Question about RIM BlackBerry Pearl 8100
My blackberry scroll key not working
Blackberry 8100 scroll key notworking
  • 2 more comments
  • baparungo Dec 31, 2008
    same scroll problem
  • Anonymous Jan 07, 2009
    my trackball works only in one direction.... it works fine in the sub menus.. but not in the main menus...
    thats really weird **** from blackberry... i dont get... y they have give this kind of track ball and also there is no other option, if you trackball once stops working....u are gone....
  • Anonymous Mar 23, 2009
    My scroll key on scrolls down and left to right.. but not up and right to left..
    :S
    i hate htis
  • raijee Apr 27, 2009
    first i got problem with silver ring out side the ball, its clip break down. i fixed it permanently with glue, now i have problem with scroll ball, i cant move it down. and can not remove silver ring. give me suggestion
I just fixed mine trackball which can only move in the vertical direction. By removing the silver cover (there are three small clips that hold it in place), the trackball and its enclosure will fall out. Carefully remove the white plastic cover (there are 2 clips that hold them in place) on the other side of the enclosure. Take out all 4 cylinders (4 magnet at the end) with tweezer and clean thoroughly. The 4 cylinders got clog with lint and dirt which prevent the ball in contact with the cylinder. This will solve your problem.
Posted on Feb 18, 2009
  • 502 Answers
Pry off the silver ring with a flathead screwdriver and take out the trackball. Clean the little black rubber cylinders on the bottom of the trackball with alcohol. That may be enough to be up and running again. There are also blackberry repair services that can replace the trackball for you or blackberry repair guides that show you how to replace the trackball in more detail.
Posted on Feb 03, 2009
I had the same problem. The way to fix this is my removing the siler ring and taking out the scroll, in the scroll there are little metal skrews, remove those and there will be alot of dust that the scroll has swept up. Clean that out and it should work, if not I suggest you buy a new one... Good luck
Posted on Dec 07, 2010
  • 113 Answers
You can find Video Disassembly Instructions at
www.fonlogix.us
They have New Trackballs for the cheapest price.
Here is a Coupon code for 10% off at their site
Code: Fixya10
Posted on Jan 31, 2009
    Problem Solver:
  • 9 Answers
Try removing the silver cover around the scroll ball, and remove the ball. There should be a little white square underneath it. If there is no white square, but a red square, then it could be water damage. I had the same issue with mine.
Posted on Dec 15, 2008
The blackberry bold trackball will not work when scrolling down
  • Go to main menu
  • Go to Options.
  • Select the Screen and key board.
  • Scroll down and Select Horizantal and Vertical sensitivity to 100.
    I hope you can fix this issue by doing this
Oct 18, 2009 | RIM BlackBerry Pearl 8100
5 keys doesn't work in my Blackberry 8100 pl. help
I had this same problem. It has probably gotten wet, or the wiring is shorting out. You probably need to get a new phone.
Jul 06, 2009 | RIM BlackBerry Pearl 8100
Mms not on my new blackberry 8100
First, ensure you have full data service showing on your blackberry 8900.
May need to check with your service provider to put on the proper data feature(s).
Then, on the device it’s self: press the Right Convenience key on the side. Frame the subject, Press the Trackball. Now, press the menu key Scroll down on the list to “send as MMS” You can now select a contact. (Either one in your contact list or a one time only) Press menu and continue. Scroll to subject. Enter that in. Scroll to message box. Enter in a cute little message. Press Menu key (once more!) and then SEND!
You’ll see arrows going back and furth.
For best results, send with +1_area code_number
If this is your first time sending MMS’s, send yourself TWO MMS’s with the same number format.
Aug 21, 2008 | RIM BlackBerry Pearl 8100
Blackberry 8100
Go to profiles; scroll down to advanced, and select. Select the profile you wish to edit, hit the menu key, and select edit. Click on sms text, then scroll to ring tone and click. Then scroll up and switch to browse. Select music or audio and select your song.
Mar 08, 2008 | RIM BlackBerry Pearl 8100
I NEED?
contact your service provider if you need to unlock the sim to use it with another carrier....it will take a few days to get the code back if they have tot contact the manufacterer....but you need the 16 diget code......after you get that, go to options, advanced options, sim card, type MEPPD. scroll to sim card, type MEP and pres the ALT key and then the 2 key.
if that doesnt work, instead of typing MEP2, try pressing and holding the ATL key and type MEPPE
if this works, a window will pop up asking for the unlock code....
Jan 01, 2008 | RIM BlackBerry Pearl 8100
Unlock Blackberry 8100 mobile
Dec 30, 2007 | RIM BlackBerry Pearl 8100
Unlock my phone
Dec 29, 2007 | RIM BlackBerry Pearl 8100
Unlock code
i want unlock code for 6500 nokia slide
Dec 27, 2007 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
11,328 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
