Question about Compaq tc4400 Tablet PC (RL875AW#ABA)
Compaq tc 4400 battery does not charge
I request your help, not burden indicates that the battery charging but not charging anything and when you connect the AC adapter becomes slow thanks for your attention.
  • 1 more comment
  • garciasoscar Dec 15, 2008
    Greetings, and installed a new battery, and loading on another
    computer, and the problem continues, the battery indicator tells me
    that this is not carrying the burden but, I suspect that the problem is
    the mother board, if you can send me your comments, thanks for your
    attention.
  • garciasoscar Jan 06, 2009
    Sincerely thank you for answering the problem is not in the operating
    system installed Vista Business and try and install Vista Home Basic
    and the problem continues, I suspect that the problem is the bios, I
    hope your comments, thank you for your attention.
  • maxchu Jan 08, 2009
    battery of my tc-4400 is not working. the pc seems to indicate the unit is charging but the indicator on the battery itself is off.
    Problem Solver:
  • 4 Answers
You may need a new battery... Somehow the way to test this is to try charging it on another laptop of the same model.
Posted on Dec 15, 2008
  • sakao Jan 01, 2009
    it could be a problem with your OS (operating system)... i would try that before going for a new motherboard! And you are welcome!
TC4400
How do you know the battery is good? does the multimeter really read more than the battery should give, according to what is printed on it?
A 3,7 volt battery, should give at least 3,8, wham not connected. A 7,2 at least 7,4. Because the printed voltage should be on the connector, when you are discharging the battery.
When your charger is blinking, it could indicate the battery is not well. The Ri can be to high or something else, is wrong, and that is ht the charger won't or can't charge.
Jun 09, 2014 | Compaq tc4400 Tablet PC
Laptop hp compaq tc 4400 is not charging , during adapter connected to laptop and turning power/standby led ... it doesnt switches on, instead battery charging led blinks 4 times, and doesnt turns on, so...
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Apr 16, 2011 | Compaq tc4400 Tablet PC
I have a HP Compaq tc4400 tablet pc. The battery light flashes 8 times then stops when I try to turn the pc on. I can't find anything in any of the documentation that tells what the problem is. The...
Sorry about this.
Have you tried charging your tab to full capacity first. You need to plug it into ac mains and leave for a few minutes to allow the battery get some charge on/in it.
Secondly, I am persuaded your tablet PC is windows OS (I stand to be corrected on this please).
Was the system board confirmed fully configured/operational with all drivers installed?
Aside of drained battery in need of charge or boost; suspected fault may have to do with getting your tab PC to initialize boot sequence.
Oct 10, 2017 | Compaq tc4400 Tablet PC
My HP Compaq tc 4400 tablet screen keeps on flipping with out doing anything
The tablet buttons can be disabled to stop your screen from rotating. Go to Control Panel > Tablet and Pen Settings > Tablet Buttons > select the rotate button and click change > select "None" on the drop down menu.
Feb 22, 2010 | Compaq tc4400 Tablet PC
Is there another way extra button to turn on my HP TC 4400" the "on" switch is broken inside of the computer
You can actually short out the on/off circuit with a flat head screw driver. I have to do this until I can find somewhere to purchase a replacement sliding switch to attach to the new motherboard which I have waiting to be installed. Alternatively purchase a cheap docking station off ebay
Jun 08, 2009 | Compaq tc4400 Tablet PC
Purchased lap top from work person I replaced added a password so I can not use it. HP Compaq tc 4400 how do I remove, the safest way thanks Harleygirl
Please let me know whats the OS you are using. If you are using XP it is a relatively simple reset procedure. However if you are using vista the easiest way to get rid of it would be to re-install the OS.
May 26, 2009 | Compaq tc4400 Tablet PC
Battery problems Tc 1100
When the Batt is inserted and you are on AC power do you have a lit charge light? It's the one in the center of the three at the lower right when you are in landscape mode.
If your batt is at "end of mission" (**** up) then it's ability to hold and take a charge may be very limited. Calibrating the batt might help. You will need the toaster style charger.
If this is the issue, then the charge light may only stay on for a few seconds at a time when you first attach AC power, so be watching.
I could recommend a new batt (e-bay) if thats your only trouble. Nothing lasts forever. I'm in Missouri and will calibrate your batt if you want to mark it and ship it. Let me know.
B
May 05, 2008 | Compaq tc1100 Tablet PC
Battery is not charging
Let the battery go all the way dead. You may have to adjust the settings in your bios so that the laptop will stay on until the battery goes completely dead. Then charge the battery. Do this a few times if it does not fix the problem you do need a new battery.
Jan 21, 2008 | Compaq tc4200 Tablet PC
Compaq tc4400 Tablet PC (RL875AW#ABA) Logo
889 people viewed this question
Top Compaq Tablets & eReaders Experts
Jerry Umali
Ann
Level 1 Expert
ray gallant
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
