Question about Frigidaire PLMV169DC Microwave Oven
Microwave with load buzz and not heating.
The microwave was in use while the stove top below was being used and sending heavy steam onto the microwave control panel. The wife heard popping and then saw blue sparks shoot out below the control panel. No smell, flame or smoke after the event. The control panel still works fine but the microwave doesn't heat and there is a new buzzing present while trying to heat. I removed the control panel to inspect the electronics for obvious burning. The only thing I could see is the HV transformer looks to have small burn marks on the outside of the transformer body. I would like to replace the transformer but don't want to waste money if this is terminal.
  • Frigidaire Master
  • 9,098 Answers
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron.
It may be a problem with the transformer, but I suspect that less.
The diode is a fairly cheap fix, and the mag will cost more. The transformer may be pretty steep. But it's best to take it a step at a time.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Posted on Dec 15, 2008
The vent will turn on randomly and not turn off!
Most over the range microwaves have a heat safety system built into them. If for instance you are cooking on the stove top for a long period of time on the burner directly under the micro control panel and the control panel get too hot, a thermostat in the microwave will automatically turn on the vent fan to help keep the control panel cooled off. My guess is that the safety thermostat (usually right behind the bottom of the control panel) may be going bad and needs replaced.
Apr 03, 2015 | Kenmore 30" Microwave Combination...
Kenmore elite microwave
Was it just the exhaust fan that came on? If so this is normal when cooking on the stove for long period of time without the fan running. The heat builds up under the microwave and eventually activates the fan.
Sep 05, 2014 | Microwave Ovens
Hot microwave door handle
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
Jan 08, 2013 | Whirlpool Microwave Ovens
Microwave popped and now does not heat
Okay, first we need to separate the situations. You were boiling water on the stove and had the range hood fan running to **** up the steam. Then you put something in the microwave to heat and you heard a pop and then zip-o.
The water on the stove has nothing to do with the situation, the fan you turn on is not part of the microwave, so it has nothing to do with the microwave.
The pop you heard and then the humming suggests the magnetron failed. You said you found a blow fuse and replaced it and still nothing, right? The magnetron is the most likely culprit...I would think it is safe to say that the magnetron shorted and drew enough current to blow the fuse.
Replace the magnetron and if that doesn't work, let me know here. Good Luck!
Sep 14, 2009 | Sharp R-1480 Microwave Oven
Acceptable distance from cook top surface to microwave?
Sorry but your subject line got cut off. I'll assume you're talking about the distance from the cooktop to the top of the microwave (bottom of the cabinet to which it's mounted).
Here's how the installation instructions spec it:
  • "Make sure the bottom edge of the cabinet that will be above the microwave oven is at least 66" from the floor and 30" from the cooking surface."
So it's measured from the cooktop to the top of the microwave, not the bottom edge.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
You can also download your owner's manual form the link I posted above.
Jun 25, 2009 | Hotpoint RVM1425 Microwave Oven
Whirlpool Microwave Hood combination Model MH6150XM turned itself on without anyone touching it. The oven and the fan went on. It continued to operate when the microwave door was opened. We unplugged...
Direct spraying of cleaners on the keypad and steam from the cooktop can short the keypad.
Luckily, it dried out. Sometimes it doesn't, and the keypad has to be replaced.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
And I always recommend that you use the vent fan when cooking on the stove top to keep heat, steam, and grease out of the controls.
Jun 22, 2009 | Microwave Ovens
My maytag over the oven microwave just died;
most likely the power supply in the microwave is gone. the microwave die probably it is over the oven. heat from the stove cause the microwave to heat up and cold off more than it is on the counter.
counter microwave has fan and air slot in the rear. it keep the motor and microwave cool, and there nothing else to keep it hot. but the over the oven, the only ventalation is from the top. and with the added heat from the stove top and oven.
Apr 27, 2009 | Maytag MMV4205 Microwave Oven
Cleaning vents
GE Spacemaker Profile X1800.
I would take out the grills and boil them, but cannot see how to do that.
Also, the GE stove top (Model JGSP44BEY) has so much baked on crud that I may never use it. I poured a whole bottle of easy off onto it and still cannot loosen it all. Same goes for the removable parts from the burners.
May 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Buzzing When Not in Use
Are you using a 3 pronged outlet and is it grounded? If you have a 2 holed outlet and are using a ground eliminator adapter, try turning the plug around to reverse the polarity. If this helps, then it would be advisable to have an electrician to ground your oven.
May 22, 2008 | Whirlpool MH7140XF Microwave Oven
Frigidaire PLMV169DC Microwave Oven Logo
218 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
