FixYa.com
Tags:
Vizio L30WGU 30 in. HDTV-Ready LCD Television
I've heard that plasma TVs shouldn't be used at...
By maartenw - usenet poster
I've heard that plasma TVs shouldn't be used at high altitude. Is this true?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 08, 2005
Helpful (85)
Charlie
Charlie - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Yes. Most plasma TV manufacturers only recommend to use their televisions at elevations under 5000 feet. To be sure if a TV will work at high altitude, check the specifcations in the manual before you buy.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 13, 2008
Not Rated (0)
dalebesh
Rating: 0%, 0 votes
Samsung's latest plasmas have a spec of 6500'.. recent issue of Widescreen Review, calibrator had a recent model (50A550) operating a few hundred feet above that with no problems, no buzzing.
Solution #3
posted on Apr 23, 2008
Not Rated (0)
pookie7408
Rating: 0%, 0 votes
Can you play videogames like Xbox 360 Elite on a Panasonic 50' Plazma TV ?
Solution #4
posted on Jul 05, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
The only Plasma TV that will operate above 6000 ft. in manufactured by Runco. The Television is very expensive aroun $8000, but worth every nickel.
Hope this helps!
Solution #5
posted on Mar 22, 2007
Not Rated (0)
phoneashley
Rating: 74%, 4 votes
a plasma screen panels have a gas in them (like a flourecent tube) the gas gets too pressurized and soemtimes causes a low humming sound. I would go by the specifications
This Problem Also Relates To: Audiovox FP1520 15 in. LCD Television Panasonic TC-32LX60 32 in. LCD Television Panasonic VIERA TH-65PV500 65 in. Plasma Television Panasonic TH-42PD50U 42 in. EDTV Plasma Television Panasonic TH-42PZ700U 42 in. Plasma Television Sony PFM-42V1N (Silver) 42 in. EDTV-Ready Plasma Television Sony BRAVIA XBR KDL-V32XBR1 32 in. HDTV LCD Television
Can you Help with these Flat Panel Televisions problems?
same problem picture turns blk...
have a 47 " Gallevia... Answer This...
vizio 32 in. HDTV
A bright red vertical line has... Answer This...
LCD Tv Flat Vizio
VU42LF HDTV10A
Our 42" Vizio has... Answer This...
connecting a computer
hello i am in the process of... Answer This...
Repair Service
Find Flat Panel TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
