Question about Amana ABB2223DES Stainless Steel Bottom Freezer Refrigerator
Poping the curcuit breaker
My frig keeps popping my curcuit breaker and wont work now and it is the only thing on this breaker.
2 Suggested Answers
  • 614 Answers
SOURCE: amana air conditioner keeps popping its cord breaker
This a ground fault breaker. They do go bad. Is it kicking it all the time or when you plug it in. I replaced a lot of the ground fault plugs. You have to go to the Appliance Parts store to get a new power cord. If you have a problem with thisyour warranty should cover the power cord check your warranty. Rus
Posted on Jul 11, 2009
Fuse on motor keeps poping after running a couple of hours.i reset button on motor and works fine for a while then button pops again.
What are you working on? You say "motor", so I assume it is electric, because if it runs on gas it is an "engine". If unit is getting hot, it will trip the breaker. This could be due to cooling path restricted by trash, or unit working too hard due to load being faulty.
Sep 02, 2015 | Cars & Trucks
Curcuit Breaker appears to be on but no power?
It sounds like something in that circuit is causing the overload. Disconnect anything that is in that circuit, flip the breaker, and one item at a time plug whatever was on that circuit back in until it trips again. Then try that item in a different circuit and see if it does the same thing. It could also be that the breaker is worn out and is tripping at a lower point that it supposed to. In that case you would have to replace the breaker.
Mar 04, 2015 | Electrical Supplies
Control panel lights not working and none of the buttons resond
Power? Has circuit breaker popped? Possible you have ground fault protected outlets and one of them popped like a circuit breaker. It usually causes all outlets on that circuit to also disconnect. They have a reset button similar to other circuit breaker devices, so double check. If it pops again, you may have a serious electrical problem or appliance problem. Unplug all appliances plugin one at a time to discover bad appliance. If none are bad and you still have frig problem. Time to call an electrician. You may be able to verify frig via extension cord from an outlet outside the kitchen. That if lights and buttons work, then you know it's the kitchen circuit problem. If not you may have a major problem with the control panel itself. Time for an appliance technician.
Feb 27, 2015 | Hotpoint Refrigerators
My champion generator 9000 watt breakers keep poping
How much time have the Generator?
looks like batteries needs to change it.
Aug 11, 2014 | UPG 12V 18Ah Champion Generator 9000 7000...
Has there been issue with 30 amp curcuit breaker needing to be changed to 40 amp on 2002 FXST
Main circuit breakers were a problem on the older bikes, problem being when over heated the would pop and you would lose all power to the bike. Now if you bike is dying and you still have power and are able to crank it but it wont start, then I'd be looking at you CPS not the main breaker. One way to tell if it's CPS is to remove it when bike doesn't start. Wipe all the oil off, take a can of compressed air blow it on the CPS to cool it down, put back in bike and start it, If it starts then the sensor is bad.
Mar 19, 2013 | 2002 Harley Davidson FXST Softail Standard
I have a thermosol AF 240 steam generator it is wired to a 50 amp GFCI breaker. It has worked for about a month, but now the breaker pops immediately. Checked for wires touching, replaced breaker, but...
Is the wire compatable for a 50 amp breaker. Also unit souuld be on its own dedicated curcuit, also how many amps is the service in the building, if your only at 100 amp it will not work.
Mar 06, 2011 | Thermasol Steamshower Generator AF Series...
Keep poping the breaker on instllation
Check your wiring for short circuits. If you turn the switch on and it pops it may be in the switch box or up in the fan box. Also make sure the fan blades spin freely. A motor overload or short circuit would be the only reason for the breaker tripping immediately.
Jan 10, 2010 | Hunter Sontera 52" Ceiling Fan with...
Frig stopped running.
Maybe over pulling more amps the the GFCI curcuit can handle. Check all the GFCI plug and verify if there are anything else plugged in. Including hair dryers and / or flat irons.
Sep 02, 2009 | LG Heat cool Window Air Conditioner
Poping the curcuit braker
Your compressor is bad .Need to replaced, a way to test is unplugged the compressor and see if it stays on
Dec 28, 2017 | Amana ABB2223DES Stainless Steel Bottom...
Curcuit breaker pops
hello elanalex,
When your heater shuts off it trips your main breaker and that is usually associated with the interupt capacity of the breaker ( which means that while your heater is drawing current, if the thermostat says stop.. you are interupting that current demand abruptly and your getting a surge back to your breaker, You may be able to add a surge arrestor to that power feed to suppress that problem. You may also be able to repsecify your main breaker with one that has a higher interupt capacity.. Check with a local electrical supply house..explain the problem and they should be able to provide a hardware solution. Make sure you provide details on your circuit breaker brand so they can provide the proper solution.. GoodLuck
Dec 04, 2008 | Dayton G73 Utility Heater
Amana ABB2223DES Stainless Steel Bottom Freezer Refrigerator Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
