Question about Bissell 6594 PowerForce Bagless Upright Vacuum
How do i change the belt on the bissell powersteamer 1697w????
OK..........I've  got the cover off and see that it is my belt.........went to wally world and got a new one...............now i cant get the little red thing off to put new belt on!!! HELP!!!
Ok taking the cover off is good. I believe the the little red thing is the beater bar. This beater bar has brushes on it an extends the width of the vacum. Pull the beater bar out straight. Some times it is tight. Next is to place the new belt around the spindle in the back and slide the beatrer bar into the belt. No twists! Besure to have the beater bar with the seperated area with no brushes inline with the belt.Now place the beater bar in place. Make sure you turn the beater bar so on the side the slotted portion slides all the way in place. Replace your cover. Turn it on and try it.
I believe this will work. Let me know.
desmjs
Posted on Dec 14, 2008
My Bissell powersteam powerbrush carpet cleaner wont spray water from the floor jets or the hose. Checked the belt, its doesn't look damaged, also took it apart and cleaned the floor jets, still nothing.
Check any related mechanical and/or electrical parts, including switched, levers, buttons, valves and all water-ways. Make sure all electrical connections are clean, functioning with a multi-meter, and all pieces are NOT broken or malfunctioning and clean. replace any broken or malfunctioning parts that you can't clean or repair.
Oct 15, 2013 | Bissell 1697W Powersteamer Pro Upright...
Bissell 1697 catches when trying to roll forward ?????
Sounds like the half moon window is dragging. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1212&cid=ccsocial
Feb 08, 2013 | Bissell 1697W Powersteamer Pro Upright...
My Bissell 1697w motor is sparking and smells like something is burning. Do I need a new motor?
You may want to contact a BISSELL Authorized Service Center to have a qualified technician inspect your machine.
Here's a quick link to locating one. http://www.bissell.com/service-centers/?cid=ccsocial
Dec 11, 2012 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1697w Powersteamer
http://www.bissell.com/images/UserGuides/1697_207.pdf
go to bissell.com on the right hand side is the link were you type in your model number. it will take you to it you click more info and it opens a page to access the user guide. i had the same problem and after looking at the user guide found i had a broken belt (near the flow indicator there is a section that can open use a flat head screwdriver to pry it open and you can see the belt) i dont know if that will work yet b/c i just found it so im on the way to get a new belt. hope this helps
Jul 31, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 1697W power steamer
I JUST PURCHASED A NEW BISSELL CARPET CLEANER AND THERES NO INSTRUCTIONS IN MY BOOK AS TO HOW MUCH CLEANER TO USE, IT SAYS ON THE BOTTLE OF CLEANER THAT CAME WITH IT,IT SAYS TO ADD 5OZ.OF CLEANER TO EACH GALLON OF HOT TAP WATER
Apr 13, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Belt removal Bissel PowerSteam ProHeat
First take off the cover on the left side oif the top cover, then turn it over, remove the screw holding the red lock and pull the cap and brush roll out, remove the cap, remove the cogged belt, then you can put the new pump belt thru that slot, put over the pulley on the pump and then stretch it to go over the motor shaft. Then put back together.
Jan 18, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 1697w
First take off the belt cover on the side,
then turn it over, on the belt end of the brush roll, there is a red piece to hold in the brush roll, take out that screw and pull it off, the you can remove the end cap and cogged belt, Put the pump belt up thru the opening and around the bigger part of the pump pulley, grab the belt from the top side and put it around the motor shaft. Re-install the cogged belt, brush roll, cap and red lock.
Nov 07, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
I have a similar model and occasionally have problems with water/detergent flow. I find it is generally due to an airlock in the piping caused by forgetting to turn the deregent water control off before removing the detergent container. Follow the manual instructions. Turn the knob to off. Fill both containers. locate them carefully. Make sure filters in the water tank and in the flow meter are clear. Start machine with handle laid flat and knob turned to maximum flow.
Dec 22, 2006 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
182 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
