Toshiba 36A42 36" TV, had for six years.
Turned it yesterday, nothing happened.
You could hear the sound like it wants to
start. But all I get is blinking red light.
Be greatful for help. Thank you
A common cause is a failure in the one of the scan amplifiers or on the high voltage section. It is also possible to have a power supply fault that will give this error message.
This WAS happening imtermittently, 'til NOW. I've replaced the remote and changed the batteries, and...
(More)
This WAS happening imtermittently, 'til NOW. I've replaced the remote and changed the batteries, and "most" of the time it performed OK, for the first week, affter I replaced the remote (w/new batteries). I can perform all of the functions via the front TV panel, but NOT with the remote. I went to the TOSHIBA web-site support, and "it" asked me: "Is the remote reset procedure accurate?" I cannot find anyplace in the manual "where" the remote 'reset procedure' and it's 'accuracy' is mentioned/explained. 'Might be my problem? 'HOPE SO! HELP!
I have Toshiba 36A42 that works great.... for an hour and a half or so. Then it starts turning...
(More)
I have Toshiba 36A42 that works great.... for an hour and a half or so. Then it starts turning itself on and off and while on the volume jumps up super loud and then back down. What would cause this? And where can I find parts? Right after I got this tv used last year, it stopped turning on altogether. A repairman friend replaced the entire computer board, and it worked great for about a month until this started happening. Would I figure the board to be faulty, or would something else be causing this issue? Thanks for any help you can provide. ---Dave
While watching our regular Dish programing, overlap menues automatically scroll onto the screen and...
(More)
While watching our regular Dish programing, overlap menues automatically scroll onto the screen and do not respond to the remote or manual adjustments on the tv. Also, after a while the screen will go totally black and we shut it off.
the toshiba/36a443 make on 2004 since the customer had along time now happens. every 15 or 1/2 hrs...
(More)
THE TOSHIBA/36A443 MAKE ON 2004 SINCE THE CUSTOMER HAD ALONG TIME NOW HAPPENS. EVERY 15 OR 1/2 HRS SHUTDOWN THEN I ASKED THE CUSTOMER TO UNPLUG THE TV FOR 15 MINUTE OR HAFT HRS THEN PLUG BACK WORK FOR 2HRS THEN SHUTDOWN AGAIN. FINALLY, I GOT PICK-UP TO THE SHOW I TOOK THE COVER ON THE BACK OUT THEN I TROUBLSHOOTING FOUD THE POWERSUPPLY PB PROBLEM ALSO I CHECK THE DRIVER CIRCUIT FOUND A FEW CAPS, TWO DIODE AND IC INTERMITTANT POWERSURGE TO PROTECT MODE.
AFTER I DID REPALCE THESE COMPONENTS THE 36A443 WORK FINE.
WU
