Question about KitchenAid K45SS Classic Stand Mixer
The kitchenaide mixer mixer head wont turn - KitchenAid K45SS Classic Stand Mixer
  • Len Mar 14, 2009
    I have a similar problem.
    The BLADE sometimes does not rotate although the motor runs and the head rotates perfectly.
    I am sure there is a broken tooth in the gears between the head and blade and looking for part ID info.
    If the motor runs but the head is not rotating for you, I would look at the gear between the motor & head.
  • 906 Answers
Good day,
hope this link below will solve your problem.
kitchen
Posted on Aug 02, 2010
  • 153 Answers
There must be something in that clean it carefully
Posted on Jul 22, 2009
Kitchenaid stand mixer motor head fell off
You didn't say which model KitchenAid mixer you have. Assuming that it is a tilt-head, and that the metal portion of the motor housing joining it to the base did not break, the Service Manual can be had at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Apr 16, 2017 | KitchenAid Food Mixers
Kitchenaid mixer wont turn on
There are different answers depending upon which model KitchenAid mixer you have. Please be more specific.
Jul 20, 2014 | KitchenAid Food Mixers
Kitchenaid mixer K45SS only has one speed, slow. Have taken apart and regreased the machine. I plugged it in while the planetary head was off and it went through the speeds as normal, but as soon as
Did you clean the are around the variable-speed control lever?
Please be sure to unplug the mixer BEFORE disassembling the mixer.
http://www.ereplacementparts.com/kitchenaid-k45sswh0-classic-stand-mixer-parts-c-114958_114959_115060.html?page=4
http://www.ereplacementparts.com/article/11983/How_to_Replace_the_Speed_Sensor_and_Control_Board_on_a_KitchenAid_Pro_6_Mixer.html
Jan 07, 2014 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid wont start
The possible problems could be in no real order>>>
1. your power outlet in your house
2 the power cord to the mixer broken or shorted
3 the speed control plate inside the mixer needs adjusting or replaced
4 the carbon brushes inside the motor head of the mixer need replaced
5 the armature a motor part
6 the stator a motor part
The first four are easy fixes the last two will require a full tear down. but there are lots of things to test first. let us know.
Feb 22, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Brand New Kitchenaid Artisan Mixer - Mixer head is stuck
Unplug the mixer, turn the whisk the opposite of normal rotation in a quick motion, the remove a per normal.
Feb 19, 2010 | KitchenAid KSM150PS Artisan Series Stand...
I have a Kitchenaid Professional 5 Plus Mixer beaters won't turn
It sounds like it has been overloaded and the worm gear has been stripped. You will need to take the head apart to confirm this.
Jun 24, 2009 | KitchenAid K45SS Classic Stand Mixer
4 1/2 quart kitchenaid mixer head jumps when mixing
Adjusting the screw didn't work for me the first time I tried it.  I was afraid of loosening the screw too much, and so I didn't turn it far enough.  Turning the screw counter-clockwise until it stuck out several millimeters finally worked.
Mar 15, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer switch is locked
If this is a 325 watt Artisan, there is no safety switch I know of unless its in the circuit board. Your mixer is broke.
Mar 01, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid mixer races when turned on
Hi. Get in touch with Kitchenaid Parts and order a new Control Board. If your mixer is still covered by warranty it's free. ricardok45
Dec 23, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid Classic -Mixer Head wobbles or shakes back and forth
Lay the mixer on its side and look up through the base. You willnotice a small set screw. This holds the pin tight. If the set screw gets loose the pin willl begin to move out and the head will wobble. Simply tighten the set screw. I just did this to my Kitchenaid mixer 10 minutes ago and it now works fine.
Oct 29, 2008 | Food Mixers
KitchenAid K45SS Classic Stand Mixer Logo
88 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
