Question about Cell Phones
Have a sgh f200 screen keeps going white no display hyave to remove battery to reset phone
    Sergeant:
  • 306 Answers
The prob is surely  with the battery.. try to change it else contact a service center..
Posted on Dec 14, 2008
How do i fix my msung SGH-T410G the screen
You need to go to service to replace LCD
Sep 18, 2017 | Samsung Cell Phones
Fit new screen was working fine now ipod touch 4th generation stuck on white screen but is still working only screen is white
The display being white can be due to failure of the LCD.So to confirm remove battery and reset. It can also be a fault on the linking cable or the control board.
Remove the battery and keep the phone aside to reset and try as a last resort.If not the LCD display could be faulty. Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Thank You for using fixya
Aug 09, 2011 | Cell Phones
I want samsung sgh b210 reset code
To perform a hard-reset to factory original settings dial:
*2767*3855#
If you need a password default should be:
00000000
BTW, this site is very good if you need further info:
http://forum.gsmhosting.com/vbb/f200/all-samsung-hard-reset-codes-588846/
May 03, 2011 | Samsung SCREEN PROTECTOR MEXXPROTECT...
My samsung sgh e490 has a constant white display
The reason your phones has a constant white display is simply because there is a problem with the flex of the phone.
If the screen is not damaged in any way, then the assumption of it being the screen is absolutely correct.
To fix the flex of the phone;
1. Get the appropriate screwdriver,
2. remove the battery, the battery cover, and your sim,
3. Turn the back of the phone,
4. you will see five rubbers,
5. pick them off with a pincher,you will see screws under them, unscrew the phone,
6. Get a credit card and slip it through the line around the phone then apply a little force in separating them apart,
7. you will see the panel of the phone, carefully lift it up,
8. you will see a flex that runs through the screen to the panel, carefully detach the flex from the panel,
9. unscrew the screen of the phone, remove the flex connected to the screen also and replace it.
10. Reverse the process to reassemble the phone.
And also it might be a damage LCD (glass screen) ,
defective display driver (small chips that makes the display works)
and the other one is corrupted software...in damage LCD the phone will detected
Take care
Sep 14, 2010 | Samsung SGH-E490 Tri-band Phone
My samsung gravity screen is white, when its on you can only dial a phone number and call but the screen is still white no matter what. ive turned the phone off took out the battery, but it still doesnt...
The problem with your phone screen is that the screen of your phone is bad that is why your phone screen is white.
All you need to do now is to get a brand new screen on your phone and you will see that your phone screen will start to display.
I advice you go with the phone while going to get the screen in other to get a the exact screen and a working screen.
Replace the screen of your phone and your phone screen will start to display.
Take care.
May 16, 2010 | Samsung Gravity SGH-T459 Cell Phone
Samsung SGH-a727: LCD display is blank (white) on the left 20% of the screen. The rest of the screen is very faded with vertical streaks through it. What's up? It hasn't been dropped or otherwise damaged.
The screen of your phone as started malfunctioning.
It is possible that you hit it on a hard surface. all the same, it also possible that the screen is not well tighten to the panel of your phone.
Get a torx 6 screw driver, switch off the phone,remove the battery cover of your phone,the battery and sim card. turn the phone over and remove the front casing of your phone, use the torx 6 screw driver to tighten up all the screws on the screen to the panel very well and couple back yor phone.
Put back the sim and battery and switch on, if the screen did not still display, it means the screen of your phone is bad.
The problem is the screen, the screen is faulty and will need to be replace if you want it to display back as you use to have it.
All you will need to do is to get a get a brand new screen on your phone and i advice you go with the phone in other to get the exact screen and a working screen.
Take care.
May 03, 2010 | Samsung SGH-a727 Cellular Phone
White screen on the sgh e250
have you tried to remove the batteries of the phone? if u already did the phone needs service.
Jul 02, 2009 | Samsung SGH-E900 Cellular Phone
Cell Phones Logo
51 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
