Question about Baby Gear
How to solve EpsonR250 Error No E-91 ?
    President:
  • 373 Answers
E-91 code means that the "Waste Ink Pad",which soaks up all the normally wasted ink from Head cleaning, etc. is saturated and needs replacing with new one. You cannot do it yourself, as it need resetting the printer sensors, and you'll have to have the printer serviced by an service engineer. Search Google for "Epson printer service" for nearest service shop near where you live. Hope this helps, but it will cost money.
Posted on Dec 14, 2008
Why is code 91 on screen?
About 1,080,000 results (0.79 seconds) Search Results
    Chevy Cruze error code 91 - Fixya
    www.fixya.com/cars/t18378173-chevy_cruze_error_code_91
    Jun 2, 2013 - Chevy Cruze error code 91 What is Error code 91? It appeared ... Ya i know that what is error code 91 it is that ur car key is not there & if shows error code35 then ur car remote key cell losing his power exchange with that cell & ur car is ok. Posted on ... SOURCE: chevrolet cruze 2.0 LT 163cv error. If im not ...
    Warning: Cruze Start/Stop button & Immobiliser Design Flaw ...
    gearheads.in > Forum > Indian Automotive Scene > Chevrolet > Cruze
    Apr 16, 2013 - 10 posts - ‎7 authors
    4kms later I realised that I had the Cruze key with me in my pocket ... If the key is outside the car and you try to start it, it throws a Code 91 Error ...
    Cruze error code ' Chevy Cruze Blog : Chevrolet Cruze Blog
    www.cruzeblog.com/cruze-error-code/
    Translate this page Mar 7, 2014 - Cruze Error Code Vehicle message 1 C
Feb 09, 2016 | Chevrolet Cruze Cars & Trucks
Sharp mxm 550 u code u-2 91
try removing memory see if it goes away, if yes replaced memory.
remove, turn off put back in turn on see if it comes back
U2-91 PCU section memory sum check error Crop 16
Apr 08, 2014 | Sharp Office Equipment & Supplies
Frigidaire oven error code
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuosly runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
Accessories For Audi
Jun 12, 2012 | Ovens
E:91:01, no flash
Hello! Welcome to FixYa!
Error E:91:01 is usually comes in Sony Cyber Shot Cameras
To solve this first of all Turn OFF the camera and Remove the battery or the power supply. Now turn the switch to camera for about 30 sec and Turn the switch to OFF. Now Install the battery or power supply and turn the switch to memory. Open the LCD cover and press the RESET button ( small inner button ).You will be prompt to adjust date/time. Set it and now take some pictures.
I hope error will not come but if you still face it then best option is to take it back where you purchased it or contact Sony service center about the error code.They will surely solve it.
I hope this solution helps you.
Thank you for using FixYa, Keep Visiting!
Sep 12, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
DSC-W30 digicam... my flash does not work and screen flashes E:91:01 with flash symbol..
E:91:01 is an error code that indicates that flash circuit board is not working and need to be replaced to solve the problem.
Let me know if you need part number of flash circuit board.
Jul 09, 2011 | Sony Cyber-shot DSC-W30 Digital Camera
Kettler Treadmill TX 3 gives error 91 supplier told it was the Power supply print. We changed it including the motor and the problem was solved for a couple of weeks. Now it is back again? Please...
Problem with Trendmil TX-3 err-91 problem is solved ... speed sensor (photo transistro in photo cell is damaged).The palsis in colector is 5V Amplitud .
Apr 05, 2011 | Kettler TX3 Folding Treadmill
What do i do if the error message on my camera appears? (E:91:01) then suddenly spark..,i wonder if it a short circuit or the bulb must be replace?i need some help please..,
TO SOLVE FLASH ERROR sony cyber shot ERROR CODE E:91:01 , JUST GO TO SETUP MENU, SELECT THE TOOLBOX ICON 1 AND SELECT """"INITIALIZE"""" CLICK OK, MASTER RESET AND IT GOES BACK TO NORMAL. NOTE: DOWNLOAD & SAVE PICTURES BEFORE MASTER RESET AND KNOW THAT YOU WILL HAVE TO SET UP TIME&DATE.
Jan 24, 2011 | Sony Cyber-shot DSC-H10/B Digital Camera
Camera is flashing "E:91:01" ON THE SCREEN. WHY?
The flash fuse on the main board or flash board is bad. Contact your local Sony service center for repair as this is possibly a short circuit problem but first try this......
I found a forum that talks about your error. Here is a quote from the forum:
TO SOLVE FLASH ERROR sony cybershot ERROR CODE E:91:01 , JUST GO TO SETUP MENU, SELECT THE TOOLBOX ICON 1 AND SELECT """"INITIALIZE"""" CLICK OK, MASTER RESET AND IT GOES BACK TO NORMAL.
please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
91-215 error code
91-215 is "communication error between system control and keyboard." could be a loose cable, open fuse, capacitor problem, etc.
Mar 20, 2009 | Sony DSR-1500 Mini DV VCR
W55 Flash dead, E:91:01
I googled this error and found a few relevant links:
http://forums.dpreview.com/forums/read.asp?forum=1009&message=20161066
http://www.fixya.com/support/t427780-e_91_01
Jul 25, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Baby Gear Logo
85 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
