Question about Crystal Decisions NISSAN SKYLINE GTR R32
Need to dismantle rear outer CV Joint
Need a diagram for a R33 Nissan Skyline CV joint Rear Outer
  • 32 Answers
Hope this helps
Posted on Aug 17, 2009
Can't budge outer cv joint Mazda MPV 1991
the outer cv joint is separable
you have to take the complete drive shaft out of the vehicle first to do it
It is not a simple process to break the joint down and you will need mechanical skill, a good off set vice and a heavy hammer
it is more cost effective and less frustrating to simply have drive line specialists replace the shaft for you
Aug 01, 2016 | Mazda Cars & Trucks
What tools are needed to chang rear cv joint in a 2002 mercury mountaineer
Basic tools..remove wheel, remove axle nut, remove brake caliper, remove lower control arm bolts,remove the bolt for upper control arm, remove the outer tie rod bolt, support vehicle and suspension, the hardest part is getting the axle out of the rear diff, sometimes a simple pry bar will pop it out, but I've run into a lot where you either need the special pickle fork or even have to remove the complete rear diff with axle still attached, remove cover and take out c clip.if you continue prying and hammering between inner cv joint and diff, you will cause damage to diff.the cv joint is steel, cast maybe, and diff is aluminum so guess what will be damaged first? That'll lead into a pretty expensive repair.the special tool to remove axle is 205-529
Mar 01, 2014 | Cars & Trucks
I have a golf gti automatic. It makes a grinding when comming to stop and when frewheeling at low speed. i've checked brake pads and there fine
cv joint going bad, grease and boot may fix, probably caused by a cracked cv boot, and now the grease is gone, first thing to check is the boot on the cv joint (that's the shaft/joint that turns the wheels)attatches by a single nut in center of your front wheel (outer joint) if not the outer, then ck the inner (attatches to the transmission) (inner joint). most likely is the outer joint though
Sep 04, 2012 | Volkswagen GTI Cars & Trucks
When makeing a left turn clicking.
this is the sign of a failing outer CV joint in the drive shaft. look under car at driveshaft. the rubber boot around CV joint is probably torn. This allows lube to fling out and water to come in, contaminating the CV joint. Replace the entire drive shaft instead of replacing only the outer CV joint.
Nov 11, 2010 | 1994 Plymouth Voyager
Cv joint but the plastic thang that go around it
One would have to remove the half shaft to service the cv joint properly.
Oct 08, 2010 | 2004 Oldsmobile Alero
How do you replace cv boot on 2004 yamaha big bear?
remove upper and lower ball joints and tie rod. remove backing plate. hold on to axel and pull hard and quickly. inner joint will pop out of differential. hold axel in vise .if replacing outer cv boot you must first remove inner boot. remove boot clamps first on inner boot. pull boot back out of the way. hook and remove clip on inside of cv joint outer cup about 3/16 of an inch in. pull joint apart. remove grease at end of shaft to find snap ring clip. remove clip. pull off joint and remove boot. outer cv joint does not come apart.
Nov 21, 2009 | Yamaha G5 Motorcycles
Need to change cv outer boot on mazda ba 94 model.
it just pulls out. it hasa circlip that holds it in on driver side. which side?
here's an escort, should be similar. note step 17
Removal
  1. Raise and support the vehicle.
  1. Remove the lug nuts (1012) and the front wheel and tire assembly.
  1. Remove the front fender splash shield bolts and the front fender splash shields (16103) .
  1. Use a small cape chisel to carefully raise the staked portion of the front axle wheel hub retainer (3B477).
  1. Remove the front axle wheel hub retainer and discard it.
  1. Remove the cotter pin and the tie rod end nut from the tie rod end (3A130). Discard the cotter pin.
  1. Use an appropriate tie rod end remover to separate the tie rod end from the front wheel knuckle (3K186).
  1. Remove the ball joint bolt and the ball joint bolt nut.
  1. Carefully pry down on the front suspension lower arm (3078) to separate the front suspension lower arm ball joint (3050) from the front wheel knuckle.
  1. Pull outward on the front wheel knuckle (3K185). Carefully pull the front wheel driveshaft and joint from the front wheel knuckle and position it aside.
  1. NOTE: Removal of the LH front wheel driveshaft and joint (3B437) requires removal of the transmission support crossmember (6A023) to allow access with a pry bar. If the LH front wheel driveshaft and joint is being removed, continue with step 11. If the RH front wheel driveshaft and joint is being removed, continue with step 15.
    Support the transaxle with a transaxle jack or equivalent.
  1. Remove the four transaxle mount-to-rear engine support nuts.
  1. Remove the two rear engine support nuts at the rear of the transmission support crossmember.
  1. While supporting the rear of the transmission support crossmember remove the two rear engine support bolts. Remove the transmission support crossmember.
  1. Position a drain pan under the transaxle.
  1. Insert a pry bar between the front wheel driveshaft and joint and the transaxle case.
  1. stf~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Extreme care must be taken to ensure that the pry bar does not damage the transaxle case, the transaxle oil seal, the front wheel driveshaft and joint, or the front wheel driveshaft joint boot (3A331).
    Gently pry outward to release the front wheel driveshaft and joint from the differential side gears (4236).
  1. Remove the front wheel driveshaft and joint.
  1. stf~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: When the LH and RH front wheel driveshaft and joint assemblies are removed, Transaxle Plugs T88C-7025-AH must be inserted to prevent the differential side gears from becoming mispositioned. If the gears become misaligned, the differential will have to be removed from the transaxle to align the gears.
    If both front wheel driveshaft and joints were removed, install Transaxle Plugs T88C-7025-AH in the differential side gears.
  1. Remove and discard the driveshaft bearing retainer circlip (3Z498).
Oct 03, 2009 | 1994 Mazda 323
02yukon i cannot get the cv joint out from the wheel/brake assem
Remove steering joint.Then bottom ball joint then you should be ok.
Jul 13, 2009 | 2001 GMC Yukon
Cv boot clamp came off somehow from the outer hub assembly
athere is a snap ring within the CV joint the nedds to be spread OPEN to release CV joint from axle, Once CV is cleaned and repacked with grease rintall onto axle by again spreading apart clamp. Prior to installing CV joint slide NEW CV joint boot onto axle, Cleanly intall add'l grrease and reinstall CV boot.
Apr 04, 2009 | 1996 Buick Century
Crystal Decisions NISSAN SKYLINE GTR R32 Logo
636 people viewed this question
Top Crystal Decisions Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Crystal Decisions Toy Expert? Answer questions, earn points and help others
