Question about ATN Aries 390 Paladin Weapon Sight
Nv sight dead
Hi there out shooting tonite and my scope just went black changed to new battery cross hairs light up but scope is pitch black even with illuminater on, help please sounds exspensive
No more lights steady type: Aries 390 Paladin, light guide only focus.
Posted on Nov 12, 2008
I shot my new 4.5x14x44mm conquest scope and tried to adjust the cross hairs according to my shots fired but the shots kept hitting in the same spot after a box of shells. i had it bore sited and i still...
Is the country of origin China.. Sounds like the reticle is stuck,, like from being dropped maybe in shipping. OK, Without any adjustments made shoot it one time, if you tap on the side of the scope, not the top of the turrets with a plastic/rubber hammer and point of impact changes (jumps) its faulty.. you cant fix it.
Feb 28, 2011 | Zeiss 4.5-14x44mm Conquest Target Rifle...
When I turn the turrets they go in the reverse direction, WHY
To raise the point of impact, turn the elevation screw counterclockwise. To shift left, turn windage screw clockwise. If you raise the horizontal cross hair you will lower the point of impact of the bullet. If you move the vertical cross hair to the right the shot placement will go to the left. Thats just the way it works. Point your right index finger at a spot on the wall, and sight down your finger like looking at sights, then take your left index finger and pretend it is a horizontal cross hair above your shooting finger, then raise your left finger a set amount above the right, then move your hands back to the shooting position not changing the distance in between, using your left finger now as the sight. You will see your shooting finger is now pointing lower than before. This is now the new point of impact, lower not higher. Hope this is clear as mud and helps Fix Ya up.
Dec 30, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Tasco Silver Antler .22 3-9X32 while shooting rifle, scope jumped off, remounted scope, now can not adjust cross hairs, can I fix this myself?
if the scope tok a hard smck when it jumped off the rail i would say its broke the adjusters in the scope,,they can jump off there mountings if hit hard getting it fixed will cost more that the scope is worth,, if it was my scope i would just bin it and but a new scope,,and not a tasco one!
Aug 26, 2010 | Tasco 3-9x32 .22 Riflescope W/ Rings,...
Parallax
What is out of focus? Your cross hairs or your whole picture? The parallax error is when you shift your head left, right, up, etc, the cross hairs stay on target. sometimes it will move with you and you will be off. But it shouldn't effect your site picture. You should still be able to see down range and the cross hairs should be in focus. Your rear most knob on the scope eyepiece will adjust to your vision. Mainly for the cross hairs though. I hope nothing broke loose in there to make it go out all at once. Hope this helps.
Mar 28, 2010 | Barska Optics Barska 10-40x50 Ao Varmint...
Will not illuminate
The battery is most likely dead, check your owner's manual for battery replacement instructions.
Dec 25, 2009 | Centerpoint Technologies CenterPoint AR22...
Not a problem but need operation instruction for my scope.Its a tasco pronghorn 3x9x40 with adjustable yardage and has two elavation cross hairs,I have had it for many years and it works perfect,but I have...
I believe the second cross hair in your scope relates to an 18 inch dimension, or that of a deer. When you adj the wire to the body of a deer, it will be the distance, I'm not sure if you have to do the math, or the scope does it for you. Some scopes, you had to figure the hold over by the distance in the scope. others would be set to shoot at that distance. I would ave to look that one for you to be sure, but that is the idea. Hope this helps.
Nov 11, 2009 | Tasco PH39X40D 3-9x40 Pronghorn Riflescope...
I am trying to bore sight a rifle with a center point 4x16x40 and i run out of adjustment to get the lazer to align with the cross hairs
When bore sighting you need to adjust in small steps and "TAP" the bore or the main body of your scope to cause a golt, as when shooting your gun it will kick and cause the scope cross hairs to take their set.  Tap it with a med sized screw driver handle. Make a small adjustment and tap it, adjust and tap.
Sep 23, 2009 | Centerpoint Technologies CenterPoint...
I have a Bushnell Elite 4200 6x24x40 rifle scope 42-6242M
First is to try for a group, do not adjust the scope in any way. Shoot 4 rounds with out adjusting the scope. The gun should settle down and start to group. If you can not get a group in 6 rounds go clean that gun & check your ammo. Start over. If she does not group, its the gun not the scope. Once it starts to group move the cross hairs in the opp direction small clicks and "TAP' the scope after each adjustment. Shoot for a group each time 2 rounds should group. Get a target that has a grid to help get on faster.
Sep 20, 2009 | Bushnell Elite 4200 6-24x40 Riflescope...
VX-III 1.75-6X32MM. While zeroing for the fist time, I had to adjust the scope up by 10 clicks because it was shooting low. After the first adjustment, it was still shooting low. When I went to adjust...
cross hairs stick some times try taping the top after each adjustment if that don't work turn your scope so the left to right adjustment is on top and use it to raise and lower point of aim.
Jul 10, 2009 | Optics
Cross hairs keep turning
I don't shoot BB guns, but I looked up your gun/scope combo. It' a $65 Chinese product. At this price level you cannot expect a decent scope or rifle. It just can't be done. The scope will not be worth fixing.
Nov 24, 2008 | Caliber Tech Force Pellet Rifle Model 34...
ATN Aries 390 Paladin Weapon Sight Logo
443 people viewed this question
Top ATN Optics Experts
Bill Boyd
Paul Woodward
Tony Parsons
Tony Parsons
Are you an ATN Optic Expert? Answer questions, earn points and help others
