Question about Belling XOU492 Electric Double Oven
My fan doesn't work
My wife and I have just bought a new house. There is a Belling double oven which must be at least 20 years old. When I turn the main oven on, the light goes on inside, and smoke comes into the oven from the back. It looks like the heating element is working, but the fan certainly is not. How can I fix the fan?
    President:
  • 1,462 Answers
Fan not fixable - replace. possible be that there is crap jamming the fan.check that the fan blade turns freely
Posted on Mar 20, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
I have an Indesit oven FI 31 KB. It is 3 years old but never used as it is in a house I have just renovated. I turned the oven on, but the fan did not come on as it is expected to do. Oven and light seem...
sometimes there is a switch that operates when the door is opened or closed causes the fan to stop when the door opens. The switch is normally mounted at a door hinge, or hinge bracket.might have to remove a panal to get to it
Oct 19, 2013 | Belling XOU492 Electric Double Oven
I have a new belling b170f and have just turned it on however the fan at the back wont turn off. how long would I expect the fan to run. The oven has not even been hot yet
If its less than a year old then call belling as it sounds like the thermostat for the cooling fan is faulty. Its designed to cut the cooling fan in at around 65 degrees celsius to protect electronics.
Mar 02, 2011 | Ovens
Belling built in fan oven (XOU60FP)is overheating
Have same problem, I am repairing our 648HM double oven. Top oven overheats. I am an electronics engineer. I found that top oven fan has failed, this is the first thing to replace. The grill element also failed which maybe due to the overheating oven. NIGEL
Apr 03, 2010 | Belling XOU174 Electric Single Oven
My Belling oven has no heat, but the fan &
If the fan is working o/k, then there is little doubt that the oven element has failed.
This is quite common with fan assisted ovens.
The element is usually located at the rear of the oven compartment behind a removeable cover.
Mar 29, 2010 | Belling XOU252 Electric Single Oven
Belling oven xou592 bottom fan oven not heating up fully. Fan works and orange thermostat light on but does not heat up. Before this happened it tripped mcb in consumer unit.
You need to fit a new oven element.
This is located at the rear of the oven behind a removeable cover, where the fan is
It is a fairly straightforward job to replace.
Hope trhis helps with your problem.
Dec 15, 2009 | Belling XOU592 / XOU593 Electric Double...
Fan oven option not functioning on main oven, its a Belling synergie multifunction oven, about 5 years old
On my Belling it was the oven multi function switch that was faulty. I replaced it - carefully (lots of coloured wires) and it works fine now. Hope this helps
Oct 24, 2009 | Belling XOU590 Electric Double Oven
I was wondering can i buy glass for the oven door seperate?
Providing the oven is not more than 10 years old, then there,sholud be no prob obtaining a new door glass.
Go to: www.belling.co.uk
Then click on: www.4belling.co.uk/spares
Pleas leave a rating for my suggested solution.
Thanks.
Feb 17, 2009 | Belling Ovens
Fan in oven works but only warms the oven
If the element was gone completely then the oven would not heat up at all. If the element blew while the oven was on then that would explain why it was warm. Elements cost between £20-£40, plus any labour costs. You can find this out when you contact the repair shop. Another thing to consider though is that it could be the thermostat, which controls the heat. These cost from around £25 upwards again you would need to confirm this with the repair shop. All in all I think you are looking between £50 - £80 to get it repaired.
Dec 08, 2008 | Belling Ovens
Belling 592SS self clean panels need replacing
Go to:
www.belling.co uk and follow the links
You should find what you are looking for
Dec 08, 2008 | Belling XOU592 / XOU593 Electric Double...
Belling XOU492 Electric Double Oven Logo
342 people viewed this question
Top Belling Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Mike Charette
Are you a Belling Oven Expert? Answer questions, earn points and help others
