanks again,
    -Tre
    Novelist:
    Champion:
  • 202 Answers
Tre, save early, save often, save many. I have seen, heard and experienced external hard drives failing. It is a good habit to use the "usb device safe removal tool" the green arrow on the task bar. When the device is safely removed, turn it off. When you need the drive again...turn it on save files, safely remove device, turn it off. Sometimes the turning on and off of the computer with the drive hooked up can cause issues over time. Anyway hope that helps. Good Luck. Tim
Posted on Mar 15, 2007
Toshiba 46 inch regza yellow light blinks and picture wont come on but I have full audio
Most likely the power supply board needs to be replaced. It could also be the T-con board or less likely the display itself.
If you don't know what you're doing, DON'T OPEN THE TV UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE TV IS UNPLUGGED!
If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
Sep 21, 2016 | Toshiba Televison & Video
PS3 yellow lights won't turn on
You may have the yellow light of death. You get the yellow light of death when the playstation stays on too long or alot of use or it may taken some damage.
May 09, 2013 | Sony Playstation 3 (PS3) Console
Dell optiplex gx 620 powere went out last night and this morning it won't turn on. The only light I see is on the motherboard and its solid yellow
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
hope this helps you
Nov 30, 2011 | Dell OptiPlex GX620 PC Desktop
When i put my samsung g3 station 2 TB on my pc, my pc will not boot.. When i look it up in de BIOS the C:\ is not available.. that why it cant boot.. it does not see the normal HDD. how can i solf this...
My desktop has a 6 year-old motherboard which will not start up if the external USB HDD is turned on. So I have to make sure the HDD is off before turning on the PC in the morning. After it starts booting I can turn on the HDD and everything works fine.
Does your machine work this way?
Mar 12, 2011 | Samsung G3 Station 1.5TB USB 2.0 External...
Compaq Evo N600c Laptop over 5 years old but has been working fine. About 2 months ago the screen went dark (bad lamp?) so been using an external monitor. Turned it on this morning and it started to boot...
Do you see any lights on the laptop that are on? If you see any lights and only a black screen, then more than likely your video chip on the motherboard has gone out. Some local shops might be able to replace the motherboard it might be cheaper than buying a new laptop. Good luck
Feb 25, 2011 | Compaq Evo N600C PC Notebook
Computer turns on, fan works, yellow light on power button and yellow light on monitor. No picture
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/boot
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 18, 2010 | Dell Studio Slim-Tower Desktop Computer
Dell XPS 600 turns itself on to solid amber
Hi. the mother board seems to be having some initialization issues during boot up. this is common when the mother board is failing. i would check to make sure the battery on this board is working. if it is, the board my be ruined.
power board seems to be fine.
please rate and god bless.
Mar 17, 2009 | Dell XPS 600 PC Desktop
La cie hard drive mount issues
I had the same problem and surprisingly, after many attempts to get the drive to mount with different connections, etc., the problem turned out to be the power adapter. If you've got the same kind of adapter on another drive, switch it out and see if your drive shows up. Good luck.
Nov 09, 2008 | LaCie Big Disk Extreme with Triple...
Toshiba Satellite L25-S119 No boot
reset bios to default try installing fresh system
Jan 10, 2008 | Toshiba Satellite L25-S119 Notebook
I think that this disk has some bade sector ,try to make a complete scan of tis hard drive by this command "CHKDSK /p /r" to repair this bad sectors and repartitioning this hard drive. some time the reason of this problem is file system of this hard drive is not correct.
Jun 14, 2007 | LaCie Bigger Disk Extreme (300789) 2000 GB
Fantom Titanium Hard Drive Logo
90 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
