Question about Arris Wireless G Broadband Router (wr850g)
No wireless connection
I have a Motorola Router modelwr850gp. I recently transferred my internet line to a new computer and am able to recieve internet direct line from the wireless router but other computers in the house are unable to connect to the internet using the wireless option. I have tried reboot sequences as well as loading up the wireless router software on the new computer that recieves the direct line. The computers using the wireless option show a good connection but I cannot pull up the internet. Help. Thanks.
Go to Parental Control after logging into 192.168.10.1. Then make sure you have allowed the MAC addresses of the wireless clients ( machines). Reboot the router one after making any changes.
Good Luck
Posted on Aug 03, 2009
Have NetGear N300 wireless router (wnr 2000v2)fed by motorola surfboard modem. N300 Port 3 output feeds OOMA internet phone system, Port 4 output feeds HP Touchsmart desktop pc (windows 7). PC will not...
hi,
go straight from your motorola to each wired computer to see if its a wire.can you can login to the router through your wired computer(touchsmart) in the settings and see if all your wired devices are listed, look at the parental controls, reset the whole router to default if you can, if your DSL. try a different jack in the house, get everything off that line but the motorola. go straight from the service jack outside the house(in the grey box) if you have to
jm
Jul 04, 2017 | NetGear N300 Wireless Router
I'm trying to connect my wireless HP DeskJet 3050 printer with my computer. In the set up it said to Press the WPS button on the router. The product automatically finds the wireless network and configures...
Click Start, All Programs, HP, HP Deskjet, Connect a new printer. Choose Network Printer, then connect the USB. It will transfer the wireless settings. Unplug USB. Viola! Wireless works.
Feb 10, 2011 | Arris SURFboard SBG900 Wireless Router...
ZyXEL P-330W wireless router
No it will not work you cannot connect a router to another router wirelessly and it will most likely not be detecting each other, routers are built to transmit internet signals from modems if you have a router and a computer but you do not have your own internet connection that will not work conencting to another router you will need USB Wifi Card transmitter/reciever to be able to connect to your friends wireless internet.
but if your friend only has a modem you can lend him your router and get a USB wifi transmitter/reciever to be able to connect to your router that is conencted to your friends modem this will work but will not work if you and you friend will both have a router creating a network.
Jun 20, 2010 | Zyxel Prestige P-330W Wireless Router...
Linksys router will not connect with motorola 2210 modem
Your problem may be timing.
Make sure you have all your cables connected correctly.
Do not have power to either the modem or router.
Plug in you modem and watch the lights go to work. Wait for them to settle down. Now plug in your router, again watching the lights. It should work now.
You can download Linksys' LELA program to monitor the network. Shows green lines to your computers, etc. when working and red lines when not. It will also give your status and make suggestions if you loose your connection.
Good Luck
Feb 24, 2010 | Linksys Wireless-G WRT54G Router
Can't find the internet when hooked up to the wireless network
Ensure that your wireless is enabled, Ensure that the router is connected correctly to the modem, and ensure that the modem is recieving signal. Set up your wireless router by LAN lining your computer to it, and then (General wireless device IP address) put in 198.162.1.1 into your internet browser bar. It should direct you to the Wireless device configuration for your router. From there, ensure everything is working properly.
Aug 28, 2009 | Compaq Presario 1200 Notebook
NO INTERNET CONNECTION
You need to properly configure the wireless settings of your computer. Make sure to disable the firewall on your computer like windows firewall or any other firewall. Now make sure that you have entered the correct wireless security key on your wireless settings. Go to control panel > network connections > right click wireless network connections > properties. Go to Wireless Networks tab and remove all the Preferred Networks there. Go to Add and proceed to adding manually your wireless settings.
Jun 01, 2009 | Arris SURFboard SBG900 Wireless Router...
Motorola Surfboard 4220 not working with my Netgear WGT624 router
Make sure that you have the ethernet cord from your modem plugged into the WAN/Internet port on your router. Then unplug the power cord from your cable modem and plug it right back in. After the modem fully comes back online, unplug the power cord on the wireless router and plug it back in. wait 30 - 60 sec and then try and connect.
Most cable companies only allow one active"CPE" at a time for internet access. All this means is when you change what is connected to the cable modem you must always reboot the cable modem to allow access.
Hope this helps. Let me know if it does not work.
Please rate.
Mar 23, 2009 | Arris SURFboard SB4220 Modem
Can I use my router just as a Wireless router with a DSL .
i doubt it will work. most times the cable companies give you a modem/router all in one box. the problem is there in no inbound connection to recieve an internet signal other than the cable cord connection. with the dsl modem you will need a seperate router. they cost around $40-50 on avg
Feb 05, 2009 | Arris SURFboard SBG900 Wireless Router...
Wireless router
I THINK YOU HAVE TO CHECK FOR A FIREWALL PROBLEM
THAT STOPS SOFTWARE FOR WIRELESS
Dec 06, 2007 | Dell Inspiron 6400 Notebook
In my new router getting less speed in wireless connection than when connected with a cable.
The 54 mbps refers to the stream rate from the router to the wireless reciever, the 100-110 kbps you refer to is the connection speed to the internet. These are two different things, if you were transfering files from one pc to another it would transfer at a max speed of 54 mbps. If you connect via a cable it would be 100 mbps. Your internet speed depends on your isp server your downloads will be less than 256kbps, with even less upload speed.
Dec 19, 2006 | D-Link AirPlus DI-524 Wireless Router
Arris Wireless G Broadband Router (wr850g) Logo
106 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
