Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Did you get your tv fixed?
I think I am having the same exact problem. I got the tv for free and can't afford to sink a lo9t of money into right now. DId you get yours fixed and how much did it cost?
  • Henry McKelvey
    Henry McKelvey May 11, 2010
    Hello deanoswaino,
    Can you tell me what problem you are experiencing with your TV? The problem is you have replied to an issue without stating the issue to which you are replying to, and your request is going unanswered,. So if you can reply to this posting with your trouble I might be able to help you.
    Thank you,
    Shuttle83
    http://www.electron-age-technologies-llc...
  • RCA Master
  • 5,138 Answers
That TV sold for 900.00 and up 1400.00 if you just have the 3 caps bad cost of repair 235.00
Posted on Dec 25, 2008
Tuning the carb
You can't figure out the EXACT settings without some equipment. If you can't afford to get the equipment and the training necessary, and you can't afford to get it fixed, dont mess with it.
Don't get mad, get it fixed by a pro or be prepared to be stuck or walk.
If it ain't broke don't try to fix it.
Feb 28, 2013 | 2002 Suzuki LS 650 Savage
I can't afford to pay $38.00 to fix the errors on my PC.How else can it be fixed? Nancy Reyes
If you are talking about registry errors, go to download.com, and type registry cleaners, there are a lot of free software out there with list of choices.
Mar 12, 2012 | Computers & Internet
I had the free trial virsion of ms office and i bought the upgrad key and i removed the free trial thinking i would have to install the real version but i can;t find a link to install it again. Please help...
Hey if you want to install the ms office you can download it by visiting the Microsoft download center or you can download the free trial and then activate it by putting the activation code.
If you want to use a software exactly same as ms office with all same features for free you dont have to spend a single penny you can download open office by visiting openoffice.org its completely free, if you wish you can cancel your order and save money.
If you need any other help or any problem please reply i will be glad to help you.
Mar 20, 2010 | Computers & Internet
Hitachi FDX Series 43FDX10B; some double/color problems,no remote
I am the right person for your problem--
If model number is 43fdx01b it uses two convergence chips--you are going to need to get your hands on a Hitachi remote if you do this repair.
If picture looks 3D, double image one or both of the two chips it uses for convergence is bad.
With the set unplugged and the back removed look on the far right side of the set---two versions of this set---one has a circuit board on the far right side about 5 inches wide and 12 inches deep--the chips will be on the large metal heat sink with fins on the far right side----look at the chips.
They are black in color and 2 1/2 inches wide and 1 1/2 inches tall with 18 pins each---They will most likely have the STK-392-120 NUMBER printed on each in white.
If you have this version the board is held in by 3 screws---you snap up a row of black plugs on the left side and several other plugs on that board have to be removed--if you do it---mark all the plugs so you get them back exactly where they came from.
Good news: total parts cost aside from a remote should be under 20 dollars---verify the number on the chips and I can tell you the best place to buy them.
There are about 12 resistors to the left of the heat sink that need to be looked at and tested--like checking a fuse.
Any resistor that is discolored in the middle or reads open needs to be replaced at the same time.
You might want to go to the house where you found the set and ask them for the remote--nothing to lose.
If you think you can solder etc and do this repair I will give you further specific instructions---this set is very easy to fix for this CONVERGENCE problem---
If you have more time than money--this is a very good TV--and this is about the only problem it ever has.
I am here to help---rate this solution if it helped you- I do this here for free.
I will follow thru with any help or questions you have even after you rate the solution.
I am here to help people.
SD TECH
Nov 01, 2009 | Hitachi FDX Series 43FDX10B 43" Rear...
My 50v710 will not power up at all. it does not even go into the diagnostic mode to give me a code thru the led's on the front. The bulb is good and the two safty switchs that are behind the bulb and at...
Sounds like you may have a bad power supply board. You can find a service manual at http://www.techlore.com/. Go about half way down the page and to the right and I think it says get manuals. Click on that and I think they have a free one. You may have to join the site to get it be its free to join. Hope this is helpful.
Sep 28, 2009 | Hitachi 50V710 50" Rear Projection...
Put in new lamp for Vivitek DLP and picture flashes
I just posted the following to someone else, since I think these problems are related.
I had a similar problem.
My TV started to flicker and I put a new bulb in. The new bulb did not help, even if it is good to replace after a couple thousand hours.
I found out that my heat sink, which is sitting on the CPU with the mirrors came loose and the unit overheated and shut off after flickering a while.
Try to take the lower back panel off and you see a heat sink which is sitting in the center of a aluminum sheet metal piece. Disconnect the wires which are attached to the circuit board behind the sheet metal. Then take off the screws holding the sheet metal and pull it gently off. It will take a little force, but it does not damage anything. Now you see the heat sink on the circuit board held by a latch going across the heat sink.
On the upper right corner you will find the handle to open the latch. Once you did it , you can take the heat sink off and see the main CPU (as I took the latch off, my heat sink fell off).
On my heat sink the Heat Sink Compound Paste creating the connection between the CPU and the heat sink dried out and became brittle, son there was no connection anymore and the heat couldn’t be transported out through the heat sink, which is cooled by a fan on the left.
I took the brittle Heat Sink Compound Paste off and applied a generous portion of the one that I bought at Radio Shack. I used a Silicone-Base Heat Sink Compound which ran $4.99 excl. tax.
After applying the paste put the heat sink gently in and when you do, you will feel like a suction indicating that you have a connection between the CPU and the heat sink.
Now you need to put all parts back together.
If you are not familiar with electronics and those wires or wouldn’t hurt or would be wise to mark the connectors and to make pictures before removing them. This will save you a lot of frustration.
I hope this helps you and brings your TV back to life. My TV was cutting out after 25 minutes and runs now like a charm.
Good luck.
PS: If you experience a black screen with vertical stripes (mine were white and green) then most likely the light engine needs to be replaced, I had this after 9 months and got it fixed under warranty
Jun 30, 2009 | Vivitek V37655 56" DLP TV
Random black bar
that bar is a menace to clear. somtimes manufactures put problems in so when you tell them the problem they know what to do this is how they make money
Apr 23, 2009 | Panasonic TH-46PZ800U Plasma TV
Sony projection tv
Fisrt off think of the age of the set. and then ask yourself do you really want to start sinking money into such an old unit? My advice, free as it may be, save your money for a new set. These older sets can be regretably costly to repair. Be warned.
C-Dog
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Panasonic rear projection TV 47 in PT 47WX49
Camaroguy: This exact problem happened to us about 8 months ago. A board had to be replaced at a cost of $500. Yesterday, the convergence has gone on the set. You get a blue and yellow shadow on the picture. From what I have been reading, this has happened on a few TVs and it will cost another $500 or so. We refuse to pour more money down the drain so we just went out and bought a new plasma (RCA) for half what it cost us for the Panasonic 4 years ago. We have never had a problem with RCA in the past (two tvs for 20 years a piece).
Mar 22, 2007 | Panasonic PT-47WX49 47" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
21 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
