Question about Coleman Powermate Powermate 5000W Generator
67 votage display on generator output.
Thanks for reponse.I'm in KSA.We have cummins 3 phase generator.according to your instruction i have checked now 67 votage display on the generator output.
  • mzahidraja Dec 17, 2008
    your information was correct
    Thanks
  • Anonymous Mar 25, 2014
    3 phase generator keeps shutting down with water temperature S/w fault coming up on display panel
  • 169 Answers
Please stop making new problem threads each time you answer, instead post a comment to one of the 5 threads you already have open for this problem. It's getting hard to follow the conversation :-)
OK, now to the problem. You say you have checked 67 volts is displayed on the generator output, I think this means that you see 67 volts on the control panel display when the generator is running. This can be several different problems:
a) a bad CT/PT module that tells the controller the wrong voltage
b) a bad A/D module inside the controller itself
c) a bad voltage regulator
Get a real DMM meter and measure the voltages at the top side of the output (large) circuit breaker of the generator. Put the black lead of the meter on the neutral wire and then measure to each of the phase wires on the circuit breaker. If you get normal voltages then you probably have a bad A/D, if you get 67 volts on all 3 phases you have some other problem.
You still haven't told me what model/spec of generator this is, look on the data sticker on the generator cabinet.
Peace,
Carl
Posted on Dec 14, 2008
I have Hobart D300 mixer which operates at 220V, 3phase supply and whereas the facility has 208V, single phase supply. Is there any recommended phase converters available for this product. Thanks
Hi Bill
I may be wrong here......
But I've been around Electricity for a long time.
Have Never seen a device that does phase conversion.
A Building site or home will either have Three Phase or Single Phase Power Available
BUT...A portable (Hired) generator could be "three phase" and you could use any one of those phases individually or all three phases.
I have 3 Phase supply to my house!
But I use 230 volt Single Phase for appliances.
My Bore Pump uses a 3 Phase Motor,
(so with a voltmeter it would read about 440 vAC to the pump motor).
Some Further Info:
A GENERATOR is basically a motor used the opposite way. Rotate a motor and it Generates.
The Phases refer to the THREE Windings in the supplying generator in your suburb.
A Large Magnet passes each winding in sequence giving you the three ripples in the supply.
Our houses can choose to have 1 Phase or Three Phases from the street when you set up your electric supply.
So... to confirm, look at the wires on the supply poles to the premises. Usually three in our area (Oz)
Most people are not aware that a car Alternator is actually three phase. The Rotor is the magnet that rotates.
The only difference with an Alternator is that each "Phase" is connected to 2 Diodes (6 total) to convert the three phase to DC to charge the vehicle.
The Regulator controls the voltage to the Rotor, thereby controlling the output.
So.... An Alternator could in theory supply 3 Phase in a mobile generator. Custom Made. Constant speed would determine the frequency of 50Hz or 60Hz.
Not sure what country you are in
Hope this Helps or gives you food for thought!
Three phase electric power
Jul 08, 2015 | Hobart Food Mixers
SHOWS CODE 36
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
Most likely, rotor slip riings, brushes, control board (if no stator output)
Oct 20, 2014 | Onan CUMMINS 4.0 KYFA/6747 - Cummins...
Troubleshooting generators
Not normally, the board outputs to the fuel pump, or LP shut off solenoid. It doesn't know the difference.
Aug 12, 2014 | Onan CUMMINS 5.5 HGJAB-6755 - Cummins...
I purchased a generac 22 kw 3 phase 120/240 volt generator. I was surprised to find that it had a wild leg. Can i change the leads on the stator output to eliminate the high leg and get straight 120/208...
This unit is wired 120-240V 3 phase Delta. if you are using on it 120/208V 3 phase application it will need to be re-tapped. If you are using it in a home 120-240V single phase it will need re-tapping, Do NOT just use 2 legs, as this will cause rotor imbalance and wear out the rotor bearings, and odd ball currents to flow. If there are 12 leads coming off the stator it can be reconnected. If not you are stuck with it, except by using a transformer
Dec 15, 2013 | Generac Generator QT02224JNAX QuietSource...
My older Honda EM3000 generator suddenly has developed an overvoltage problem. It now shows 200 volts output regardless of what setting you select (120/240). This generator was purchased new about 1983. ...
The voltage can go down provided the engine RPM drops off. So check if the oil change and scheduled maintenance was done on time.
If the RPM is set up according to the load , the voltage will rise up , but if the voltage is low the Load connected can also be high.
So if in dry load the generation is low you might need a full check up,overhauling/cleaning out of the alternator, engine to get his back to shape.
Sep 29, 2010 | Honda Electrical Supplies
How do I connect multiple (two or more) 3 phase ac power sources (from wind turbine alternators) to a single 3 phase junction to power one device?
what did you mean by single 3 phase? single phase motor have two wire output 110-110, 3 phase gen have 3 wires 110-110-110. if only two wires here ,this is single phase, all appliances are only single phase so you can connect it here, except some 3 phase motor or dynamo. the ac current has no polarity so you can connect to it all kinds of load depends upon the amperage of of your turbine generators
Jul 22, 2010 | Kitchen Ranges
Dear Please my Onan Generator Model # DFEC-3381761 I need wiring drawing to ATS connecting to Generator Thanks & Regards Farooqui General Electric Co. KSA
Here's a potential source that may help you...
http://www.genset.com/onan.htm
I searched Cummins-Onan and the model # you ask about does not exist on their website.
Jan 24, 2010 | Computers & Internet
I have a generator with a GE 3pole 100 amp main breaker its # 1-2-3 from left to right i'm using a 10ft piece 223 alum wire to hook it to the breaker panel my problem is the panel is a 100 amp square D...
the 1 and 3 poles, the 2nd is used for more a 3phase system, hooking up say 1 and 2 wont give you 120v. test with a volt meter to confirm but if your looking for 240 you need to use 1 and 3
Nov 06, 2009 | Electrical Supplies
Just bought wells fyer model # F-67
3 phase is VERY DANGEROUS, contact an electrician,
Jan 26, 2009 | Wells F-67 21167 Deep Fryer
I have cummins generator the voltage display on output 67.how can i soved the problem
Somehow your post ended up in the wrong category. On some models, 67 indicates a failed inverter. To be more accurate, would need to ask again with correct model and spec numbers.
Dec 13, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powermate 5000W Generator Logo
210 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
