Question about Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES just hums when you start it... doesn't turn
I just finished drying a load of laundry, and then the next load wouldn't turn.  There's just a humming noise.  All of the controls light up. There may be a coin trapped inside one of the inside 'spokes'.
What is your thought?
Thanks in advance for any advice.
  • ross790587 Dec 15, 2008
    I have the same exact problem
  • mkellyf Jan 01, 2009
    Thanks jtbjtb.... The clogged blower was the answer for now, but the motor may be the issue down the road.
    Thanks again.
    K
  • 135 Answers
Unfortunately, this is probably a bad motor, part # 131560100. It retails for $129 but can be found for around $100 shipped online. You can inspect for a clogged blower first by removing the front panel.
Posted on Dec 31, 2008
Frigidaire dryer dries for a few seconds then stops and lights blink.
Hi laylabetes - Answering your question, there isn't a way to actually CLEAN the control panel. Depending on an actual diagnose from a professional, the part would need replacing or if possible repair. However, if your model is electric, turns and there is no heat, it could possibly be a blown fuse. There are two house fuses that supply voltage to your dryer circuit in your fuse box. If one of the two is blown, the dryer may turn but will not heat. Check and replace fuse in fuse box if necessary. Please feel free to reconnect if this does not resolve your issue - Best, Chris
Jul 01, 2013 | Frigidaire Dryers
End of cycle keeps beeping even after clothes are finished and removed
this could range from a simple processor hanging problem to a defective pcb
please start from a hard reset by leaving the unit plugged off from wall power for one night
Jul 30, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire Affinity Front Load Washer wont drain.
If your pump had something in it, it wouldn't have had to clog it, but rather just stopped the internal spinning. My coworker removed a dollar bill from his water pump, and it fixed the problem he was having (same as you've described) and the water pump worked well after it was re-installed.
Worst case scenario, you reinstall it and it doesn't drain and you spend 40 or 50 bucks online for the part. I would reinstall and see if it works. I'd bet on it.
Nov 14, 2012 | Frigidaire Affinity ATF7000ES Front Load...
I have a frigidaire gallery electric dryer. It was working fine for the load of laundry I had in it, then I put the next load in and turned the start button and all I get is a hum. It seems to be sending...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 16, 2011 | Frigidaire GLER331A Electric Dryer
My dryer worked fine i checked some clothes to see if they were dry so i went ot turn it back on and all it will do is hum
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 04, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Noisy Frigidaire Electric Dryer
Here is a tip that I wrote that will give you somethings to check out...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Apr 03, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Dryer won't start
If you are getting s slight HUM when you press the start button,your motor is experiencing some problems. If you do not hear a hum, and after letting the dryer cool down for several hours, it suddenly works again, your motor has an internal short and is shutting itself down via the internal overload. If there is no hum of any kind, even after letting it cool off for a long time, then either there has been a failure of a part in the line such as the door interlock switch, the timer contact or there is a thermal overload in the back of the dryer, down by the blower, it is white in color and it has probably opened up.
Dec 14, 2008 | Roper Dryers
Frigidaire GLEQ2152ES Electric Dryer Logo
138 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
