Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Helpme i have a panasonic cinemavision hdtv projection 2002 tv..my problem is that my tv dont turn on at all...when i push the power button ,dont turn on just a red blinking light show for ever..
  • 1 more comment
  • fantomaas
    fantomaas Dec 18, 2008
    When  I turn it on it turns for 3-4 seconds then off and red light begins to blink. I checked at D-Board (Npth0371) ferrite Beads (L-505, L506, L-510, L-511) they were smoked I mean they were maybe overheated and burned and now I plan to change them,  $ 1.95 a piece in online ordering. What do you think the problem is? let me knowi would very appreciate it !   autocars4u@aim.com
  • scottnorman Jan 04, 2009
    43 inch rear pojection panasonic tv. red light blinks three times when turned on
  • kamcauley Jan 06, 2009
    My panasonic PT53tw53 tv is on, then just shuts off-red light blinks "forever", until I disconnect TV. I then reconnect, turn tv on...OK for a couple of minutes(solid red light), then bingo!!, black screen again, accompanied by the flashing red light again-weird thing is that tv can be OK for 2 days, three, then it goes....now it's 5 mins or so then it's gone...any advice??
  • Panasonic Master
  • 5,138 Answers
Replace Both of your convergence ICs they are big black ics STK392-110? use 180s .
Posted on Dec 27, 2008
My 51" Panasonic CinemaVision rear-projection HDTV
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Aug 12, 2013 | Televison & Video
Problem with Panasonic PT-53WX54J 53 in. Rear Projection HDTV Television - Green Screen
You may have a component failing in the red drive stage possibly the blue as well or even the quadrature stage. A can of cold shot should help narrow the search considerably. It is also possible the red and blue projection tubes are nearing the end of their service life as well. If you have the means to test the tubes themselves, check the red and blue tubes for gas.
Dec 19, 2011 | Panasonic Televison & Video
There is no picture. When it is turned on the
the convergence circuits have failed. You can get the convergence repair kit for your model at www.tvrepairworld.com the kit contains the parts and the Cd with instructions
Jan 15, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic CinemaVision PT-47WX53G : half the screen is distorted
did you try to try to adjust the vertical and the horizontal of your tv?
Oct 05, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic cinemavision hdtv 1080i projection TV. Is this tv digital? how does one access the digital aspect?
go to this link for the manual.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=d17d8491251fb501911086409da7f697&modelid=275504&q=Panasonic+PT-47WX49
Jun 11, 2009 | Panasonic PT-47WX49 47" Rear Projection...
My Panasonic CinemaVision 47" won't turn on.
Thats the error for the convergence. The following repair kit will usually repair that. The kit contains the parts and instructions with pictures on how to do the repair. Heres a link to the kit for your model. http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
May 17, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic cinemavision pt-53wx54j
if the led is blinking one time its the 140 volt circuit. If its blinking a series of 3 blinks its the convergence circuit
Feb 15, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-53WX53 cinemavision HDTV keeps powering off right away
5 blinks is telling you that IC4511 on the DG board is faulty. This is not serviceable you will need a new DG board the part number of that board is TNP2AA126
Mar 25, 2008 | Televison & Video
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
230 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
