The beeps are possibly post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off. make sure that your RAM modules and Cmos battery are securely seated on some motherboards Cmos batteries are soldered in Test all power and data leads that attach from motherboard to your hard drive IDE SATA make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40 pin ide it will be the first to fail check the graphics card is seated properly with no dust in the socket you might have to remove it to check for dust reinstall it restart your computer the found new hardware wizard should activate a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function
make sure all leads that are attached to your drives dvd\cd and floppy drive have secure make sure the connections and are not faulty or just replace them they could be faulty
a computer needs all electric current and computer data to travel to and through every working device and have an end to work properly so any faulty leads will end up with a computer error
also check the keyboard for secure dust free connection ps2 and or usb
hope this helps
SOURCE: no boot but a 5-second beep
sounds like your memory is messed up, try some different memory in your PC.
SOURCE: I use D101GGC motherboard with
This is a problem with the memory or motherboard. Troubleshoot the RAM first by cleanning the contacts or replacing with a good one followed by the display card and then the motherboard.
Testimonial: "Replaced my RAM and it worked. Thanks. My question is that "what are the possible reasons that can set RAM to go off."
