Question about Maytag PAV2300 Top Load Washer
Maytag PAV2300AWW Washer leaks while filling
We just bought a used Maytag washer and my husband hooked it up tonight. When we did a test run (just filling it with water empty), the water immediately went out of the tub and onto the floor. Does anyone have any idea what could be the problem here? My husband did use the water hoses from our old washer instead of the ones that were on the this one originally, but that was the only thing we changed. Thanks in advance for your help!
  • 1 more comment
  • kimberly93 Dec 15, 2008
    We used the ones from the old machine because they were almost new (we had changed them out). My husband found the problem yesterday after he opened up the machine. (We found excellent directions on how to do this and what to look for from this website http://www.applianceaid.com/). The hose that goes from the pump to the basket had somehow fell off and he had to reattach it. The machine is running well now and hopefully for many years to come. Thanks for your help and hope this helps others as well. :)
  • sdsat Mar 11, 2009
    when the machine is filling it leaks out from the outer ring that goes around tub.
  • 750 Answers
Hello
Welcome to Fixya
My name is Huum,
Why did you change the hoses with old ones?
If you are going to change them use new ones!
Sounds like the drain hose connection to the washer is not tight or not secured, or not fitting th connection because it is from a different washing machine.
Or there is a hole in the inner tub and leaking out on the floor.
Do you know the ones that sold it to you?
Thank You For trusting us with your question
Please remember to leave a rating before you leave!
Posted on Dec 15, 2008
Our Maytag PAV2300AWW Performa top load washer fills with water fine, draisn fine, spins fine, but after filling with water (even on "Mini" size load) it begins to agitate and then quits completely and...
If it was the bearing it should be leaking water out the bottom! It is more than likely the water pump. The seal in the pump drops down and then makes noise. The pump should be in rear. tilt machine back remove belt then try turning the pump by hand if tight replace.
List price is about $89.99 you can find it on Ebay cheaper
Jul 05, 2014 | Maytag PAV2300 Top Load Washer
Clothes Washer stopped running. I have a Maytag PAV2300AWW clothes washer that was mistaken ran with a full load on the small load setting and stopped working mid cycle. Any help with the cause and
first check the house breaker and make sure you still have power. If it does then I would unplug the machine and lean it back against the wall to look at the motor wiring harness underneath to see if it came loose or is wet.
Mar 31, 2012 | Maytag PAV2300 Top Load Washer
My washer fills with water and keeps filling doesn't stop on the selected water level for the load. It doesn't wash because the water keeps filling. What's wrong with my washer? Help please (Maytag...
The problem is simple and easy to fix. Your washer has a tubing which runs from the base of the tub to the water pressure switch. It might have vibrated loose from the switch, or their can be some sediment in the tub. Blow out the tubing and reattach it securely to the switch and pump out the water in the tub. Then try it again. I wrote an article about this:
Help my washer is overflowing !!!
Jan 07, 2011 | Maytag PAV2300 Top Load Washer
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Spin Cycle is slow
new belt or there is a thrust bearing above the drive pulley that wears out.
May 22, 2010 | Maytag PAV2300 Top Load Washer
Leaking when turning on cold line
1. replace the water mixing valv.
2. will be fixed when you replace the valve.
3. standpipe drain is clogged. snake it out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Maytag PAV2300 Top Load Washer
Cold water inlet on maytag top load washer not working
switch the hoses fill hoses and if no hot enters you have a defective inlet vavle,,replace...onthejob
Jan 13, 2009 | Maytag PAV2300 Top Load Washer
Washer won't stop filling with water
In yor machine control panel you have A part called a pressure switch or water level switch. that controls the water level and tells the timer to start aggitating .If the part is bad the machine will over fill and keep running the water!!
Sep 01, 2008 | Maytag PAV2300 Top Load Washer
Maytag Neptune Leaking Water
pull the frount panael at the bottom and look there early model neptunes would leak around the door seal they made a kit to fix them but i dont know how old yours is so i cant tell you if thats it check the obvious hoses etc your drain pipe could be cloged the one your drain hose goes down in and just barley running over when the washer drains tell your husband to fill it then then switch to drain and listen to the pipe will sound like a bottle filling up when it drains or he will see it running over while it fills look under the bottom panel for leaks hope that helps
Dec 27, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Does not spin
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Sep 24, 2007 | Maytag PAV2300 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
285 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
