Question about Video Cameras
The camcorder fell ,shows only black and white inthe view finder
The camcorder fell , it will not show pictures on the screen, it shows only black and white in the view finder. Can I have it fixed or up graded?
the model is the super vhs 400x zoom.
If I can have it fixed I would like to , can it be upgraded? it is in excellent condition it was only used once, but I have had it now for over 5 years it is still new.
    Scholar:
  • 61 Answers
What has happened is that one of your cabels has come disconnected in the accent. A solder job would fix this, but it is likely with the cost of todays cameras for the price of the repair, you should go out and buy a new camera instead. Super V is a good looking picture but can't compare to the High Def cameras that are out today. You will be very happy with the results of taping resolution from one of these. Infact, there are some great HD cameras that record directly to Hard Drive, thus saving you on tape costs for the rest of your life. So, one could say that the camera eventually pays for itself since you won't ever have to buy tapes for it! (Make sure that the HD conversion from camera to your computer is compatiable and there are no issues with it... Do a google search on your new model before you buy it, as some have issues with transfers to different Operating systems).
Posted on Dec 14, 2008
View finder on my Sony HVR-Z5U isn't working, I can film through the flip out screen, but unable to use the eye piece view finder
POSSIBLY THE RIBBON CABLE THAT RUNS FROM THE EVF (VIEWFINDER) TO THE MAIN PROCESS BOARD SHOULD SWITCH REFERENCE TO EVF WHEN LCD PANEL MONITOR IS CLOSED REGARDS JOHN
www.jvsvisual.com
Mar 14, 2013 | Sony HVR-Z5U High Definition DV Camcorder
Rca540 camcorder will not show tape in eye pc unit runs but no picture in view finder
Is there a eletrical board that controls the opening & closing of the lens in front of the camcorder?
Aug 29, 2012 | RCA Pro Edit Camcorder Model Cc540
No picture shows up on the screen nor in the view finder when I turn on my Sony camcorder model hdr sr11.thank you.
If the issue persists even after performing allthe above-mentioned steps, service is required.
Jan 01, 2011 | Sony HDR-SR11 Flash Media Camcorder
How do I get the sony handycam dcr-hc30ntsc to show me a pictuer wale recording or any thing
If camcorder does not show live view in view finder and lcd screen but shows good picture in play back of old recorded tapes then ccd imager chip is defective in camcorder and need to be replaced.
It is not user level repair as soldering work is needed to replace ccd imager chip.
Let me know if you have additional question.
Thanks.
Oct 18, 2010 | Sony Handycam DCR-HC30 Mini DV Digital...
Viewfinder and LCD screen only show black and record black
If camcorder shows old recorded tapes picture with correct colors in LCD but does not show live view in camera mode to record new movie then its ccd imager chip failure.
And if camcoder shows live view and old recorded tapes in its eye piece view finder but does not show any thing in LCD the its problem of broekn/ cracked flexible wire between lcd board and main board of camcorder.
Let me know your finding with bit detail to provide you solution/ helpful info.
Nov 18, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
When I turn my camera on and try to record, nothing shows up on the screen.
Make sure lens cover is open, if still camcorder does not show live view then it is bad ccd imager chip problem that will be replaced.
Let me know exact model of your Sony camcorder to provide you part number info of ccd imager chip.
Thanks.
Sep 24, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
Dvx100a showing black screens on lcd screen and view finder
You probably have the lens cap on, the iris dial closed, or you are in vcr mode rather than camera mode. You may also have the nd filter set to 1/64th, this is only for bright sunlight. When shooting indoors with low light, set the nd filter to off and hit the iris button until iris manual appears on the lcd, then dial the iris dial in front of the iris button up or down to bring the iris to around 5.6 f stop.
Feb 26, 2009 | Panasonic AG-DVX100 Mini DV Digital...
Distorted picture when looking through view finder or lcd screen
the video playback is sampled off the video out and independently processed sorta like a TV signal to project on the lcd screen.
horizontal lines means you lost sync circuit and needs troubleshooting. Hopefully maybe a bad connection with a ribbon cable for the ICs and components are hard to change and jammed tight. I would order a video board.
May 14, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
NO picture - JVC GR D74
JVC GR-DVL9500
Error Code E04 when I load a tape .
Oct 04, 2007 | Video Cameras
Gr-dvx7 jvc lcd screen is just white?
If the view finder shows the same white display. You probably have display circuit problem in the camera. Faulty CCD chip usually shows Black screen so it probably board problem or a connector problem. If you see an image through view finder then you may have defective connection from board to LCD assy. Either way it need to be looked at by a trained technician. Good luck.
Mar 17, 2007 | JVC GR-DVX7 Mini DV Digital Camcorder
Video Cameras Logo
176 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
