Question about Baumatic 23 in. BDW13 Built-in Dishwasher
I need to reset my dishwasher but don't know how!!
MMy baumatic bdw13 needs reseting. It powers up but cannot figure out what buttons to press to reset. Can anyone help???
  • 3 more comments
  • ugers Mar 21, 2008
    BDW13 dishwasher. Delay timer stuck on 17, I have tried the solution on page 19 of the baumatic manual that doesn't work. According to Baumatic 17 is the manufacturers setting therefore I must need to reset the washer but don't know how. They charge £80 for a call out and I just know they will fix it in seconds.
  • miley1234 May 07, 2008
    re-installed timer number coming on only
  • shanesemail Jul 17, 2008
    Hi there - I have the same problem - I have spoken to someone at their helpdesk, and like many of you, resetting doesn't seem to have done the trick. Resetting requires you first to swith on the dishwasher, then hold down the timer delay and the on/off button for more than 1 second. Apparently this resets the machine. Turn the machine on again after a further 2 seconds. Resetting didn't work for me but I have just read that the most common fault is that there is a polystyrene float under a panel at the front that trips the pump.
    This is the advice from another site if your machine is out of warranty (as mine is): "underneath the door is a plate (as wide as the dishwasher) ind about 6inches high. Remove the screws and the kick board retainers, rear feet screws and prise off the plate, you should now see a float trip mechenisim, "!!!!switch off the dishwasher!!!!!" and using a sponge soak up the water, using something "Non conductive," trigger the switch a couple of times then restart the dishwasher."
  • jowatsonpink Feb 25, 2009
    hi can any one help we have brought a second hand dishwasher favorit electrolux integrated and cant seem to get it working any ideas your help would be appreiciated!!!!!!
  • Anonymous Mar 15, 2014
    Tablets do not dissolve, plates dont look like they have even got wet and do not know what to do! I tried putting dishwasher salts in but it doesnt seem to be working still! Any ideas what I should do?
    Problem Solver:
  • 10 Answers
Search my other answers - Error E4 - too much condenstae in bottom catch tray
Posted on Oct 05, 2008
The engineer I spoke to suggested cleaning all filters and turning it off at the mains for 48 hours - it should reset. In the unlikely event of this not working call an engineer to fix.
Posted on Dec 27, 2007
Bdw13 showing e4 & trying to empty when no water in it
Posted on Apr 16, 2007
  • 944 Answers
If it's any help then here is the link to the user manual (when you download it it applies to bdw13 as well even though it is labelled for the bdw14) http://www.baumatic.co.uk/products/discontinued-models/dishwashers/integrateddishwashers/BDW14 Best I could come up with is to try page 19 at the bottom of the "dishwasher doesn't run" section - there are two different types of reset which may do the job. Hope this helps :)
Posted on Mar 14, 2007
Looking for reset switch
If your getting `E3` then it cannot be reset, one of the two thermostats on the heater element cannot be reset and has to be replaced, around £18, you can test which one of the thermostats is faulty by using an `ohms` tester, open circuit, faulty, this is a very common problem with these.
Sep 08, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Error code on my bdw13 dishwasher
Turn off the water and electric!
Its really easy to change the heater element, once you have taken out the dishwasher!, remove the bottom panel and remove the wiring to the element, slacken off the nut under the electrical contacts voila!, also it may be a faulty thermostat that you cannot reset and has to be replaced, I would do this at the same time, as again its easy with the bottom off.
May 03, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Baumatic bdw13
the top tray has a nozzle on rear,which pushes into a screw on rubber seal on inside rear of appliance.this splits and stops water being fed to sprayer on top tray.phone baumatic parts dept,only a few pence,but sent mine free!
Jan 09, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Dont know how to clean the dishwasher
go to the dishwashers brand site,click help for your solution.
Jan 05, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Baumatic BDW13
e4 code means the machine is showing a fault code for overfill,tip the machinee to a 45 degree angle and get excess water out should run ok after that
Aug 13, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
Baumatic BDW13 14 dishwasher SHowing E3 Fault
word_answers.gif I had the same problem and changed the two thermostats on the base and got it working. You can get them from partmasters.co.uk (thermostat protector) cost 17.99. They just screw in and are dead easy to fit
Mar 08, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
Baumatic 23 in. BDW13 Built-in Dishwasher Logo
2,644 people viewed this question
Top Baumatic Dishwashers Experts
Marvin
Marvin
Kolbrun...
ray gallant
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
