Question about Maytag Neptune MAH5500B Front Load Washer
Leaking Washer Machine
I have a Maytag Neptune front loading washer that leaks in the front right corner. I noticed a hole in the flange around the tub and I'm not sure if this is where the water is coming from or not. It seems leak worse when there are less clothes in the washer. Maytag wants to send someone out, but wants to charge me $80 for the trip. Help! Is this a major or minor problem? I have looked under the machine while it is running and a slow drip is in that front right corner. Anyone know the answer?
I just this week have had this problem. There is a whole in the rubber boot around the drain whole in the bottom. I have got the part and am trying to fix it myself. You might try calling your maytag dealer and asking for the part at cost. It's worth the try. They wanted over$80 for the part and over $80 for the call. motherof6
Posted on Mar 14, 2007
    Novelist:
  • 116 Answers
The right front corner is possibly a low spot where the water is runnung to. Two possible points of the leak are the main door boot could have a tear in it or the drain pump could have a hole. It is possible to look inside of your machine while it is running. First I must warn you to take care and not touch anything inside while there is power to your machine. First open the door and you will see 2 screws on the left and 2 screws on the right sides. one pair of screwws will mount the hinges and the other set goes through a small triangular bit of metal. remove the screws and leave the door in place. The sides of the front panel between the door and edge of the machine will rotate outward slightly and the whole front panel will pull forward. at about 45 degrees the panel can be lifted off of the lower supports and placed out of the way. You will now be able to run the machine and observe exactly where the leak is coming from. Again all of the electrical connections you see are live when the machine is plugged in so do not reach inside of your machine.
Machine is leaking from front right corner.
If the machine is leaking water not oil than the problem is with the main bushing on the center of the washers drum, It is either broken or worn. Remember when ever water leaks from something it may travel in many different directions before it falls to the floor. So be aware of this principle before you start fixing you will know where to look.
Feb 11, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Leaking water on spincycle
I have the same problem with my washer. The problem just began a few weeks ago. It is splashing out the front left corner of the tub and running down the inside of washer and then leaking out the bottom of the frame. It is just enough water to be annoying. The washer is about 6 years old.
Model: FAV6800AWW
Serial: 11277017EG
Any ideas??? Help!
Jul 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Order/Replace Rubber Boot on Maytag Washer?
it can be quite tricky to fit, you can buy one,I would however advise to get a supply/fit quote from an engineer as he will get discount on the part, unless you are good diy person ,get hired help....
Nov 28, 2009 | Maytag MAH6500 Neptune Front Loading...
Stackable Neptune Front Loader Washer Leak.
check that the door seals correctly on the rubber boot, check the boot for holes or rips, check the drain hose, tub to pump hose and pump.
Jul 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Water is leaking from the bottom of my washer, it is maytag neptune ,front loading washer
Check the door boot (typically grey rubber bellows looking ring around the door opening that keeps the water in the tub from leaking) for cuts.
See the manual:www.applianceblog.com/manuals/MaytagNeptunenew.pdf
Joe
Jun 06, 2009 | Maytag Neptune MAH6500A Front Load Washer
Maytag Neptune mag9700 leaking water from bottom
to get a better look at where its cominf from take it apart by removing the screws from around your vdispensor as well as the ones out of the door and the other side . then there is 2 5/16 screws under neath the lid once you remove the front take them out then u can see where its leaking from . odds are its it either your boot or hoses to your valves.
Mar 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
this is joyce
This sounds like a center seal kit, they run around $80.00 they are complecated to install so I would suggest getting someone to install for you.
thanks,
joyce
Feb 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Water leaking from the bottom of the washer at the rear right corner!
firstly check that the inflow water pipes connected to the machine are connected correctly, feel around the pipes that touch the machine to see if there is any water. If there is the washers may need replacing on the pipe. Or the pipe may simply have got a bit loose through the machines spinning.
Oct 20, 2008 | GE Energy Star WCVH6260F Front Load Washer
Machine is leaking detergent
check inner gasket for small hole
u can take front off by removing screws from around inside door frame (including hinge screws) the panel will pull out towards u then u might be able to c where its leaking better
Jun 01, 2008 | Maytag Neptune MAH7500WH Front Load Washer
Leaking water Maytag Nepture washer MAH400AWW
open door and feel around the rubber bellow possible tear causing leak
Feb 27, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune MAH5500B Front Load Washer Logo
301 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
