Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Channel id keeps popping up
I have a sharp lcd tv. Every so often the channel id info square pops up on screen for no reason.
  • Anonymous Dec 19, 2008
    I have the same problem going on too. It's the LC-46SB540 model
5 Suggested Answers
BMW Rider
  • 232 Answers
SOURCE: LG 20LS7D flat panel LCD TV
Hi, go into your menu and turn off closed captioning, sometimes listed as "CC" instead of spelled out "closed captioning", this will fix ya, Happy Holidays, BMW Rider
Posted on Dec 01, 2007
  • 17 Answers
SOURCE: Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Posted on Dec 31, 2007
SOURCE: Black square box pops up in the middle of tv screen.
It is most likely related to the Closed Captioning option on your TV. Go into settings and make sure that CC is turned off, or make sure it's set to CC1. What you are probably seeing is the "text" option included in the CC options.
Posted on Feb 15, 2009
SOURCE: my sharp 32 lcd keep flashing the channel and audio mode
If your receiver came with audio video cables, hook them to your receiver and to either input 1 or 2 on you flat screen. These inputs support audio video. This will stop that annoying flashing between mono and stereo.
Posted on May 05, 2009
I get a black square in the middle of the tv. I can still see part of the program and hear it but there is a code or something that pops up it starts with lid and has numbers following. If I push the input...
U have the tv original remote wright?Yes.Used ur tv remote look for a button that said CC.Pushes a few times make sure all like CC1,2,3 so on to all off.The black square box show up in the middle of the tv screen,numbers and printting words on the screen it is are call Close Caption for the hearing impair person to read,will disappear from the middle of the tv screen.
Apr 04, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Audio keeps switching from mono to stereo
on every channel ? then av board is failing
on a single channel then it is their signal not you set
Nov 24, 2009 | Sharp LC-32SB21U 32 in. LCD TV
Feb 14, 2009 | Polaroid TLA-01511C 15 in. LCD Television
turn off the closed captions - you have it in text mode that will have a big black box with video on the sides
thanks
scott
Feb 14, 2009 | Polaroid LCD-1700 17 in. Television
A "Critique show" text message keeps popping up
This is definitely not a Sharp Aquos feature. Any show related functions come from Dish Network. It might be a channel specific function which the Dish Network support staff does not know how to deal with.
Jan 31, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp lc-26sh10u intermitent problem
its a motherboard problem. i got one for sale or you can sell me the tv cause mine has a broken screen
Dec 25, 2008 | Sharp LC-26SH10U 26 in. LCD Television
Display box keeps popping on and off on screen
Your display box continues to pop up because of the way your optimum box is connected to the back of your television. If you are connected with a coaxial cable from the box to the back of the tv, you will get that display box. The reason you are getting it because of the weak signal coming from your coaxial cable(which is the worst cable to use when connecting ANYTHING to ANY tv, especially a lcd tv). That cable is sending a fluctuating signal and your television is adjusting to that(hence the reason the display box comes up). Use composite cables(typical red, white, and yellow cables) to connect your box to your television and I guarantee your problem will be solved. Make sure you unplug that coaxial connection from your box to the television.
Dec 08, 2008 | Sharp Aquos LC-32D40U Television
The channel information/display won't stop popping up every few seconds.
What you all need to do is get away from a coax cable connection. If you have a cable box, or satellite box, take the coax cable off and use red, white, n yellow rca composite cables to connect your recievers to the tv. if you dont have a cable box, either get one, or get a converter box and use a tuner outside of the tuner within the unit. The tuners in those tv's are built to show you when you experience signal fluctation(which is normal with a coax cable) and thats why the box keeps popping up on its own. good louck to you all with this problem
Nov 02, 2008 | Sharp LC-32SB24U 32 in. LCD TV
Sharp LCD model LC-26SH12U
I just purchased this TV and when I changed the channel a black box pops up in the middle of the screen, I have to press the freeze button twice in order to take it off. How do I keep it off permenately
Jan 21, 2008 | Toshiba 19A26 19" TV
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
238 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
