Question about ASUS P4SDX Motherboard
WinXp wont boot after the initial installation
Had an an hp d330 pc.
tried to install with a fresh copy of windowsXp on it.
you know after the usual stuff of copying from the cdrom with xp to ram/hd then it reboots to complete installation.
after the reboot, POST passed
and nothing happens. just a cursor blinking waiting for something.
tried to replaced, ddr ram, hard drive as well as the socket478 processor.. still the same happanes.. just a blinking cursr after POST :(
do you think i have a problem with by motherboard?
i even tried to download a new rom bios image from hp website.
it successfully upgraded the firware but still same problem exist
hope you can help me on this
thanks
-dexterdolz
  • Anonymous Jan 03, 2009
    i have exactly the same problem
    President:
  • 2,351 Answers
Hi dexterdolz, systems from companies like HP, Dell, Compaq, ECT. Usually put a small hidden partition at the front of their hard disk drives. (Between 2MB & 4MB in size). So if you try to install any version of windows it doesn't install because the partition is too small & you end up with a flashing curser or blue screen. They do this to force you to go back to them for your windows upgrade.
I noticed you mentioned you even swapped hard disk drive out & still got the flashing curser.
First make sure your hdd's data cable is good. (Swap it out with a new one). If you have an extra one. Boot the system & enter the bios. Make sure the bios list the hdd & that the drive is also listed in the boot order. Your cdrom drive seems to be working on the secondary IDE port.
You can connect your hard disk drive to the secondary IDE port if you feel there is a problem with the mother boards primary IDE port. Just adjust the bios boot order & hook the CDROM to the primary IDE port.
You can also run a program called Darik's boot & nuke on the HP drive: http://www.dban.org/
This will allow you to create a bootable floppy disk & totally clear the drive of hidden partitions. Windows should install just fine.
Good luck dexterdolz!
Thank you for using fixya.
Mike
Posted on Dec 14, 2008
  • 341 Answers
See if it will boot off the XP CD.If it does I would think you have a corrupt boot sector. Installing windows again should fix it if it is.
How do I install WindowsXP
You need a Windows XP installation CD plus the product installation code.
If you do not have a Windows XP Pro installation CD then you maybe able to get one on the internet.
To install Windows XP, boot up your laptop with the Windows installation CD and follow the instructions.
May 20, 2012 | Computers & Internet
HP 520 Notebook. Shuts down before installing new OS.
I agree a clean install is always the better, fresh start J
OK it sounds like missing drivers, what you have to do is create a new installation CD that will load the drivers for your laptop as it boots. I haven’t try this method with windows 7, but I know it works well with Windows XP. Try and create a new Windows XP CD with the drivers see: http://unattended.msfn.org/unattended.xp/view/web/35/
The start a new installation with this Windows XP CD and reformat you computer, after that you can do a new upgrade to windows 7
Nov 25, 2009 | Office Equipment & Supplies
Hello'I' gt a compaq d330 ut desktop Pc to arrange
If you format the hard drive NTFS format you should be able to install Windows XP. If the computer is old, the hardware may not work with Windows XP. Any computer built in last 8-9 years should work with Windows XP.
Nov 08, 2009 | HP Compaq Business Desktop d330
Installation failure- HDD not detected
may be your harddisk is not detected.
check in bios settings.
and disable sata otion .then try.
Dec 29, 2008 | HP 530 Notebook PC
Forgot password to log in to pc
Please mention your problem clearly....
If its BIOS password (when system boots it will ask for password) then shutdown the system and remove the COMS battery for 2 minutes which is present in the one of the corner of the motherboard.
If its user password (asking the user name and password) then you need to install a fresh copy of windows xp. to install a windows xp, Insert the XP bootable cd into the CD-ROM. Restart the system. Then the system will boot from cd. If its not asking to boot from cd then you need to change the settings on BIOS menu. When system restarts keep-on pressing the DEL or F2 keys or both. then it will take you to BIOS setup. there change the boot priority. Select first boot device as CD/DVD ROM. After please click on the below link or copy the URL and paste it in your web browser. Follow the steps.
http://www.microsoft.com/windowsxp/using/setup/winxp/install.mspx
Thank you........
Aug 19, 2008 | E-Machines eMachines Refurbished EMA...
PC not booting!
please chat with me so that we can solve your problem in a better way...........thank
Thanks and Regards
Dilip Bagdi
Technical Associate
May 07, 2008 | Computers & Internet
Reformat
Insert the winxp disk and boot from that, when prompted hit any key to boot from cd.
Win xp will start to install choose to delete the partition, confirm delete.
then press enter to install to that unallocated partition, choose format to NTFS.
Follow the prompts and it has formated the hard drive and will install XP.
Apr 30, 2008 | Dell Inspiron 8500 Notebook
Audio and vedio drivers
Go start run then type DXDIAG and let me know for system models and i will find right driver for you!
Jan 06, 2008 | HP Pavilion dv9000z Notebook
ASUS P4SDX Motherboard Logo
144 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
