Question about Fahrenheat FBE15002 Baseboard Heater
I have a Fahrenheat model f2516 120v and a double pole thermostat
How do i hook up the thermostat? i tried and no power was coming out the other side of the tstat. should his be a single pole?
hotuna
  • 288 Answers
SOURCE: Electric baseboard heater
You need a meter, it will be hard without this! If you have 220v in the wall, then think of it like this; each wire is 120v. Test to each other, you get 220v. The thermostat is a double pole, you said. So think of it like this, its an adjustable temperature controlled switch that lets electricity through at the temp. you set it at. If you have 120v from one wire connected to one end of the element, and the other 120v connected to the other end of the element, then it will work. DO NOT CONNECT THE 120V TOGETHER. IT MUST GO THROUGH THE ELEMENT FIRST. The thermostat should be between the power from the wall and the element, to control the temperature.
Posted on Jan 09, 2008
hotuna
  • 288 Answers
SOURCE: How do I wire up a F2544 baseboard heater with a single pole themostat
It sounds like you are not getting the correct voltage for the heating element. If you wired a single pole thermostat, and its a 220v unit, then it will not get hot enough, like you are saying. If its a 220 heater, you need a 2p2t thermostat. The parts supplier will know what this means.
Posted on Mar 20, 2008
  • 92 Answers
SOURCE: dimplex baseboard heater wiring
no does not matter but you must have a ground leg
Posted on Feb 24, 2009
  • 55 Answers
SOURCE: hooking up the thermostat
Thermostats are typically low voltage only no more than 24volts that is supplied from the transformer in your heating unit. you need to look at your low voltage wiring that is in the furnace and write down the terminals that are hooked up. Usually (this is a very typical set up) red wire goes to R which supplies 24 volts. green goes to G powers fan motor, white to W terminal and blue or yellow goes to Y terminal this terminal will usually have another wire in its terminal with it to control an outdoor ac unit likely another red or white wire, and lastly the C terminal has a white wire. That is for a basic heating and cooling system just match how they are hooked up at the main unit to the terminals on your thermostat. the thermostat is just a switch breaking and connecting terminals that allow voltage to carry through it. Shut down your unit while working on it as not to blow the transformer otherwise you are gonna need to replace it to if it isnt fused, that is probably my most common repair from people who have tried to change their own thermostat. Hope this helps
Posted on Sep 21, 2009
shastalaker7
  • 1515 Answers
SOURCE: i am trying to install a fahrenheat f2543 heater
Hi, this is very easy for you to do.The 12/2 Romex wire coming in is the power which you know. What you do need to know, is the voltage coming in? Sometimes they will use 12/2 Romex with ground for 220, 240, operation. You need to know if the T-stat is Line voltage 220, or 240 volt. You have to have the same voltage for both for it to control. Reguardless of the voltage, lets say it is in the 220 and up range. You take one of the 12/2 wires, white or black and hook it to the black or red on the T-stat and the white to the other one, red or black. Thats it, you are done! If the T-stat is 2-pole I am sure it is a high, Line votage T-stat. Best of Luck,
Shastalaker7
Posted on Nov 22, 2009
Bought a Fahrenheat 5' baseboard heater and a single pole thermostat to replace an old heater. What's the difference between a single and double pole thermostat? Which should I use? I have a 240v line...
Here is a link to the wiring instructions, which has detailed pictures and instructions. This should make it a lot easier. http://www.marleymep.com/en/multimedia-library/pdf/fahrenheat-pdf/products/f2500-series/F2500wiring.pdf
Feb 14, 2011 | Fahrenheat F2545 Electric Baseboard Heater
What thermostat do I use for a model f2546nwc heater where the thermostat is mounted on the heater
u have to use a double pole thermostat...u can find it a homedepot...it has 4 wires- 2 red and 2 blacks..i just installed mine on 11/7/10...
Nov 04, 2010 | Fahrenheat Electric Convector Baseboard...
I am trying to install a fahrenheat f2543 heater with a fta2a double pole thermostat. there is a 12/2 wire coming into where the heater is being installed. how do i connect the red and black to the white...
Shastalaker7
Nov 09, 2009 | Fahrenheat Built-In Baseboard Thermostat...
Hooking up the thermostat
Sep 20, 2009 | Fahrenheat Electric Hydronic Baseboard...
Dimplex baseboard heater wiring
Jan 05, 2009 | Fahrenheat Electric Convector Baseboard...
Mar 17, 2008 | Fahrenheat Electric Convector Baseboard...
Jan 05, 2008 | Fahrenheat FBE15002 Baseboard Heater
Fahrenheat FBE15002 Baseboard Heater Logo
205 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
