Question about Whirlpool Duet GHW9150P Front Load Washer
Error code f-21 how can I tell if the pump is bad
I checked the hose and the filter. Cant find anything clogging either of those. Wondering if it is the pump, but how do i tell if it needs a new pump or not? I also checked for any loose connections but didnt find any.
    President:
  • Whirlpool Master
  • 2,651 Answers
According to the whirlpool website the f21 is a communication erroe, nothin to do with pump. if you remove the top panel from washer (3)screws from across the rear of unit, youll find the main control board just under there. i would look for loose wiring connectiond at tha point.
f21=
This error occurs if the touch-pad/LED assembly is not
able to transmit/receive data to/from the central control
unit (CCU).
Possible Causes / Procedure
1. Check the touch-pad/LED assembly by selecting
different cycles and changing the modifiers and
options available to confirm the touch-pad/LED is
responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit
Posted on Dec 14, 2008
My normal and Eco light keep flickeing and there is still water in my filter
Hello. That flashing combo of lights is an error code telling you that something has malfunctioned. Most likely, from what you describe, the drain pump is clogged or jammed. I need the model number for a more exact diagnosis of the error code--its a digital code--the lights will flash a certain number of times, usually. The clue here is the water left standing in the tub. It means the drain pump failed to evacuate all the water out. When you cancel/drain, do you hear the drain pump turn on? If so, then the main board is activating properly and sending 120volts to the pump. Probably the pump is clogged with food or debris, and/or the drain hose is clogged. If you don't hear anything, then the kick panel(below the door) must be removed, the pump, wiring, main board must be checked. Check the filter inside the floor of the washer--if it's gunked up, the main pump can't spray properly and the drain pump can't pull water out.
Aug 19, 2015 | Kelvinator Dishwashers
Need manual for whirlpool front load sport duet model wfw8600sr00
F-21=LONG DRAIN If the drain time exceeds 8 minutes the water valves shut down. After 4 mins the Sd(slow drain) error will be displayed, 4 mins later the F/21 error code will be displayed.
Press PAUSE/CANCEL 2 times to clear display
Probable cause/Proceedure
Drain hose plugged / kinked
Unplug washer/disconnect power
Check electrical connections to pump and make sure pump runs, check drain pump filter for strings,sand etc., plug in washer. If this don't work dismantle pump carefully to check if anything is clogging it. If the electrical side of pump is faulty this can easily be replaced, it is normally not repaired.
Washer parts can be found on this site.
www.youtube.com/watch?v=2abTptUYXH8
Mar 04, 2013 | Washing Machines
Error code 21?
F21 is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a ?SUDS? error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
  2. Check the drain hose to make sure it is not kinked or clogged.
  3. Check the electrical connections to the pump and ensure the pump is running.
  4. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions: checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Hope helps.
May 23, 2011 | Whirlpool AWM8163 Front Load Washer
I cleaned the pump filter after getting sud error. now i get F 21 code.
Press the pause cancel button 2 times this should clear it. If it does not and the filter and drain hose are clear you will need to replace the pump.
F21 Fault Code Repair
LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
Press PAUSE/CANCEL two times to clear the display.
LONG DRAIN
NOTES:
1. Check the drain hose and make sure it is not plugged or kinked.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
LONG DRAIN
NOTES:
Nov 03, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
F21 code flashes
Lets see what an F-21 is shall we? F21 Long drain Possible cause: Clogged filter, clogged/failed pump, suds detected by control.3a5b94a.jpgb4a897e.jpg55f108d.jpg
Jun 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F21 code
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following
try doing the following :
Apr 29, 2010 | Kenmore Elite 45986 Front Load Washer
My washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Jan 18, 2010 | LG WM-2277HW Front Load Washer
He2 error message f 21
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 06, 2009 | Kenmore HE2 Plus Front Load Washer
Message OE
OE : Drain Hose is Kinked or clogged or The Drain Filter is clogged - Clean and straighten the drain hose / clean the drain filter.
also do check for the pump blockage.
for more info on this check the following link
http://pastoralfarms.us/2008/04/21/lg-fl-washer-2277-oe-error/
Dec 23, 2008 | Washing Machines
F-21 error, washer not draining
I have had this code three separate times. The first time service man came and cleaned out the filter. This is behind the lower front panel and can be removed by hand. The cartridge style filter is located at the pump in the lower right of the unit. Have something available to catch the draining water as you loosen the filter. The second time I received this code I found a blockage in the drain hose at its bend. The third time no hose blockage, no filter clogging, but the pump impeller was jammed by an elastic strap that had made it through the filter. I removed it through the supply side of the pump seen after filter is removed.
Feb 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
82 people viewed this question
Dan Webster
Dan Webster
Sal De
