Question about Jenn-Air JGR8850 Gas Kitchen Range
Jennair down draft cooktop
It got cold air coming up thru the vent it cold all around the cooktop
a dryer flapper fix the problem?
  • brigitte_lew Dec 14, 2008
    Ill try that, its cold outside Ive noticed coolness on floor as well
    did nt realize it was going to be such an issue..thank you
Hi i have a Jenn air down draft as well you should have a spring loaded flap like a dryer they sell them
separately, you can buy them at home depot or lowes that will stop some of the cold air coming in not all of it.
Posted on Dec 14, 2008
Some water condensations around bath fan
THATS GONNA HAPPEN WITH THE HUMIDITY IN THE BATHROOM AND THE TEMP DIFFERENCE. TRY INSULATING THE DUCT WORK FOR THE VENT. INSTALL A FLAPPER SIMILAR TO WHAT A CLOTHES DRYER HAS. U DON'T WANT COLD AIR COMING IN. INSTALL A DEHUMIDIFIER.
Dec 12, 2009 | Home
How do I replace the switch for a jennair electric cooktop? model jed8430adb. Thanks!
You first need to remove the unit from its installation. Start by disconnecting the exhaust fan from the ductwork. Then push the cooktop up.
To get at the switch you need to remove the top by taking off only the top row of screws all around the unit and also at the top of the down draft cavity (the down draft cavity is where the grease guard mesh is)
Nov 15, 2009 | Jenn-Air JED8430 Electric Cooktop
Cold air from outside enters the kitchen through the down draft vent.
its would be best to install a damper
whether auto matic
or manuely operated
this is a common problem for the down draft
ive seen some people install things similar
to dryer vent louvers,
but check you exhaust area and still if you can block direct draft
but dont block it so that it cannot exhaust properly
Oct 11, 2009 | Jenn-Air JED8430 Electric Cooktop
Installing JED8230ADB Cooktop Grill with down-draft exhaust
I can't imagine directing the downdraft vent back up to a traditional hood type system. Why bother, just don't use the downdraft or get a cooktop without a down draft and save money.
In granite, yes for any cooktop as long as someone can cut the correct size hole. Cooktops must be installed so the top is just about flush with the countertop. They all come with a template for cutting the right size hole in the countertop.
Feb 24, 2009 | Jenn-Air JED8430 Electric Cooktop
Splendide 2000 dryer venting
Absolutely. You need to pull the unit out. Not what you wanted to hear. It not a pretty job.
www.coachtech.info
Feb 15, 2009 | Splendide 2000S Vented Washer/Dryer
Draft
Someone suggested the flapper needs replacing.
Thanks for your help.
Jan 18, 2009 | Jenn-Air JED8430 Electric Cooktop
Cold air draft
the only way is to block off/check the flapper., if your not going to use for the winter you can disconnect the vent from under the cabinet temporaily and close off there till you can gain access to check outside grill
Nov 25, 2008 | Jenn-Air JED8430 Electric Cooktop
Not drying
I know you cleaned the lint vent but your vent hose is clogged or damaged and there is no air exchange thru the dryer Air can only hold 100% humidity. You could dry your clothes for 10 hours but the air in the dryer is saturated with water and can not hold anymore so your clothes wont dry. Check behind your dryer and Ill bet the vent line is damaged. The problem is the air is not getting out of the dryer. Check the flapper at the end of the vent line. With the dryer running go to the end of the vent hose and there will be no air coming thru.
Oct 15, 2008 | Roper REX4634KQ Electric Dryer
Downdraft
I would double check that the installer used the correct vent hood outside. The correct one has a spring that keeps the outdoor flap closed when not in use. Cleaning the outdoor flap area may also help it seal a little better. Even if the right hood was installed, you might check to see there is a spring present (or signs that there was one.
I have never had air blow out the downdraft, but I do feel cold travel to the fan unit which makes the floor cold in front of the range.
Jul 12, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air JGR8850 Gas Kitchen Range Logo
273 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
