Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
How to work my thermostat
I need instructions for my thermostat.Its a focuspro 5000 series.How does it work? Do I leave the fan ON ore put it on AUTO??
  • 108 Answers
Fan switch should be on auto in the heating mode and on in cooling. Contact the manufactuer on line for a new manual for this thermostat.
Ray
Posted on Dec 14, 2008
How do I program a Honeywell FocusPRO 6000 Thermostat?
You can find the installation set up just goggle the model and put pdf in the search. If you paid the plumber to install it he should come back at no charge if he is not going to and it's been less then 30 days he is probably not a good plumber and could have completely screwed things up so changing settings may or may not solve the problem.
Oct 05, 2014 | Honeywell Focuspro 6000 Prog. Multistage...
I took my Honeywell focuspro 5000 non programmable thermostat off the wall to change the batteries and I put new batteries in it and back on the wall and now my air conditioner wont come on do you kno
I can only suggest that you check and make sure all of the pins are straight and not bent over from trying to align the back plate with the back of the thermostat. Ive done it and its easy to do if you are not very carefull.
Sep 19, 2014 | Honeywell TH5110D1006 Focus PRO 5000...
Honeywell TH5110D1006 FocusPRO NonProgrammable Thermostat Is there any trick that can make it so I can keep a child from messing with the thermostat Anything even if its just disabling to buttons We leave...
I believe you can set a range stop in installer mode, the instructions are here but if you have difficulty ask your installer as if you don't know what you are doing you could stop your system working by changing the wrong settings in installer mode.
https://customer.honeywell.com/resources/Techlit/TechLitDocuments/69-0000s/69-2021ES.pdf
Apr 02, 2014 | Heating & Cooling
FocusPro TH5000 will not cool
Make sure the thermostat is set to "cool" mode. Make sure the thermostat is wired correctly and has fresh batteries in it. Check both the thermostat end and the air handler end of the wires. If All this checks out, the problem is most likely in the air conditioner, not the thermostat.
Mar 29, 2014 | Honeywell TH5220D1003 FocusPRO 5000...
I was moving thermostat about 15 inches,the only problem I didn't shut the power off. I think I might have shorted something out. It was a honeywell focuspro thermostat 5000 series, controlling a gibson...
if you have a meter on the indoor unit locate the transformer and check to see if getting 24v ac on the secondary side the primary side should be 220 most of the time their is only one of the wires that would of causes a short red to common the rest just transfer voltage to make the circuit some boards have a 5 amp fuse that will blow and some transformers have a reset button on the 5000 stat make sure that you are putting the wires in correct slots due to having two configurations conventional and heat pump
May 16, 2009 | Honeywell Focus 6300B 5-2 Days...
Thermostat not shutting off heat.
has the thermostat been programed to tell it what type of system you are using. If you look in the papper work you should find where it ells you to hold down the button lower left and top right button i think those are the two i don't have the papper work with me right now but i can get if you need more information on how to set it
Jan 21, 2009 | Honeywell Programmable Thermostat Heater
A/C Problems
SOUNDS LIKE THERMOSTAT IS NOT SET UP CORRECTLY THE HAVE TO BE PROGRAMED TO YOU UNIT
Aug 28, 2008 | Honeywell Electronic Programmable...
Compressor shuts down when warm outside
make sure you provide shade for your unit. It may help keeping it cool.
Aug 27, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
374 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
