Refrigerators
Problem for Refrigerators
Generic problem for all Refrigerators
Frigidaire refrig stuck on crushed
By prpickard on Dec 14, 2008
frigidaire refrig stuck on crushed ice will not go back to cubed model #glhs268zds7
Best Solution
posted on Dec 14, 2008
Very Helpful)
RescueTech
Rank: Guru
Rating: 96%, 163 votes
A common problem on these models is the solenoid that changes the mode from crushed to cubed has frosted over/frozen over. Sometimes this happens if the freezer door is left open. Slide the ice bin out of the freezer section, and notice where the lever on the end of the ice bin goes into what looks like a plastic "square" on the left side of the box. That "square" is the end of the solenoid and it should move freely by hand. It is probably frozen stiff. If this is the case, sometimes you can get away with thawing it out with a hair dryer, but I usually find I have to take theat whole assembly out of the freezer, thaw it out and then dry up the parts, as it sometimes will just re-freeze if you don't get the excessive moisture off the solenoid plunger.
I hope this helps.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Refrigerators
Questions and Unsolved Problems for Refrigerators
Answer
Whirlpool model ET1CHEXVB or model W2RXEMMWB. Anyone have comments on either of these... (More)
Answer
Need a new refrigerator after only 8+ years from Kennmore -- have not been happy with this brand on... (More)
Answer
Fridge broken, frezzer working in the same unit, is that possible? Do they use seperate compressors
Answer
the freezer has an ice build up. I defrosted but it ice is coming back. the refrigerator side is... (More)
Answer
need a diagram on ice chute assembly...replacing solenoid & the spring fell out..can't... (More)
Describe your Refrigerators problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
in Van Nuys, CA
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
