Question about Whirlpool Duet GHW9150P Front Load Washer
Front load Whirlpool Duet
Washer was in spin mode and went off balance. The door came open and we did everything, Unplugged and then held the cycle off for 5 seconds. The door now will not close at all. It seems to have sprung something. Help
  • Donna McCooey Mar 15, 2007
    No the door catch is still there. It may be the door lock as you can hold the door with your knee and the washer will work.
    I found the part, but I don't know how difficult it will be to replace. It is called a door lock assembly.
    Do you know if it is difficult to replace?
    Thanks,
  • Anonymous Feb 09, 2009
    duet washer door will not close
    Problem Solver:
  • 16 Answers
Hi, Has the door catch,which protrudes and goes into the hole, broken off, it should have a sort of hooked end. Tom.
Posted on Mar 15, 2007
  • Tom Mercer Mar 16, 2007
    Usually when the door is closed the door catch holds it shut with the hooked end, then when the washer is switched on to start, the door interlock locks the catch in place so that the door can't be opened. If there is no hooked end on the catch it might have broken off and so not keeping the door shut. If you are certain it is alright then the interlock is usually accessed by removing the top cover. There should be 2 screws holding the plate where the door catch goes in, on the outside, and when this plate is removed there are 2 more screws holding the interlock to the front.
    MAKE SURE THE PLUG IS TAKEN OUT OF THE SOCKET BEFORE YOU DO ANYTHING. Tom
SOURCE:
Whirlpool trouble shooting
All Spin cycles regardless of load or even when unloaded and spinning?
If so suspension is broken.........Technician repair only, even the balance weights in the tub are too heavy for DIY to remove and replace springs
Sep 07, 2014 | Whirlpool WFW9550WW Duet 27" 4.4 cu. ft....
Whirlpool duet ghw9200lw front load washer will not start cycle
Check the door interlock on the washing machine. If it's faulty, the machine won't start its cycle. This page will give you an idea of what interlocks look like.
Door Interlocks
Feb 20, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Spin light is flashing 1min left in cycle door
Take the bottom panel off. The tech sheet is right there. While at it clean out the pump filter.
Interesting home videos
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not open, drain or spin.
if the error code is SE it needs 2 be manually drained
Apr 16, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
My washer is out of balance when spinning.
Your problem is probably much more than the washer being out of balance. The front load washers have shock absorbers that hold them from moving all over the place. These have a habit of breaking. Then the drum hammers and sounds like things are flying apart. Pull the bottom front off and check the shocks. Typically the rings where the pins go throuhg are where they will break. Sometimes at first they look okay and you have to grab them and move them to see that they are broken.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Nov 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loading Washer Won't Turn On
MY WASHER WAS DOING BASICALLY THE SAME THING. I HAVE A WHIRLPOOL FRONT LOADER MODEL #GHW9460PL0. MY HUBBY REMOVED THE 3 SCREWS FROM THE BACK OF THE WASHER, UNPLUG IT FIRST, AND TOOK THE TOP OFF. WE THEN CAREFULLY UNPLUG THE WIRES AND REPLUGGED THEM BACK IN 1 BY 1 SO U WONT GET THEM MIXED UP. WE THEN TRYED IT, AND THE CONTROL LOCKED LITE STAYED LIT. HE HELD THE SIGNAL CYCLE BUTTON IN FOR 3 SECONDS AND THE LIGHT WENT OUT. WE THEN TRYED RUNNING A CYCLE AND SO FAR SO GOOD!! GOOD LUCK!
May 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet stuck on spin cycle
Press 'end of cycle' for over 3 seconds. Perhaps you have to check your filter, maybe clogged.
Feb 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Off-Balance Duet Washer
spin basket surport is defective..put unit in spin without clothes do it bang and clang,,sound like train ,or airplane,,if so contact whirlpool your under warrranty for spin basket..onthejob
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door on washer will not open
Select Drain/Spin to remove any water remaining in the washer. The washer door wil unlock at the end of the spin.The washer door will not unlock if the unit has not drained.
Nov 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
221 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
