Loose power when turing it on
We have two tpi baseboard heaters, and when we turn the theromstat on we loose one of the 120v so the heater doesn't work. Do we need a new theromstat?
    Problem Solver:
  • 12 Answers
Sounds like it is wired incorrectly at the baseboard heater. BUT if it worked correctly before this, then you may have a bad thermastat. Wiring in two baseboards into one thermastat is a bit tricky, each time I do it I have to think it thru before hand to get it right. IF it has never worked right, again you probably have it wired in wrong at the baseboard.
Posted on Sep 29, 2009
I need to wire a remote thermostat to my electric wall heater in the bathroom. Not sure if I run the wire from the panel to the heater first or to the remote thermostat then the heater.
Run the wire to the thermostat then to the heater
Jun 21, 2011 | Heating & Cooling
I cannot get my TPI Corp baseboard heater to turn off. It kicks on even when it is not that cool in the room.
If the unit kicks on at too high a temperature, then it is probably the thermostat. If it will not turn off then it is probably the switch that is bad. Since you gave both indications, you could have two components bad. NOTE: Normally calling a technician to repair this item is more expensive than replacing it with a new one yourself.
Jun 18, 2011 | Electric TPI CORP TBS BASEBOARD HEATER...
We put in a new baseboard heater thermostat a couple of years ago in our 20 yr. old apartment. When we turned it on yesterday, it shorted and we no longer have any heat coming from the baseboard. Do we...
I have base board heaters in each room and each with a thermostat and hooked to a controller. The controllers activate the heat in the base board heaters. I believe this is how it works. When you activate the thermostat, it sends a message to the controller that sends a message to the base board for heat.
The controllers are Singers. Prbkem 2:. When I turn down the thermostat (to off), I still get heat in the base board heaters. WHY.
I was going to get rid off the controllers and thermostats and buy new base board heaters at Home Depot. The thermostats are on the base board heaters. Will this work.
Oct 26, 2010 | Electric TPI CORP TBS BASEBOARD HEATER...
I have power to my heater but heater will not heat
Does your baseboard heater have tstat. If so. Turn off power and disconnect the two wires going to heater take a ohmeter and check to see if you have any resistance on your heater. Also remove wires from tstat and check across terminals to see if you have restistance should be 0. If the heaters are good should read restance across them. If no resistance is found bad heater. Keep in touch Rus
Dec 08, 2009 | Heating & Cooling
Baseboard heater running all the time
since they have indivial twist knobs that regulat temp, the thermostat is bad on one in hall either replace knob which should have thermostat built in or whole unit
May 03, 2009 | Electric TPI CORP TBS BASEBOARD HEATER...
Heater is excessivly noisy, can be heard over tv
first, my research into the Cadet model #09954 is a 240v unit. if it is wired to only 120v that may be your problem. I am not even sure it work work on 120v.
Feb 11, 2009 | Cadet Manufacturing 09954 Baseboard Heater
Disconnect baseboard heater
After confirming that the heater circuit is de-energized, simply go to whatever heater that you want to disconnect, open the junction box, remove the heater wires and cap them off. Twist the remaining circuit wires together, wire nut, replace the juction box cover and on to the next one. There are ways to install a thermostat at each heater too.
Jan 17, 2009 | Electric TPI CORP TBS BASEBOARD HEATER...
Electric baseboard heater
You need a meter, it will be hard without this! If you have 220v in the wall, then think of it like this; each wire is 120v. Test to each other, you get 220v. The thermostat is a double pole, you said. So think of it like this, its an adjustable temperature controlled switch that lets electricity through at the temp. you set it at. If you have 120v from one wire connected to one end of the element, and the other 120v connected to the other end of the element, then it will work. DO NOT CONNECT THE 120V TOGETHER. IT MUST GO THROUGH THE ELEMENT FIRST. The thermostat should be between the power from the wall and the element, to control the temperature.
Jan 05, 2008 | Fahrenheat FBE15002 Baseboard Heater
127 people viewed this question
Top Electric Measuring Tools & Sensors Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Electric Measuring Tool and Sensor Expert? Answer questions, earn points and help others
