Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
I am trying to install a phillips apapter RF modular to a televison. I have no idea whether to hook it up to the cable box or the TV. To be honest am not sure where the input cords go. Phillips SWS2326W/17
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, the video (yellow) and audio (red & white) OUTPUTs of the cable box should go to the Video/Audio INPUTs of the RF Modulator. Thereafter, the TV should be set to Channel 3 (or whatever it is the RF Mod is using). This is done if and only if the TV has no A/V INPUTs and/or the cable box has no RF OUTPUT.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 14, 2008
I have a maganovox combo system, converter box, older model zenithe tv and rf modular. How do I connect all this to record and look at vcr on combo? I need step by step of hooking up all cords and plugs....
You dont need the rf modulator. Use a female to male rf, antenna cord and plug from the RF out on the back of your combo to the TV. Now you need to tune your TV on analogue mode until you find the dvd/vcr picture. Have the combo on when you're doing this.
Feb 19, 2014 | Televison & Video
How do i hook up my new cable box for descrambling to my vcr
If the cable box has audio and video outputs on it then use RCA type cables to connect the outputs of the cable box into the video and audio IN of the back of the VCR. Then select L1 on the VCR. If your TV has video and audio input connectors connect another set of cables form the VCR OUT to the IN puts of the TV, then select the AV inputs on the TV. If your TV doesn't have video and audio inputs, then use a coax cable from the RF/Antenna OUT of the VCR and connect it to the antenna jack on the TV. Now select 3or4 on the VCR to whatever works for your location and tune the TV to that same channel. That's it ...you now can watch and record the channel you're watching. You will have to have the VCR powered up all the time to watch TV
Jul 28, 2017 | Symphonic SL260A S-VHS VCR
I have an older TV with only an antenna hook-up, a VCR, a DVD recorder and a converter box that I would like to hook all together. I can get the VCR to work, but don't really know how to hook the DVD...
Try this. You will need 2 RF cables and a RCA cable that has a red, black, and yellow plug on each end.
  1. Plug the antenna signal into the converter box.
  2. Connect the RF output (TV out) of the converter box to the RF input on the VCR
  3. Connect the RF output (TV out) on the VCR to the TV
  4. Finally, plug the DVD recorder into the converter box also, but use the 3 RCA cables that came with it (audio left, right and video).
Apr 13, 2010 | iLO DVDR05 DVD Recorder
DTV hookup for an RCA XL-100 TV
Buy a box modulator which have RF input then have RCA output that's input to your TV or other option below.
Just click and choose whatever hooked up connection you want;
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ..
Plasma or Video Projector Wiring Guide
Blue-ray Surround Wiring
HP TVs - TV Cable and Connection Types
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Jan 07, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
I have a Pansonic TH-C42HD18 Plasma TV. It works fine when I play DVDs (through HDMI connection) and as well as you would expect watching VHS tapes through a composite connection. However, when watching...
You say you have switched AV cables. Have you tried switching input sockets as well? In other words, have you tried using the HDMI socket you normally use for DVD for the cable box input to watch TV? If so, does the problem stay with that input device or does the problem stay with the socket?
Also you say it doesn't matter "whether the cable is connected at all," but I'm not sure whether you mean the cable company cable or the (presumably) HDMI cable connecting the cable box to the TV. Can you clarify?
Mar 27, 2017 | Televison & Video
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
Trying to Install
Do you have the red, white and yellow hookups on the back of your TV????? If you don't then you need to get an RF Modulator. You can buy one at Walmart. Older TVs don't have the red, white and yellow hookups. You hook up the RF modulator with a short cable to the cable outlet on your TV. Then you plug in your DVD player to the RF modulator. You also plug your cable for the TV into the RF modulator. It really is very simple. Directions are included with the RF modulator. You will need a short piece of cable also.
Feb 04, 2008 | Panasonic DVD-RV41 DVD Player
Tuning in Akai Video
Please explain what you mean by "tuning in."  Are you referring to hooking up to your Television, or to a cable/satellite box?  Or can you not see video when you play a VCR.
Check your hookup cabling.  With a cable or satellite system, the VCR normally is hooked between the cable/sat receiver box and the TV.  Cable box RF output to VCR RF input, VCR RF output to TV RF input.
There are other possibilities when your TV has video or line inputs.
Oct 30, 2007 | JVC BR-S622DXU VHS / S-VHS playback VCR
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
61 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
