Question about Hobart N50 Stand Mixer
N-50 service manual
Bigg t, I just bought an N-50 that's in pretty good shape. I would like to have the service manual for it in case I ever have to rebuild it. I've downloaded everything I could find on the Hobart Service website. I have the ability to rebuild if necessary, but I wouldn't do it without the manual. I plan on this mixer outliving me, and I've blown two other "consumer" mixers, so I'm fed up with that stuff. I have no immediate need, but Iknow from visiting this site that you are "The Man". Can you help in my search for a manual? Thanks in advance. Ricardo
  • Rick Belanger
    Rick Belanger Dec 14, 2008
    bigg t. Thanks for the quick reply. I fully realise that Hobart does not release these manuals. I do have the exploded views for this mixer's components. I'm sure you know what I need for a potential rebuild. The fax # is 905 619-3275. Many thanks for your expertise. The fixya website and it's users are fortunate to have you online. Amen.
  • 640 Answers
Hobart keeps there service manuals for their techs only and do not provide them to the general public,Give me a little time and a fax number and ill see what i can do.
Posted on Dec 14, 2008
  • Caroline R Oct 24, 2012
    Anthony, I'm hoping you still read this board. I am in the same boat as Rick Belanger - I need a service manual for my Hobert N-50 (I actually have two of them). The newer one is ML 33777, ser no 31-1208-992; the older one is ML 19727-A, ser no 14060512. Fax: 978-540-4032. Thanks in advance. - Caroline
Hobart n -50 where do i put grease in, machine makes a grinding noise
If your N-50 is making a grinding noise there is a strong (almost certain) possibility that the cause is more than just needing more grease.
The sources of the noise are from the transmission case (front portion of the motor housing) and/or the planetary (where the blade attaches).
A search online should turn up the N-50 Service Manual.
With luck, it may be that the two adjustments specified in the Service Manual will do the trick
Three things come to mind regarding the noise:
1) If simply greasing the planetary does not do the trick, then
2) There are two adjustments to the transmission detailed in the Service Manual. And if that is not the cure
3) The transmission housing will need to be removed to find the source of the grinding. This is where the grease is truly encountered.
Sep 04, 2017 | Hobart Food Mixers
Shifting on my Hobart N-50 mixer. I just pulled the switch/shift cover. yellowish-brownish grease in places, but a few gears looked dry. Tried shifting / no success.
You are in for an adventure. The first step is to find the N-50 Service Manual online and download it.
Trouble shifting speeds is rarely a simple matter of lack of grease.
If your mixer shifted before removing the switch plate, then there is a post that shift lever engages which in not being engaged properly.
On the other hand, if that is not the problem, the transmission case must be removed. Shifting gears involves moving the tumbler yoke assembly. If you are extremely lucky the yoke's spring has become detached and re-attaching it will be all that is needed.
Of course the spring will be in place and you will have to deal with all the grease and investigate the cause.
This is a good time to replace the old grease as well.
Mar 14, 2017 | Hobart Food Mixers
Kitchenaid frozen bearing
Hi Thaddeus, What model is it? If you have taken it apart and checked the worm gear surely you would have stumbled on the frozen bearing if one exists. When you split the gear cases you are in a position to turn everything by hand so any frozen part is going to be pretty obvious.
Cheers Ross
Apr 24, 2016 | KitchenAid Food Mixers
How to check Artisan kitchenaid worm gear
If the planetary head (which holds the beater) is not reliably turning, you can be pretty sure that the worm gear (more properly called a worm follower gear) has protected the motor from burning out by sacrificing itself. The Service Manual may downloaded from:
Jun 06, 2014 | KitchenAid Food Mixers
Why is my kitchen aid mixers so Loud?
Could be,among other things:
Very worn brushes (although, in this case, the mixer usually stops entirely).
Worn gear(s).
Grease congealed and not lubricating correctly.
In any case, see the Service Manual at:
May 16, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kp2671 stops and starts
It is not going to be a problem with the motor. It is going to be a chipped/damaged gear, a bent planetary center shaft pin, or possibly the planetary itself.
The first thing you need to do is take the mixer apart. You are going to have to clean of all of the gears and inspect them very closely. I recommend using paper towels and wd-40. If there is any damage, the gear will need to be replaced, in some cases the pin that sits between the worm follower gear and bevel gear can become bent, if it is, it also needs to be replaced. If all of the gears, bearings, and the pin are in perfect shape inspect your planetary assembly. In some cases the center shaft, which is pressed into the planetary can become loose, so it will still spin under no load, but as soon as you put something in the bowl it stops spinning.
Here is a link to the KitchenAid service manual. This will walk you through how to take the mixer apart, and put it back together:
Please let me know if you have any questions, or need help with the repair.
Thank you,
Customer Service
Feb 15, 2013 | KitchenAid KSM103 Professional 5 Series...
Does the Kitchenaid Model G / Hobart N-50 have a motor capacitor?
There does not appear to be one listed in the service manual. The manual is here Hobart 50 Service Manual
Jan 30, 2018 | Hobart N50 Stand Mixer
I have a Hobart N50 and am in need of a SS bowl. The bowl pins are 8 7/8" apart. Do they make a replacement bowl for this? I've seen the ones that have 9" bowl pins. Thanks, Ron
can buy hobart bowls from lots of places, or use the correctly shaped kitchenaid ones, both fit.. i like the lip and thickness of the hobart bowls, bought mine from globe equip.. do u still have the service manual, if so i would be real intrested in it, please
Jun 14, 2009 | Hobart N50 Stand Mixer
Small screw and nut?
By turning the screw cw or ccw it adjusts the clearance on the worm shaft assembely,in other words if the mixer is noisy by adjusting this screw you can quiet it down.
Mar 30, 2009 | Hobart A200 Stand Mixer
Hobart Mixer wont start
I apologize but im unable to answer yours or any others at this time.Ive been hijacked by another user on this site that is dropping my rating.I contacted (manager) of this site about restoring my account but has yet to do so.If my request fall on deaf ears maybe if you can email him and explain that its hard to get info on any hobart products and im the only one that is a hobart tech answering questions for FREE!!As soon as this matters resolved i will continue to help people as ive been doing for a year on this site.
Apr 01, 2008 | Hobart HL600 Legacy Stand Mixer
Hobart N50 Stand Mixer Logo
366 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
