Question about Epson Stylus Photo 1290 InkJet Printer
Repacing the color inks with black ink on the epson 1290
Would anyone know if you would get reasonable black and white prints by refilling the color inks with only black inks (using the new blank/empty cartriges you can now purchase). Would this eliminate the color casts you get using the color inks for black and white prints or would it be more sensible to just use the black single ink cartridge ? I have a spare 1290 that I replaced with a 1410 and thought I would experiment wiyh the blacks on the 1290.. Thanks for any help...Laurie
  • oldfirie Dec 15, 2008
    Hi Carl, I have been using "select black ink only" but I was interested to find out what would happen if I filled the blank/empty five ink colour cartridge with all black ink. Hmmmmmmmm!! might try it and see what happens...Regards Laurie
  • Carl Gehrke
    Carl Gehrke May 11, 2010
    Why not just select black ink only in the properties part of the print dialog?
    Carl
  • 169 Answers
Well, since you say you'll be using new cartridges you shouldn't have any nozzle problems. About the worst case I can see would be the slight chance of getting too much ink on the paper resulting in wet paper and a stained platten roller. Seems like an interesting experiment over all.
Nozzle problems arise when reusing cartridges. The very thin metal film that is the nozzle assembly gets worn down as the print head moves over paper and after a number of pages printed the little holes that are the nozzles get larger making for fuzzy, wetter than it should be, streaky printing.
Enjoy,
Carl
Posted on Dec 15, 2008
Only want to use blkac ink only
When you want to print a page whether its a word page or any webpage as you give that print command before printing you will find many options in the left hand side like Destination,pages,layout,COLOR,margins options, So before printing the page you can easily check in the "black and white" option and it will simply print in black.
If the information helped you then please give me some ratings.Thankx
May 25, 2012 | Epson Stylus 680 InkJet Color Printer
How to refill ink cartridge of Epson me32?
Follow these steps:
1.
Buy an Epson ink refill kit. A refill kit gives you all the tools you need to refill Epson ink cartridges. Kits typically include a syringe, rivets, ink, and instructions on how to refill the cartridge. You can find Epson ink refill kits on the Printer Filling Station along with instructions for each specific model (see Resources).
2.
Cover your workspace with a paper towel and fill up the syringe with the ink color you need. Epson refill kits will either include black ink or the color combination cyan, yellow and magenta. On average, you'll need 10 ml of black ink or 5 ml of color ink for Epson ink cartridges.
3.
Find the rubber seals on the back of the Epson ink cartridge. Insert the rivets into each seal.
4.
Empty the contents of the syringe into the Epson ink cartridge. You'll want to perform this action slowly in order to avoid spilling or overfilling the cartridge.
5.
Remove the rivets. Use tape to cover the holes you made in the ink cartridge. Return the ink cartridge to the printer. Allow the printer to go through several print cycles in order to ensure that the Epson printer operates properly.
In case of any additional help please revert back
Jun 12, 2011 | Office Equipment & Supplies
Why can't I print black and white, without colored ink?
I have the same problem & have been searching for weeks for a replacement printer that will print B & W with one or more colors empty. I haven't had any luck yet - I did run across a post that said: For black and white images and photos, a blend of colors called "composite black" may be used to achieve significantly better image quality and smoother gray tones than can be accomplished with black inks alone. I'm still searching...
Jul 28, 2010 | Epson Stylus CX5000 InkJet Photo Printer
Hi, when printing the page is full black. After head clean, nozzle check etc still black & nozzle check prints two x dark lines. I changed ink cartridges but no improvement. Thanks, Roger
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 06, 2010 | Epson Stylus Photo 1290 InkJet Printer
Epson C60 Stylus Status Monitor Does Not Work On Windows Vista
I ve been having the same problem with my Epson 1290 and Windows Vista! It works fine but I cant get the status info on my ink levels. Its so annoying when u run out of ink the LED on the printer goes on but you dont know whick cartridges to replace! I hope Microsoft and Epson get this sorted out because it so annoying and I end up spending more money on inks than needed! I read someone had similar problem, installed the 1290 M driver (via Vistas set drivers) but it didnt work for me!
any other suggestions?
Apr 18, 2008 | Epson Stylus Photo 1290 InkJet Printer
Printing in black & white when color cartridge ran out
One of the possible reason why you can't print black in white because Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. More than that Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head.
Apr 15, 2008 | Epson Stylus Photo 1280 InkJet Printer
Black Won't print on my 1290
I have had these issues before (that's why I never use refill carts anymore: false economy) You'll just have to keep running the clean cycle until it goes through. This may take several tries, and will waste tons of ink - hence the false economy of refills!
Feb 12, 2008 | Epson Stylus Photo 1290 InkJet Printer
Epson C66 won't print without color cartidges
epson printers won't really print if one cartridge is not detected or detected as empty. the only option that i can suggest to you is that, buy a continous ink kit at any ink refilling station in your place. i highly recommend that dont leave a cartridge empty with ink cause it might clog your printhead. using a continous ink system's cartridge is auto reset, whenever the printer says that the cartridge is empty, it will automatically resets itself. ink refill kit comes with 100+ml of ink per color i think. and it is much cheaper using original epson ink.
Sep 26, 2007 | Epson Stylus C66 Inkjet Printer
I had the same problem. Had no choice but to buy the colors I ran out to make the printer work. In order to avoid future problems and save on color inked I attempted to follow the steps of a previous posting, however, that did not work for me. This is what I had did. Print, select properties, advance, continue, check box - Black ink only. Remember when you decide to print in color you must reset your setting and take out the check from the - Black ink only.
Sep 08, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus Photo 1290 InkJet Printer Logo
117 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
